Hot Rods Who's building a Hot Rod to go drag racing? Let's see the pics!!!
Discussion in 'The Hokey Ass Message Board' started by HotRodChassis, Sep 20, 2008.
  1. 1arock
    1arock
    051.jpg [/ATTACH][/ATTACH]
    Here is my 38 IHC project race/street. 6-71 blown efi 468, ported dart heads comp hyd roller,transbrake t400,35 spline 9 inch spool. I hope to run in the low 5's in the 1/8. 1.625x.134 mild steel double frame rail ch***is kinda modeled after a friends pro mod frame.
  2. menacekustoms
    menacekustoms
    Dude, I love your car, and the concept. But, that roll cage is sketch man. There is no triangulation, and I would love to see that front kicker tube be straight rather than have a bend. Your execution on everything else is great, time to redo that cage to keep up with how fast that car's gonna be.
  3. gypsy
    gypsy
    from florida
    Here's mine, started as a street car, but will be raced and is a work in progress.
  4. Codeman
    Codeman
    from SE Mo
    Where in Swampeast Mo. might you be? I'd like to see this thing make a p***. Going to Sikeston?
  5. 1arock
    1arock
    Scott City. probly be 2011 before I try to make a spectical of myself at Sikeston Drag Strip
  6. 40chevythrowensparks
    this is my IH S100 with a 750-800 hp 427 that everyone calls mater like the truck from cars... i plan on runing it on the streets more or less a scare the **** out of your buddys truck....
    [​IMG][​IMG]
  7. Brahm
    Brahm
    ...sooo wanna vacation in mammoth and help me with my car ^_^ Man you build is inspirational. I'd like to do something similar with a spring behind, box frame, and the tires partially the body.
  8. swade41
    swade41
    from Buffalo,NY
    I'm still plugging away to get it out this year
  9. 5wcoupehunter
    5wcoupehunter
    from FLORIDA
  10. brandon
    brandon
    i wish...still beating the coupe, when the rain isn't occurring saturday nights:mad:
  11. SUSCRIBED, just became my ULTIMATE favorite HAMB thread, 2 thumbs up guys !!!!!!!!!!!!!!!!!!!!!
  12. usmc50lx
    usmc50lx
    from St.Louis
    I've caged mine, raised the front, redid the rear end, added more motor,more gear and a spool! At work at the moment will add pictures when I get home boys! BTW its the coupe in the avatar
  13. powhatan42
    powhatan42
    I'm building a '40 Plymouth Business Coupe..Here is the Ch***is build. Mustang II front end, four link read end with panard bar, sway bar, and an air suspension. 4.30 gears in a Ford 9' rear Detriot locker and Welwood discs. Stay tuned for my Street and Strip build. Full rollcage etc.
  14. swade41
    swade41
    from Buffalo,NY
    Well the truck got put on the back burner again to build this J, 388 sbc aluminum heads with old tr1x tunnel ram, hope to have it out this summer.
  15. usmc50lx
    usmc50lx
    from St.Louis
    Alright, heres pics as promised! took the car to 23" crankshaft centerline from 19"(just for looks). Added the cage using 6"x6" 1/4" plate and setup for my 4 point harness,swapped my 3.55s for 4.11s and a mini spool and added Strange c clip elims and revised my ladder bar brackets,added the full roller harland sharp 1.8 ratio rockers and a few other things to the motor, and moved the tach up to a lil more visible place! and then the final product!
  16. GasserTodd
    GasserTodd
    My bucket.
    Ran best of 10.2@132 with the old street 454. (hydraulic cam & TRW blower pistons) Car weighs about 2500 lbs with me in it so its no lightweight.
    Motor suffered a meltdown so got replaced with a 540 & I refitted the old 671. Have a 1071 in the shed but theres not room behind the blower for the mag, as its too close to the firewall.
    Once I have driven to the track, run a 9 in street trim and driven home without breaking anything, then I will have met my goals.
  17. captmullette
    captmullette
    still have a lot of the little things to do, got it apart now to change the stall from a 2500 to a 3500, hope its enough....
  18. Leadsled51
    Leadsled51
    Here is my 63 Falcon, picked it up this spring, and have a few things to do to it to get it legal, but this one won't be on the street
  19. captmullette
    captmullette
    nice looks like a good project, does it have a staight axel??
  20. Leadsled51
    Leadsled51
    yes, a straight axle...9" ford rear....4spd. I'm going to try and keep it as period correct as I can, once I get started on it!
  21. my entry
  22. a better side view
  23. Well maybe I fit in here!
    James D paint job
  24. Blown 61
    Blown 61
  25. Man im glad i saw this thread. New to the site and this is def my fav thread i've read. Im currently building the frame/suspension for my Model A coupe.
    Got alot of good ideas by looking at ya'll set ups.
    Great thread!!
  26. Mike VV
    Mike VV
    from SoCal
    Sorry, I haven't sat down long enough to learn how to post pictures.
    Here's an address to my 2dr. Lark wagon.
    http://public.fotki.com/-Mike-/60_lark/
    It's been sitting like this too long but I have to finish another car first.
    And as per the original request...it's currently licensed, registered and insured.
    I figured I didn't want any h***le putting all the legal things back together to be able to drive it.
    The only thing I havent figured out to make it "fully" street legal is the windshield wipers.
    The cage/ch***is is NHRA legal.
    Mike
  27. Isn't that turbo gonna turn the inside of you car into a sauna? Wiring, interior?
  28. TinShed
    TinShed
    That is exactly what I was thinking! Dam it will get hot in there!
  29. WILLYSDOCTOR
    WILLYSDOCTOR
    Here's my home built multi-year project.
  30. marcello7x
    marcello7x
    from Boston
    Mines a gl*** 33
    First frame design. X member was junk and being redone now. It was connected with the bolt in trans mount.
    First motor: chevy ls 5.3, new motor is at the machine shop, chevy ls 404 stroker[fuel injection, the very non hamb way, but should be in the 520+rwhp]
    The begining of the cage:
