any ideas on how to take off bumperstickers?
Discussion in 'The Hokey Ass Message Board' started by 69f100, Jan 16, 2010.
  1. 69f100
    69f100
    from So-Cal
    we just got the rear bumper for our 65 f100 for free, which is good, but their is two ugly bumperstickers on it. I was wondering if any one had any ideas, tips or tricks to take them off. any info is helpful, thanks.
  2. I have used Gunk decal remover that worked pretty good.
    If its chrome, a razor might be the best way.
    Bill
  3. Christie
    Christie
    try this one, rub some baby oil on them and then soak a paper towel with more baby oil, lay it on top of the stickers and let it sit for an hour or two. the oil should penetrate the sticker and break down the adhesive.
  4. MEMPHIS RAT
    MEMPHIS RAT
    gas works great!!!
  5. Beano
    Beano
    from Pa.
    WD-40 works the same way .
  6. greasemonkey060
    greasemonkey060
    Lacquer thinner, gas, rubbing alcohol probably, just about any strong solvent..
  7. Christie
    Christie
    your right, thank you, didn't even think of wd-40, same oil base.
  8. Lighter fluid (naphtha) will get the residual glue that remains after s****e/peel/heat/etc. Trust me. I have used it to remove tape and glue on thousands of golf club shafts when replacing grips. Also toulene and acetone will work.
  9. DrJ
    DrJ
    IF you get desperate enough to go the razor blade route, use the blade to sharpen a tongue depressor/popsicle stick into a non-chrome-scratching s****er to s****e the crud off, resharpen as necessary...
  10. Heat gun or hair dryer works very well.
  11. otas
    otas
    I do this often. I use enamel reducer and keep rubing it with a soaked rag. You can use any kind of s****er with a good straight edge that will not scratch the chrome. May take a bit but it works everytime.
  12. Goo Gone - you can find it at Walmart or hardware store :cool:
  13. boldventure
    boldventure
    I've used "Goo-Gone" for similar problems works well for me. Not usually hard to find in the cleaning produts section at supermarkets.
  14. zzford
    zzford
    I often have to remove stripes and city decals from vehicles at work. I use a pinstripe removal wheel. It works great. It won't hurt the paint under it, either. Body shop suppliers carry them.
  15. Harbor Frieght's last flyer had a heat gun on sale for eight bucks. It aught to last long enough to do a couple bumper stickers without exploding into flames or anything.
  16. Big Tony
    Big Tony
  17. NAILHEAD JONES
    NAILHEAD JONES
    from Lomax ILL
    goo gone works could
  18. 80 grit sandpaper:eek:, just kidding, enamel reducer will work best if bumper is chrome, painted surface wd-40, and some common sense, oh, old wash cloth as they have texture to remove the residuals.;)
  19. oldpaint
    oldpaint
    lacquer thinner is probably the strongest and will work the fastest. keep it soaked and start from the top so the thinner runs down into the sticker.
    It also helps to talk real nice to the sticker...don't yell!!!:rolleyes:
  20. pasadenahotrod
    pasadenahotrod
    from Texas
    3M has an Adhesive Remover that works very well. It is the only product I've ever found that removes the GM death goop from steering wheels and seems to stop it from reappearing.
  21. fordcragar
    fordcragar
    from Yakima WA.
    I would probably start with a heat gun and also use almost any of the other methods mentioned as well to complete that job. All bumper stickers are not created equal, so whatever type that they are has to come into play.
    After all of this is said, I hate them. Most people think that they can always take them off and the bumper will look fine, the reality is you will probably always see an outline of where they were. At least this is what I've noticed.
  22. Rog
    Rog
    I don't know for sure about a bumper sticker, but I know it works for old window tint. A steamer of some sort to take it off and Easy Off oven cleaner will remove the sticky stuff.
  23. Goo Gone is just overpriced lighter fluid with some citrus oil to mask the smell.
    Edit.....
    My bad...I am thinking of GoofOff
  24. Man - I think Harbor Freight just found their new
    North American spokesman :D
  25. boldventure
    boldventure
    Works good though....
  26. plym49
    plym49
    from Earth
    x 2
  27. noboD
    noboD
    Mine quit the second time I wanted use it, F'ing junk!
  28. Master of None
    Master of None
    x3 for the 3m adhesive remover. They also make a giant eraser on a wheel that u put in a die grinder. that works great but it does fling stuff everywhere.
