can you paint over chrome?
Discussion in 'The Hokey Ass Message Board' started by chopt55bc, Jan 5, 2010.
  1. chopt55bc
    chopt55bc
    i have a pair of cal custom valve covers that have been chrome plated. i wanna paint between the fins. is there any way to prep the chrome so the paint will stick?
  2. pitman
    pitman
    SEM makes an etch primer in a rattle can, might be worth a try.
  3. holeshot
    holeshot
    from Waxahachie
    CHOP...sure people do it all the time, don't even have to sand. just wipe between the fins, well to get oil and dirt off. that's it and good luck. this is 1 of the few times i like painted chrome. man your going to love the result...POP.
  4. HOTRODPRIMER
    HOTRODPRIMER
    I just cleaned them good and brushed the red enamel on and wiped the excess off the fins with lacquer thinner as soon as the enamel started drying . HRP
  5. rocket8
    rocket8
    from antioch CA
    yep, pick up some wax and grease remover, clean em up REALLY WELL, dry REALLY WELL and paint.
  6. Marcia
    Marcia
    Same thing. I painted the whole thing and then wiped off the fins.
  7. i did one set with enamel primer and painted the polishe d out area and had some paint com loose when demasking, would be best to skuff pad the areas to be painted, also did my OTB aircleaner tops, this stuff looks nice
  8. It helps to use "bulldog" primer first. It's really sticky stuff and sticks to just about anything.
  9. First - wax&grease remover. Second - scuff with red scotch-brite. Third - paint (or prime and paint). That's how we learned to do it at tech school and it works for me.
  10. SlowandLow63
    SlowandLow63
    from Central NJ
    Ya buddy.
  11. skullhat
    skullhat
    one shot will stick good for brushed applications.
    for spray , id go the bulldog, or etch primer route that has been mentioned.
    painting over chromed cast parts like valve covers seems to last ,unlike other chromed parts such as bumpers
    skull
  12. run a scotch brite through between the fins because sometimes the surface might be to shiny and smooth for the paint to stick which might allow it to chip off
  13. rockable
    rockable
  14. SaltCityCustoms
    SaltCityCustoms
    An adhesion promoter will also help a****st the other replies.
