'50 Stude Convert Rubber Vent Window Seal?
Discussion in 'The Hokey Ass Message Board' started by brigrat, Jan 15, 2010.
  1. brigrat
    brigrat
    from Wa.St.
    I have tried all the usual rubber seal dealers and struck out, anyone have a secret place to find vent window rubber seals for a '50 Stude Champion Convert? Thanks
  2. michiganman061
    michiganman061
    from Michigan
    You have a 50 champion convertible? Cool, I do too.
    Did you try studebaker parts vendors Chuck Collins in AZ, and Bill Fenesse (sp?) in Tenn?
  3. hotrod8
    hotrod8
    try steelerubberproducts.. they have a lot of seals for different makes ...
  4. brigrat
    brigrat
    from Wa.St.
    Michiganman, do you have any contact info you could PM me?
    Steelerubber was the first to say N/A, along with the other major rubber seal supplier's..............
  5. speedtool
    speedtool
    Bill Fennessy is a great guy, sure did me right on my '49 Champion.
  6. 54stude
    54stude
  7. jroberts
    jroberts
  8. 5brown1
    5brown1
    Just happened on the seals I believe you are looking for at CollectorsAutoSupply.com
    1-888-772-7848
    <input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden">
  9. brigrat
    brigrat
    from Wa.St.
    Thanks but at $433 a pr. I will p***..............
  10. michiganman061
    michiganman061
    from Michigan
    Try bill, I dug up his contact info. He was one of the first guys back in the day to offer repro rubber for studes. He's getting up there in age, so you'll have to call/write him (no internet)
    Fennessey Studebaker
    217 andover Way
    Nashville TN. 37211
    615-662-5013
  11. YEP, Fennessey in Tennessee is the place to go first.
    If he doesn't have it for that car, probably no one does.
  12. brigrat
    brigrat
    from Wa.St.
    Checked all the leads posted and still no rubber, will contact Bill next. Thanks 4 all info guys..............
  13. brigrat
    brigrat
    from Wa.St.
    Bill's the man! Just got off the ph. with him and he can set me up with what I need in a round about way as they don't make them anymore. Thanks!
  14. mottsrods
    mottsrods
    Bill is the guy to go to for what is repopped, but if you need it made, Steele Rubber will make it for you as long as you can make them a template of the profile. I been using them for years, and had to do this several times. It's not as expensive as you think it would be.
