if you are wanting to upgrade the brakes on your 37-48 banjo rear end , use 87-96 ford f 150 rear brakes , heres a how to ,click pix to inlarge . theres a discription at the bottom of each pic http://s843.photobucket.com/albums/zz359/jonnybe1947/banjo brake update/rear 40/
You put a lot of thought and good engineering into this brake setup. Nice lowbuck upgrade for the application. With the big binders on the rear you could need a proportioning valve. But needless to say a good inexpensive job.
Great job. This would actually work on any 28-48 Ford P***enger Car OR 28-47 Ford 1/2 ton Pickup/Panel rear end. You would need to check the 28-31 A rear end spring perch clearance to the cylinder brake pipe inlet on this before committing to it just like the early Ford conversion. How about a shot from the rear installed?
to answer some of your questions,, there is a discription under mosr of the fotos if you inlsrge them and scroll down !!! is this my album ?? yes backing plates , ? junk yard , get everything ,so you will have e-brake parts drums $ ? best i remember 20$ each , the complete job was less than $200 hub ?? hub is for outboard drum mount and it floats !!! i really hope this helps someone with their brake s oh !! i used a speedway disc kit on the front , so i still have 5 on 5 1/2 lugs all around
Wow, Thanks for posting, this is just what I needed, besides 87-96 ford F-150 rear brakes are alot easier to find than decent 39-41 Ford.
