Brake shoe question
Discussion in 'The Hokey Ass Message Board' started by Capt.Mike, Jan 13, 2010.
  1. Capt.Mike
    Capt.Mike
    A basic question for you. I have a Ford 10 bolt rear with drum brakes in my project. It has drum brakes. When I took the drums off I saw that there are two different size shoes. The problem is that on one side the large shoe is in the front and on the other it is in the rear. Looked on the web, 2 different answers. Which way is correct? Thanks
  2. HEATHEN
    HEATHEN
    from SIDNEY, NY
    The shorter shoe goes on the front.
  3. hotrod-Linkin
    hotrod-Linkin
    x2.....
  4. Capt.Mike
    Capt.Mike
    Thanks. As soon as it warms up I'll change the one. 14 here in sunny Charlotte, NC at 7 AM.
  5. bobss396
    bobss396
    It always cracked me up when I pulled a drum on a brake job and found them reversed or the long ones on one side and the short ones on the other. Usually some of the hardware was missing as well.
    Get yourself a book on brakes, the old Peterson ones were great, not sure if they're still in print though.
    Bob
  6. Spidercoupe
    Spidercoupe
    from Bevier, MO
    the short shoe goes on the front the long on the back on both sides
  7. gtkane
    gtkane
    Just remember "BB"...Big in da Back!
  8. HEATHEN
    HEATHEN
    from SIDNEY, NY
    ...but don't use a geographic reference point for it. Years ago, a not so bright coworker could never keep the brake shoe location straight, so the service manager told him to remember that the short shoe goes on the side closest to the workbench. One day, a car was backed onto his lift, and guess what........
  9. woodhawg
    woodhawg
    Hmm, My old 40 juice brakes have the long one on the front. Interesting that folks made them both ways.
  10. V8 Bob
    V8 Bob
    It depends on the design of the drum brake, as there are many. The Lockheed brakes that Ford used from '39-'48 were non-servo/fixed-anchor, with the larger wheel cylinder half pushing the longer forward-facing (and harder working) shoe. The '49-present Bendix and similar designs are servo, and have longer and usually thicker/different linnings on the secondary, or rear-facing shoes, because these do most of the work. You will also find modern non-servo drum brakes on the rear of many cars/lite trucks that have identical fore and aft shoes.
    Bob
  11. Capt.Mike
    Capt.Mike
    Thanks again, Da B's are now on da back, checked, adjusted and back on da ground.
