Maths help needed! marking crank pulley degrees.
Discussion in 'The Hokey Ass Message Board' started by lowsquire, Jan 3, 2010.
  1. lowsquire
    lowsquire
    from Austin, TX
    Ive put a TDC mark on my 99A Flathead and made a pointer, but I would like to mark ten, twenty and thirty degrees so i can get an idea of timing at idle and total advance, As the engine is in the car and only has an inch in front of the pulley, I think the best way to determine the marks without a degree wheel on the front of the pulley (Becuase I cant get in there to see it) is Via good old mathematics..
    So with a crank pulley Diameter of 5.175 inches (131.4 mm) how would i work out how far around the pulley ten degrees is?
    I know it will have Pi in the equation, but its been twenty years since i FAILED maths at high school..
    Im sure someone out there can do this in two seconds...
  2. Andy
    Andy
    5.175 x 3.1416 = 16.2577 for 360 degrees. Divide by 36 for 10 degrees = .4516" for 10 degrees
  3. 5.175" X 3.1416 = 16.258" cir***ference. 10 degrees = 1/36 X 16.258 or .452".
  4. 131.4 millimeters x pi = 412.805275 millimeters
    Divide this by 36 to give 10 degrees.
    Answer is 11.466813 millimeters on the curve.
  5. thunderbirdesq
    thunderbirdesq
    If you don't feel like doing math, get a little artist's protractor and hold it up to the pulley. Mark 10*... Done!
  6. duste01
    duste01
    three way tie!
  7. flamed34
    flamed34
    Mark out the .4516" on a piece of paper or tape (it would be easiest to dial this in on a digital caliper and mark to the jaw opening)...pull it around from your 0 and mark it!
  8. lowsquire
    lowsquire
    from Austin, TX
    Damn you guys are Quick!!
    Thankyou very much. who needs online calculators when you gots da hamb!!
  9. very good points
  10. lowsquire
    lowsquire
    from Austin, TX
    yep the positive stop method was used to set up the pointer and TDC ,before i put the heads on.
    yeh I understand the measureing around a curve bit, will do it later today and take some shots to help others out hopefully.
  11. Divide pulley into quarters . They are 90 degrees. Divide them (the 1/4s)in half. That is 45 degrees. Divide them in half . That is 22. 1/2 degrees . Divide that in half and you get 11 1/4 degrees. The side of that line closest to the tdc mark is 10 degrees or so darn close it wont matter. All you need is to cut out a circle of thin paper the same diameter as your pulley. Then fold it in half then half that to a 1/4. Fold that again to 1/8 (45 degrees ) fold that again for 1/16 (22 1/2 degrees) amd once more gives you the 11 1/4 degrees. No math no measuring just simple paper work. I use this when finding hole spacing on round objects like spacing the screw holes on my wooden steering wheel. I just fold till i get the spacing I want. When i unfold there are all the spots evenly spaced and easily seen.
    Don
    I made this one for a different reason hence the diamond shaped holes and I started with a square but it only takes a minute to do. Made the second one fom s**** paper today. Takes less than a minute/
  12. super plus
    super plus
    Borrow or buy a degree wheel
  13. Wow.
    I think measuring 11.5mm from TDC is the easiest way for sure... :D
