41 or 42?
Discussion in 'The Hokey Ass Message Board' started by victorsam, Jan 14, 2010.
  1. victorsam
    victorsam
    from Wyoming
    I am considering buying for my next project. Its rust free except for windshield frame. I am also curious as to what others would think I should pay for this.
  2. pasadenahotrod
    pasadenahotrod
    from Texas
    Well, if that grille is stainless and it looks like it is, and IF it also fits pickups the truck should be worth $1K.
    It could be a 41-early 47 vehicle. Only way to be sure is get the engine number from it and see, IF the engine is the original one.
  3. victorsam
    victorsam
    from Wyoming
    The grill is stainless. It was previously painted and has a few little problem areas as you can see from the close up. The truck itself (cab and clip) is the same as a pick-up. The original engine is in it, so I will check that out. Thanks
  4. 38Chevy454
    38Chevy454
    That looks like a big truck and you will probably find the fender cutout radius is larger for the bigger tires used on big trucks. I am not sure if the fenders and grille are wider too? The cab is definitely the same as 1/2 ton pickup.
  5. pasadenahotrod
    pasadenahotrod
    from Texas
    Those "problems" are no big deal, fix and polish rather than fix and have replated at today's astronomical prices.
    The big truck fenders are NOT the same as pickups in those years.
    I know that earlier Chevy trucks have bigger grilles than pickups.
  6. brett4christ
    brett4christ
    You got a pic of the firewall and/or rear window?
    Either one can be a YOM clue.
    Also the running lights on top of the headlights...are the 2-piece or one (not including lens, of course)?
  7. victorsam
    victorsam
    from Wyoming
    I have been superimposing the pics of the yellow one over known half ton pickups and the proportions seem the same. Of course measuring would be needed. Also the number of vertical grill pieces is the same. I can not be sure about the wheel opening, but Ive attached a pic. I do appreciate your guys' help
  8. victorsam
    victorsam
    from Wyoming
    The headlight housing is 2 piece, with the turn signal runner attached to the main housing with 2 screws. This is the best firewall pic I have.
  9. brett4christ
    brett4christ
    Fenders are definitely "big truck" and wouuld be way out of proportion on a half-ton. Grill is almost definitely the same on little and big.
    The running lights seem to be one piece. That leads me to believe it's a late-46 or early-47 model. All 45 and early-46 trucks had painted grilles and hood-side trim due to the war consuming all the chrome.
  10. brett4christ
    brett4christ
    Yup, firewall is post-war as well, or at least late-41. 39-to early-41 did not have the "X" pattern on the firewall.
  11. brett4christ
    brett4christ
    The last check (without running the frame/VIN #, of course) is...does the rear window have any screws around it from the inside? If not, definitely post-war!
  12. pasadenahotrod
    pasadenahotrod
    from Texas
    OK, here it is from the Chevrolet Parts Book, 29-54, March 54 edition.
    41-early 47 Pickup, 1/2 ton and 3/4 ton front fenders are the same, 1-ton-up trucks are different.
    41-early 47 Pickup, 1/2 and 3/4 ton grilles and 1-ton-up trucks are the same.
  13. henry29
    henry29
    That's not the original engine, looks like a 50's 235.
  14. victorsam
    victorsam
    from Wyoming
    Great, thank you. So...fenders are different, grill is the same. Side note, the gvw painted on the side states 16000
  15. 1946chevytruck
    1946chevytruck
    from london ,ky
    i would say it is worth about $800 but i would of less . they are fun truck to drive .thanks
  16. Hnstray
    Hnstray
    from Quincy, IL
    It is '54 thru '58, ***uming the valve cover is the original to the engine........'59 thru '62 had the breather cap midway, not near the front.
  17. squirrel
    You could start a paving company.
    neat find!
