If money were no issue, whats your ideal motor?
Discussion in 'The Hokey Ass Message Board' started by Dynaflash_8, Jan 12, 2010.
  1. mtrhd
    mtrhd
    exactly. http://picasaweb.google.com/mtrhd60559
  2. hotrod40coupe
    hotrod40coupe
    Just to be different, a Cosworth.
  3. 66Coronet440
    66Coronet440
    Definitely a 540 Hemi built by Dale Reed.
  4. BangerMatt
    BangerMatt
    If money were truly no object, a Miller V-16.
    or THIS:
  5. TomT
    TomT
    Ardun headed flattie ...
  6. What I have is what I'd have...
      64.1 KB
  7. Retrorod
    Retrorod
    an Offy banger in a track roadster!
  8. 66Newport
    66Newport
    528 Hemi. I am easy to please.
  9. squirrel
    Money is always an issue.
    I like the blown 454 in my 55, I built it at a time when I had a bunch of extra cash. 20 years ago. Even so, I built it on a set budget.
  10. revkev6
    revkev6
    from ma
    if money weren't an issue, then neither would the vehicle I wanted to put it in. My choice would be:
    a pratt and whitney wasp major R-4360 shoehorned into a corsair. also known as an F2G or "Super Corsair". It's the hot rod of the prop plan world. lets stuff the biggest engine in it we can!
    the r2800 that came in the F4U:
    the R-4360 that was stuffed in the f2g:
  11. V8Mongrel
    V8Mongrel
    from Apex, NC
    DFV for me, please.
  12. 61TBird
    61TBird
    I'll keep it simple...
  13. 55FORDWGN
    55FORDWGN
    Pontiac OHC 6..............cool motor. Any thing but a small block chevy
  14. D.R.Smith
    D.R.Smith
    Ford had some exparimental 4 cam small blocks for Indy,That would make my list
  15. 8flat
    8flat
    Flathead, Ardun heads, SCOT blower.
  16. falfas55
    falfas55
    A blown sbc from Big Al's Toy Box.It would be more streetable for me. FALFA
  17. Rocky
    Rocky
    Classified Editor
    Yup...me too.
  18. dcoe
    dcoe
    from washington
    Studebaker Indy engine 1950s
  19. okiegreaser
    okiegreaser
    from LA
    Olds 324 rocket with vintage speed equipment. 3 deuces, solid roller cam.
  20. kustombypook
    kustombypook
  21. Paul
    Paul
    Editor
    lot of responses are for a Ford version of a Mopar
    or some other run of the mill mill
    'don't know what I'd choose
    but it would probably be a one of a kind
    piece of perfection
    even then I don't see it costing much more than a million or two..
  22. young olds
    young olds
    one of these.
    Aluminum 2 Valve 455
    Aluminum DOHC 4 Valve 455
    Aluminum 2 Valve Turbo 455
    Iron, Aluminum 2 Valve 455 Hemi (W-45)( iron block, aluminum heads)
    iron 4 valve 455 hemi(w-43)
    Aluminum 4 valve 455 Hemi (OW-43) 300hp@3000rpm,600hp@6000rpm,700hp@6800rpm
    they are all oldsmobile engines. i would also like this one.
    indy aurora 4.0l v8. 10,500rpm redline and 650+hp, also an oldsmobile.
  23. 60'shotrod
    60'shotrod
    An early Merc Flathead, built to hilt with pre-war tuning goodies!
    Nick.
  24. Thorkle Rod
    Thorkle Rod
    I'll take 320CIABONES, Donovon Gemsa
  25. hillbilly
    hillbilly
    man...you beat me to it as far as the engine goes...I'd be the fool that figured out how to put it in something with four wheels. I've been looking at those smaller radials that people put in those 1/2 scale replica fighters..but money is still an issue. :p
    and that was my second choice...in an econoline. Sure, it'd be an aerodynamic brick, but what a quick little brick it would be.
  26. patrick66
    patrick66
    I'd like a 572 ci HEMI in a '63 Plymouth Belvedere I two-door sedan, complete with blower, dual carbs, alcohol, and enough torque to rotate the Earth the opposite direction!
    A Rolls-Royce Merlin engine in a Bonneville car would be another "if $$$ were no object" pick. I like hillbilly's idea in an Econoline, but if I were to go that way, my Merlin would go in a Dodge A-100 pickup...kinda like the "Maverick", but no wheelstands!
    The little Offenhauser Four-Bangers were amazing little engines, too! An Offy would be cool in the ultimate sleeper four-banger - a Metropolitan coupe!
    And, of course, the Chrysler Turbine Car engine in something!
  27. revkev6
    revkev6
    from ma
    as long as you don't go wild and want to put more than one R4360 in that four wheeled contraption I'm with ya! I wouldn't want to do a plug change on more than one 28 cylinder radial engine at a time .....:D
    just imagine a B-36. 6 of em, that's 168 spark plugs without getting into the four jet engines to maintain
  28. James66g
    James66g
    I am pretty lame I guess I would want the baddest FE motor ever the twin supercharged super snake shelby FE for my Galaxie! That way when I open my hood people would say "HOLY ****! What That !?" I can say "oh...that? well thats my F@ckin Engine" cause thats what FE stands for.
  29. Abone29
    Abone29
