A couple BASIC Model A questions....
Discussion in 'The Hokey Ass Message Board' started by Big Mac, Jan 9, 2010.
  1. Big Mac
    Big Mac
    Decided to make some very mild changes to my BONE STOCK model A. Since I'm totally unfamiliar with these, I have a few real basic questions. Thanks in advance for the help.
    - Do I need to make any changes to put different wheels on it? As long as they're 5on5 1/2, they should bolt on, right?
    - I would like to drop the front end just a little. Maybe a 2 inch dropped axle? Whats the best method to drop it?
    - I'm going to run the stock motor, but would like to dress it up a little. Where can you get dress up parts for a stock model A motor?
    That's about it I guess, unless anyone has any cool pics of a NON-chopped, NON-channeled '31 5 window. I would love to see some pics. Thanks HAMBsters!
  2. Rob Paul
    Rob Paul
    Run some early ford solid 16" wheels, or some 16" 35 Ford wires. No problem. Get yourself some juice brakes, and drop that front axle, and reverse the main leaf. Model T spring in the rear, and youve got a pretty nice stance.
    Stay away from AutoZone type dress up stuff. Consider a downdraft intake with a 97.
    Rob
  3. moefuzz
    moefuzz
    Bolt on any Ford Truck rim to ~1990 (cool!), Many Dodge rims fit to but I wouldn't know which is which with dodge.
    Drop axles are available for A's. Check Street Rodder Magazine, lots of ads
    Banger goodies can get expensive, Finned heads, header, Carb/intake, balanced crank,cam, more. The sky is the limit as long as your wallet is in that same sky.
  4. Rich Wright
    Rich Wright
    Any early Ford wheel will fit.
    If you only want to drop it a couple of inches, you can remove one or two leaves from the spring and do the rest with tire sizes. I don't know about finding a 2" inch axle.... If you want change axles, just use a 3".
    I'm not a banger nut 'cause I can't afford it. Dress-up/speed parts are pretty spending, but easy to find. There are a bunch of banger guys on the HAMB so do a search and you'll find anything you want...
  5. REM/Mo
    REM/Mo
    from Missouri
    If you are still running the stock mechanical brakes a dropped axle is going to cause problem with the front brake actuators.
    Reversed spring eyes and a softer spring would be the easy way.
  6. RussTee
    RussTee
    use a 32 -34 axle and perches then you can keep mech brakes banger gear is expensive but funjoin in on the monthly banger meet here on the HAMB and all will be answered
  7. Lowbuckboz
    Lowbuckboz
    This is totally stock other than lowering it. Still running mech. brakes.
  8. oldskool30
    oldskool30
    Mostly Stock "B" motor , juice brakes , downdraft carb , stock rear spring , posie reverse eye front spring , F100 steering box , mitchell overdrive
    before
    after
  9. Thirtycoup
    Thirtycoup
    this thing is pissa.
  10. Lowbuckboz
    Lowbuckboz
    Hey Thirtycoup, I had to look that up! Thanks man! lol
  11. Big Mac
    Big Mac
    That is exactly what I'm wanting to do, except mine doesn't have nice paint. Your car is awesome Lowbuck! What size tires/wheels front and rear?
  12. brocluno
    brocluno
    You can even go down to 14" rims on the front with 1960's Linclon wheels. I think all Linc's had 5 on 5 1/2 up to the late 60's.
  13. Lowbuckboz
    Lowbuckboz
    Thanks man! Front tires are 5.50 16 & rear are 7.50 16. Wheels are from a '42 Ford 16 by 4.
  14. Big Mac
    Big Mac
    How did you lower it, and how much did you lower it?
  15. Lowbuckboz
    Lowbuckboz
    Rear is lowered with a 27 T rear spring with 1 leaf removed, dropped about an 2 1/2". Front is lowered with a 4" stretched dropped axle and a reversed eye spring, dropped roughly 5.5" when comparing to stock ride height with a new original spring.
