so we used Lacquer paint...look what HAPPENED!
Discussion in 'The Hokey Ass Message Board' started by Terry O, Jan 10, 2010.
  1. Terry O
    Terry O
    just cleared..not rubbed yet
    Terry
  2. Theo Douglas
    Theo Douglas
    Shiny!
    Very nice, gentlemen.
  3. blt2go
    blt2go
    we used to use alot of lacquer with a 2k clear. switched to base/clear. miss the lacquer. looks super, do you rub with foam or wool pads?
  4. Kripfink
    Kripfink
    Superb!!congrats
    Paul
  5. jonnycola
    jonnycola
    What color is that??? Where did you find it in lacquer?
  6. Beano
    Beano
    from Pa.
    Very nice , love the lacquer .
  7. langy
    langy
    Looks nice, how come the wheelarch is not painted ???
  8. 3wLarry
    3wLarry
    from Owasso, Ok
    don'tcha just hate it when it does that?
    kidcampbell71 likes this.
  9. MarkzRodz
    MarkzRodz
    Did you get that color off eBay? LOL. I have a gallon of that color.
    Hey!! What clear did you use?
  10. The Shocker
    The Shocker
    Man ,that came out slick.I would also like to know where you found Lacquer ...
  11. storm king
    storm king
    I miss lacquer; I thought you could't buy it anymore? We used to have a guy in New York paint our race cars, Bob Hall, and he could lay it on without needing to buff it.
    You did good!
  12. rgaller
    rgaller
    Hopefully you don't live anywhere with large temperature differentials, that paint will start shrinking/cracking in no time.
  13. flatheadpete
    flatheadpete
    from Burton, MI
    Looks good. Where's the rest of the car?
  14. The37Kid
    The37Kid
    I think we need a Horduras Maroon HAMB Club! Well done, you can tow my Lyndwood any day.
  15. Rich Wright
    Rich Wright
    Looks like it layed down nicely... Is it lacquer clear or Eurethane? Who made the clear?. How long did you let the lacquer gas-out before applying the clear?
    Sorry for all the questions...
  16. 56don
    56don
    I have had lacquer last 20 years on cars that have seen all kinds of temperature shifts.It will probably eventually show cracks,but not any time soon I would bet.
    Why be the guy with the negative post?
  17. hemi coupe
    hemi coupe
    from so-cal
    The painter forgot! Kidding, the car is full fendered and it is going to be painted with undercoat/paint.
    Jimmy White
  18. Rich Wright
    Rich Wright
    "Hopefully you don't live anywhere with large temperature differentials, that paint will start shrinking/cracking in no time."
    I've probably spray a few thousand gallons of lacquer over the years with very few problems. And pretty much all of those could be attributed to:
    Not allowing the material to dry thoroughly enough between coats.
    Laying on too much material, including clear lacquer, over the top of a lacquer base.
    Clearing with a catalyzed product before the lacquer is completely dry......
    Primer on too thick and not properly g***ed-out.
    All these problems are the same root cause.... Trapped solvents and/or too much material thickness.
    If used correctly, lacquer will last a long, long time.
  19. Greezy
    Greezy
    That looks very nice. Laquer is still out there if you look for it, but it aint cheap anymore that for sure.
    Also would like to know what clear you used.
  20. 40FORDPU
    40FORDPU
    That's okay for a base..will you be painting satin black over that? Looks great..like the color.
  21. powdercoater46
    powdercoater46
    How much time do you wait inbetween coats using laq? AND what clear coat can u sue succesfully??
  22. banditomerc
    banditomerc
    I get it in Mexicalli,mex:D
  23. banditomerc
    banditomerc
    "in no time",explain...20,30,40 years...by that time you will be tired of seeing that color anyway.Nice paint work.:eek:
  24. Rick Sis
    Rick Sis
    from Tulsa OK
    Thanks Rich! I see a lot of misinformation posted about lacquer and it's good to see that there is always someone on the HAMB that knows the bottom line.
  25. carcrazyjohn
    carcrazyjohn
    from trevose pa
    Looks great ,By the way Hibernia sells laquer paint .Look it up in Hemmings motor news.....Nothing wrong with laquer as long as you dont use a car cover ,Ill explain If the cover gets wet ,It traps the moisture in .My dads 34 Ford is holding up great since 76 .Keeping it waxed helps .His roof cracked in some areas ,Due to a moisture problem when he had it in storage .Other than that its perfect.
  26. lippy
    lippy
    from Ks
  27. Porter Man
    Porter Man
    Alliance Vendor
    from Mound, MN
    Look's great Terry! Bet you can't wait to drive it.
    Clark
  28. Von Rigg Fink
    Von Rigg Fink
    from Garage
    sweet..i did a triumph bonneville MC in a color close to that..in lacquer too..loved the stuff
  29. RUDOG
    RUDOG
    *****in Terry O!!! Congrats on getting the paint on....Looking forward to see it at GNRS.
  30. Terry O
    Terry O
    We used the PPG line, custom color mixed by the painter (honduras + gold flake)
    Jeez - now you tell me!
    Spread around so-cal. Trying to find all the pieces before the GNRS.
    Terry
