Projects My 1966 Ford F100 Resto-Mod
Discussion in 'The Hokey Ass Message Board' started by tschmitt, Oct 1, 2009.
  1. tschmitt
    tschmitt
    from IL
    A little timeline of the frame.
    Started with this...
    Then sandblasted after being completely dis***embled...
    Primed...
    and finally painted...
    Should be alot of fun when I get all the other misc frame parts done and get it all put pack to get together. Finally no more dirt and grease lol.
  2. ccain
    ccain
  3. Kustom7777
    Kustom7777
    from Austin, TX
    you're off to a great start,,,love those shortbed fords
  4. tschmitt
    tschmitt
    from IL
    Awesome! Just joined lol didnt even know there was a group for the slicks on here. Thanks for the invite.
  5. tschmitt
    tschmitt
    from IL
    Thanks Kustom, I love the swb alot more than the lwb, they seem more *****y when they have the right look.
    fiveoh108 likes this.
  6. Side
    Side
    Did the thought ever cross your mind to swap your rolling ch***is out for an eighties Crown Vic?
    I bought an 88 Crown Vic a year ago with 48k miles for a 71 F100 swap cost me $1000 bucks for the car. The Vic gives you a smooth ride, good brakes, a/c, auto, 5.0 power, and the wheel base is less than an inch off.
    It's a shame that my ch***is swap fell to the wayside and now my Crown Vic is the most reliable driver I have.
    I am impressed with your build though.
  7. tschmitt
    tschmitt
    from IL
    No when I bought the truck I hadnt planned on anything too extreme like doing a frame swap but with the amount of work I have done so far to the frame I guess I couldve lol. When I started the initial plan for my truck I based everything off of the stock frame and worked with what was available as far as aftermarket. I have read about the Vic swap before though but I never really considered doing it. I had planned on actually putting in a 5.0 efi setup but decided to switch to the big block Cadillac 500 instead. Thanks for the compliment :)
  8. chaddilac
    chaddilac
    Wow!!! $800 You really scored!! keep the updates coming!!!
  9. tschmitt
    tschmitt
    from IL
    Ya I jumped on it when I first saw the price, it was only on craigslist for about a day, went and looked at and bought it that same day. Should be some more parts painted within the next week.
  10. tschmitt
    tschmitt
    from IL
    Well I finally got the small frame parts painted silver. They turned out great and I couldnt be happier with it. Primed with 2 coats of epoxy then painted with 2 coats of SS Urethane. Very nice finish and feels great to do it all myself. I still have to have my kingpins pressed out and get my 9 inch cleaned up and then I can prime and paint the rear end and I-Beam setup as well. Here are the pics.
  11. tschmitt
    tschmitt
    from IL
  12. tschmitt
    tschmitt
    from IL
  13. tschmitt
    tschmitt
    from IL
  14. tschmitt
    tschmitt
    from IL
    Thats it for now. Cant wait to start putting it back together.
  15. CJ Steak
    CJ Steak
    from Texas
    WOW. Awesome attention to detail! I'd love to see some pics of that frame out in natural light.
    Good job.
    -Chris
  16. tschmitt
    tschmitt
    from IL
    Thanks CJ, I cant wait to see it out in the light too. Hopefully in the next few weeks I can roll it outside and get a real good look at it. I'll be sure to take plenty of pics.
  17. A Rodder
    A Rodder
    Your doing a great job, I like the detail in your pics for the purpose of this thread. Excellent. I have a super super nice 65 SWB, and have had a 66 LWB for over 10 years. I am curious, why do they call these trucks slicks? I kind of feel like I am on the outside looking in but I know them quite well.
  18. tschmitt
    tschmitt
    from IL
    Thanks for the complimant. I really dont know why they call these trucks "slicks". Thats a good questions though lol, ill have to do some research on that.
  19. tschmitt
    tschmitt
    from IL
    Finally got everything painted for the winter. I got all of the frame parts painted so I am done painting, sandblasting, and priming until I start on the body and that isnt going to happen to till late next year at the earliest. Here are some pics.
  20. tschmitt
    tschmitt
    from IL
  21. tschmitt
    tschmitt
    from IL
    Thats it for now. Hoping to have the TruTrac posi installed and the rear end put back together in the next few weeks. Will be going with 3.73 ratio most likely. Its going to be fun putting this stuff back together.
  22. stuart in mn
    stuart in mn
    Looks good! You're getting a lot accomplished in a short amount of time.
    An interesting swap is to use the front suspension from a 2004 or newer Crown Vic police car - it uses an aluminum crossmember that bolts in place, has modern suspension geometry, nice big brakes, and rack and pinion steering. Plus, it lowers the truck something like 5 inches. It's not quite a bolt in for the F-100 but it's pretty close. There's a huge thread about it here: http://www.ford-trucks.com/forums/716058-buildup-06-crown-vic-front-suspension-into-67-f100.html
  23. tschmitt
    tschmitt
    from IL
    Its a very good swap because it gives you everything you need for a great price as well. The next time I get another slick I will try that route for sure. Wanted to keep it simple this first time around.
  24. tschmitt
    tschmitt
    from IL
    Got some parts in this week. The Bronco II gas tank and my rear leaf spring bushings. Also got some pics of the coil springs and leaf springs painted.
  25. tschmitt
    tschmitt
    from IL
    My Eaton Detriot Truetrac arrived in the mail today. Should be dropping it off at the speed shop within the next week to have the gears installed, etc. Only thing left for the rear end will be new drums, axle bearings, and rebuild the brakes.
  26. menacekustoms
    menacekustoms
    What I want to know is, did you get rid of those awesome mini lamps in the interior?! If you didn't, and you want to get rid of them, send them to me!! Too cool. Love the DJM beams.
  27. tschmitt
    tschmitt
    from IL
    Lol the mini lamps broke in the process of removal, sorry lol.
  28. menacekustoms
    menacekustoms
    That ****s, they ruled!!
  29. tschmitt
    tschmitt
    from IL
    Got the center chunk complete. New everything, new axle bearings and seals as well. Got 3.73 gears installed, he told me it installed really tight so it should stay nice and solid for a long time. Just got to finish cleaning out the housing and press the seals in. Its been cold here in IL so I cant get outside to pressure wash the housing out again so gotta wait till it warms up. Its clean but I can get it cleaner if I spend some more time getting it spotless. The cleaner the better. Next on the agenda is to work on the drum brakes. Gotta replace everything in that area including the drums. I will take the drums and have them powdercoated once I get them. I cant wait to move on to something else on this truck lol.
  30. 66Newport
    66Newport
    Looking good man. What are the plans for body color?
