Whats the difference 49-51 fords???
Discussion in 'The Hokey Ass Message Board' started by WhiteDevil, Jan 20, 2010.
  1. WhiteDevil
    WhiteDevil
    I did a search and couldnt really find much on the differences of 49, 50 and 51 ford shoeboxes. I know theres a sedan and a coupe and I know there is changes in the grilles. But what are the changes between the 3 yrs. THanks for the help in advance.....
  2. lothiandon1940
    lothiandon1940
    A**** other things, the 49-50 had exposed chrome trunk hinges. By '51 they were hidden inside the lid, looked a little cleaner. The coupe/ sedan thing has been covered here before. '51 was first yr. for an automatic.
  3. Easist way to tell is in the grill. There are other differences in the steering wheel, trunk hinges, etc. but the grill is the easiest way to tell a stock 49,50,51
    Grill on the 49 has no parking lights and has a center bullet with the half circle in the hood
    50 also has the center bullet and half circle, but also has chrome parking lights
    And the 51 is the only one without the center bullet and half circle. So no brainer on that one.
  4. madpole
    madpole
    exposed gas cap on '49. trunk hinges, grilles, tail lights on the '51 trunk handles are different.
  5. happy hoppy
    happy hoppy
    a 51 transmission will not fit in a 49-50. found that out the hard way.
    headlight rings changed in 51 also.
  6. 50Fraud
    50Fraud
  7. lothiandon1940
    lothiandon1940
    True hardtop, Victoria, appeared in '51, built from a convertible body to compete with Chevy's hardtop.
  8. Mudslinger
    Mudslinger
    Door handles on a 49 the whole handle pulls out instead of a push ****on. The strikers and door latches are different. Best way to tell a stripped 49 door from a 50-51 is the door handle hole is square instead of round.
    Trunk handles and license plate surround is different.
    Horn ****on, grill, trunk hinges, gas cap, bumpers have no outer braces. Some later models have the fifty outer brace. Hood ornament is different and the 51 was the first year with automatic trans so the 51 firewall has a larger opening for the trans.
    Also the center ring part of the grill is deeper on a 49 than the 50.
    Theres probably more once I start working on my 49 that will come to mind.
  9. pasadenahotrod
    pasadenahotrod
    from Texas
    The Aussies and Kiwis refer to 49-50 as single-spinners and 51 as twin spinners referencing the single bullet and dual bullets in the grilles.
    49-50 have the cat's eye taillamps which bulge slightly to the outside of the quarter panel with a tapered bulge in the quarter running forward.
    51 has a chrome-spear running forward from the wider taillamp housing covering the bulge in the quarter. The taillamp lens is plastic, wider and thicker than the 49-50 gl*** ones, and has a pointed cone stocking out at each end.
  10. holeshot
    holeshot
    from Waxahachie
    DEVIL...also the dash and taillights are different in the 51 ford...POP.
  11. hotrod1940
    hotrod1940
    49 has the letters FORD just above the spinner. 50 has the Ford medallion just above the spinner.
  12. Stefan T
    Stefan T
    from Sweden
    49 and 51 have diffrent floor than 51 have
    the hood hinges on 49 is not same as 50 and 51
    51 have diffrent rear springs
  13. RodStRace
    RodStRace
    Saw this a while back and grabbed it. Sorry I can't give credit...
  14. WhiteDevil
    WhiteDevil
    Thanks so much....the hamb is like instant information no matter the question. Is any of the 3 years "better" to make a custom or is it all preference??? Didnt know if any were the "duckling"
  15. Hell no. All of them look great as kustoms. However even though I love my 50 I would prefer a 51. Nose end just looks so much better to me on those. Just personal preference
  16. The Hank
    The Hank
    from CO
  17. chop32
    chop32
    The '49 does have parking lites...they are arrow head shaped and at the ends of the grille bar,
    while the '50 parking lites have stainless (or chrome) surrounds that wrap around the fronts of the fenders.
    '49 trunk hinges are more of a pointed art deco style, while the '50's are boxier in shape.
  18. WhiteDevil
    WhiteDevil
    I said 3 years in regards to the 49 50 or 51...
  19. lothiandon1940
    lothiandon1940
    I can't believe nobody took this opportunity to post up some pictures of their '49, '50 or '51...you know, just for reference.:)
  20. 50 differences between the 49 and 50 and probably that many changes between the 50 and 51. All the important **** like hinges, latches, etc were constantly changing. Bumper irons were different from year to year as well as bumpers. The best mechanically was the 51 as they had 3 years to get the car right. It also had hidden trunk hinges. Not the prettiest front end in my book, but the one I would use to build a shoebox on. A 49-50 nose will bolt rite on. I am not a big fan of the dash in the 51 but again a 49 or 50 will bolt rite in. I used a 51 Ford coupe as a starting platform and put a 50 Meteor nose on it and 50 bumpers and a 49 dash. Pat.
  21. thesupersized
    thesupersized
    just curious, could you see pluto with the side mirror???? ;)
  22. chop32
    chop32
    Here is my '49 Coupe...with '51 bumpers, grille opening and hood...the only parts left that are visibly from a '49 are the trunk hinges
  23. 50Fraud
    50Fraud
    Well, OK, here's my bitsa: it's a '51 Victoria, but with all the trim (grille, headlights, tailllights, side trim, deck handle, bumpers, dash) from a '50, 'cause I like them better. So it's a fake '50 -- except for a '49 hood ornament and dash knobs.
  24. eaglebeak
    eaglebeak
    '49 and '50 had a push ****on to start.
    '51 had the start in the key switch.
    Go to http://www.carnut.com/ and see the differences.
    50FRAUD has the nicest one in the world.
  25. Fenders
    Fenders
    Here's a nice tail light treatment I saw at Pomona........
  26. chop32
    chop32
    50FRAUD,
    I was all over your car at the West Coast Nationals (I think) a few years ago. While I knew that Ford only made a Vicky in this body style in 1951, you still had me second guessing myself, thinking Canadian or?? Then, on my 2nd or 3rd trip back to the car, I read the license plate!
    Beautiful job!
  27. 50Fraud
    50Fraud
