Ford 262 I6 to T5?
Discussion in 'The Hokey Ass Message Board' started by Barn-core, Jan 5, 2010.
  1. Barn-core
    Barn-core
    I'm looking at a '60 F100. It has the big truck 262 straight six, and granny low 4 speed. I was wondering if anyone might know what would be involved in swapping in a T5? Thanks, Barn-core.
  2. bluebolt
    bluebolt
    from Benton LA
    Not too hard, you will need a new driveshaft and a modified bellhousing and other small parts. http://www.ford-y-block.com/truckt5.htm
    The best junkyard T5 to use is a 1990-1993 Mustang V8 t5, next is the 1985-1989 v8 trans. least desireable is the 1983-1984 V8 Mustang non World Cl*** trans. If you want a new trans the Ford Racing T5-Z would be my choice.
  3. Barn-core
    Barn-core
    Thanks for the info bluebolt. Anyone else know of any other options?
  4. Flat Ernie
    Flat Ernie
    Tech Editor
    Check the link in my sig. Lots of T5 info. I'm not sure what transmission bolt pattern was for your truck, but if it's the same as p***enger car, anything written about adapting the '49-53 flathead steel bellhousing should apply...
  5. Barn-core
    Barn-core
    Does anybody know of any other possible swaps for these motors. Maybe a better 4 speed, w/o the granny gear, maybe a C4, or AOD?
