Machining Raw 4340 Forgings - Con Rods
Discussion in 'The Hokey Ass Message Board' started by GlassThamesDoug, Dec 31, 2009.
  1. GlassThamesDoug
    GlassThamesDoug
    Does anyone know a machine shop in the Midwest that machines connecting rods from raw 4340 GM Bowtie forgings.
    Doug
  2. Rich B.
    Rich B.
    from Portage,IN
  3. mikeyfrombc
    mikeyfrombc
    any particular reason you want to use that particular forging ? today you can pretty much buy any rod style you want from a number of different sources
  4. GlassThamesDoug
    GlassThamesDoug
    Bought them dirt cheap....would like to get a nice set made once.........then should last me. Came from a Nascar Shop in North Carolina......otherwise might make good weights for the canopy at the shows.....
    I sent an email to Steve Schmidt Racing....Thanks,
  5. Doug,
    There's several places that could do it. Four I would check with:
    Bob Hardison- http://www.jetboatbob.com/
    Mike Phillips- http://automachperf.com/ Bob & Mike are part of the Kentucky Gang down around Owensboro that's doing quite well with drag racing & drag boats.
    Randy Malik- http://www.rmcompe***ion.com/index.html Randy isn't a machinist per se but has lots of good connections in the Detroit area...is also a fanatic for detail. If he recommended a shop I'd trust it.
    Dave McLain- http://www.mclainsautomotive.com/ Super nice guy, works on a little of everything from monster trucks to SBCs, and a very versatile & smart guy.
    Whether it will be cost-effective to do it (***uming the end result is strong enough for your needs), vs. cost of readily available rods, is another question. Unless you got these things for almost nothing, I would think that a **** H-beam is roughly comparable in strength & possibly about the same price, factoring in shipping & initial purchase price.
    One more local place to us...and I must caution you that I've never used them, nor do I have any experience with them...but they are relatively new & seem to have a good rep so far....
    Chenoweth Speed & Machine
    368 Erie Avenue
    Morton, IL 61550 (309)266-8084
    If you want to take a look at them, check here....http://www.centralstreetscene.org/forum/index.php and look towards the bottom in the sponsor section. Take with the appropriate grain of salt, since they ARE a sponsor of the forum, but it seems promising. I plan to talk to them in a month or two about a BBC.
    Edit: There have been quite a few negative comments on YB about Steve Schmidt recently. Some of these guys are more credible than others...& every business has its detractors...but there are several instances where people did not get what they paid for. http://www.yellowbullet.com/forum/showthread.php?t=196585
  6. GlassThamesDoug
    GlassThamesDoug
    Thanks........I will see what they can do.
    Doug
  7. GlassThamesDoug
    GlassThamesDoug
    No Luck So Far.......Need to find the shop that machined them for GM,, I doubt the GM would have done such low volume work.
  8. racer756
    racer756
    Try a rod manufacturer such as BME, Brooks, GRP, Howards, etc.
  9. stealthcruiser
    stealthcruiser
    Did ya' Google up some :Katech Engineering??????
  10. dieselc
    dieselc
    from ohio
    Man it might be pretty expensive to get this done, might be better finding a set of good used ones cheap.
  11. mikeyfrombc
    mikeyfrombc
    i doubt they have fixtures and tooling for steel rods the companys you suggested are strictly high end aluminum rods .
    as posted earlier in this day and age it,s gonna be tough to find some who will do them for less then what a set of EAGLE , **** and the likes can sell a set for , if you are dead set on using them i suggest you check out some drag race sites you may find someone
    you could try Carrilo rods o know they used to be hand machined in the past they may still some manual procedures
  12. Hmmm. At this point, I'm thinking you may have to go to Carillo, or Crower, to get it done. I'm a little surprised, I guess...though some of these shops may simply be looking at their setup time & what they will have to charge, vs. what they figure you would be willing to pay.
    Do you need anything unusual for the C-T-C length, or will it be the common 5.7 or 6.0"?
  13. GlassThamesDoug
    GlassThamesDoug
    Yeah ..............unless I find the supplier for GM Performance Parts that did the original machining, it may ge a good paper weight.
    Most indicate they purchase Billet material and make the H or I beam.............Rods.
  14. fasttimes
    fasttimes
    from NC
    If they came from a NASCAR team in North Carolina. Most of the Connecting Rod Forging comes from Carrillo Rods in Southern California. You may want to contact Roush in Michigan for Machining (They build other Engines other than Fords).
  15. GlassThamesDoug
    GlassThamesDoug
    Maybe Carrillo Forgings..........I guess if I can get $7 each at a swap meet, I get my money back...........might look good on a desk.....Did send an email to katech....will see what comes of that....I know someone who has a contact at Venolia they know eveyone in Cali....maybe something there.
    got some time yet........2 spare motors to blow up before then......
  16. Mr69novaman
    Mr69novaman
    Can you post a pic of one of the forgings? We might be able to do something with them. Me and my father own Dexter Manufacturing www.dextermfg.com We do a lot of odd engine machining and CNC Machining as well. a custom setup like that might not be so tough.
  17. GlassThamesDoug
    GlassThamesDoug
    Me69NovaMan, Here a few photos. The forging is 1" thick, and the are the I Beam type.
    Thanks, Doug
  18. FLAT6
    FLAT6
    I just talked to Mike at Engine Supply, the guy to talk to about this stuff. He said they would do it for you but it would cost 2-3x the price of buying off the shelf **** or Eagle rods. They would do them proper and have made many rods from scratch for the biggest names in the business. If you want his number I can pm it to you. Thanks
    Mike
  19. GlassThamesDoug
    GlassThamesDoug
    Yes FLAT 6, Send me the number.
    Thanks,
    Doug
  20. GlassThamesDoug
    GlassThamesDoug
    Yes the contacted me back, and do not have the fixture or program to set these up. At least they responded back, which is always a good thing. :cool:
  21. gas pumper
    gas pumper
    You need to find a hobby machinist who thinks the challenge is worth his time.
    I've made single rods for small engines before, and it's a lot of time involved.
    Cool pieces, tho.
  22. nutajunka
    nutajunka
    I worked in a high performance machine shop, and my job was to blueprint con. rods, small blocks to hemi's and we did most everthing that could be done to them. I think like everyone else, it might be cost prohibited compared to buying even a semi-finished rod and having it worked to your needs.
  23. FLAT6
    FLAT6
  24. GlassThamesDoug
    GlassThamesDoug
    UNCLE................listed them on the you know what............someone else can find the machinist......
  25. GlassThamesDoug
    GlassThamesDoug
    $69 can own them if interested.
  26. CNC-Dude
    CNC-Dude
    How do you want payment.
  27. GlassThamesDoug
    GlassThamesDoug
    PAYPAL or MONEY ORDER is fine. SEND ME PRIVATE MESSAGE I GIVE YOU ADDRESS. CAN SHIP FLAT RATE ($15 with tracking) DId you look at the photos on my HAMB page. These came from Carolina area. Seller said they were from a big time engine builder? I AM 100% FB on THE LIST SITE.
  28. GlassThamesDoug
    GlassThamesDoug
    Still for sale...........Need to have access to a Machinst that can finish these? $55
