Staying 6v but want an alt.
Discussion in 'The Hokey Ass Message Board' started by Reverend_Jack, Jan 20, 2010.
  1. Reverend_Jack
    Reverend_Jack
    So I've replaced the genny in my 53 merc flathead about 5 times since I've had it and this put me in the mood to convert to 12 volt. But I think I may be changing my mind slowly but surely on the conversion.
    The question is does anyone know where I could pick up a 6 volt alternator that looks like a generator? The powergen's come to mind but I'm pretty sure they are strictly 12v.
    Thanks
    Jack
  2. pasadenahotrod
    pasadenahotrod
    from Texas
    Why have you had to replace the generator 5 times and how long have you owned the car?
  3. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    If your going to go so far as to use an alternetor, ya might as well go all the way and run 12volts.
  4. Reverend_Jack
    Reverend_Jack
    I've had the car for 6 years.
    And had to replace the generator for a whole host of different reasons.
    First time the armature needed replaced. I had it rebuilt and the rebuilder painted my case and got paint on the brushes. So that was the second replacement.
    The third time the Mallory dual point did something I couldn't really understand (I'm not an electrician by any means) and fried the battery and the generator so I had to have it replaced again.
    Then this last time was the bearings going bad and it wasn't spinning. So I guess I've only worked it over 4 times not 5.
    I just bought a new battery and the whole set up seems to be running like a top now but I've got this feeling it's only gonna run great for a little longer before something else ****s out.
  5. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    Maybe buy good stuff and rebuild it yourself?
  6. pasadenahotrod
    pasadenahotrod
    from Texas
    Was your generator replaced with another one or did you 4 times rebuild the same one? A lost cause for sure.
    I'd find another generator and have it done right...turned and tested armature or new one, new field coils, new brushes, new bearings/bushings.
  7. holeshot
    holeshot
    from Waxahachie
    JACK...theres a good reason folk's change over to 12 volts. it's time my brother, you won't regret it!...POP.
  8. UA_HoBo
    UA_HoBo
    from Oswego NY
    12 volts its a bit of work at first but you will reap the benifits
  9. CheapCat
    CheapCat
    from Illinois
    Going to 12 volt would be a good move either with a generator or alternator. The problems that you have stated could have also happen with a alternator too. Rebuilds are only as good as the rebuilder and it sounds like you do not have a good one.
  10. 12v conversion isn't hard at all.. just need to change all the bulbs out and put a voltage reducer for the gauges. most 6v starters will work on 12v
  11. Shaggy
    Shaggy
    from Sultan, WA
    What about tractor alternators?? arent they 8v??
  12. 55 dude
    55 dude
    google 6v alternator and you will find out they build them.
  13. ventilo
    ventilo
    powermaster?
    i know some people had issues with them, but my 6V alternator works just fine
  14. 4dFord/SC
    4dFord/SC
    I believe PowerGen makes 6v and 12v alternators. Another option is Ed Whitney in Buena Park, CA, (714-773-1611); he converts Ford generators to alternators to retain the original look. I've had one of his 6v conversions in my flathead for 5 years, and it works great. Whitney's alternators put out about 40 amps, while the PowerGen is good for 60-75.
  15. wvenfield
    wvenfield
    I had a 6 volt alternator on my 54 Chevy. It wasn't made to look like a generator though.
    There was absolutely no reason to switch the car over to 12 volt other than I couldn't directly run a modern stereo (which I didn't care about) and I'd run the brights on at night. (nobody noticed).
    I understand wanting to keep the looks of a generator but unless you want a modern car, 6 volts work just fine in a proper set up.
  16. RAY With
    RAY With
    Macs antiques Auto has 6 volt altenators with + or - grounds. You select what you want it to be to match your application.I would opt for the 12 volt conversion for the long haul.
  17. trmel3
    trmel3
    from new jersey
    do an 8 volt conversion jack up the regulater an get 8 volt battery dont have to change gauges an it will start like a 12 volt would
  18. FatFndr
    FatFndr
  19. Reverend_Jack
    Reverend_Jack
    Hey thanks everybody!
  20. 61falcon
    61falcon
    +1 on the macs antiques
  21. thesupersized
    thesupersized
    Easier start ups especially in the winter is a pretty good reason for 12 volt for me...
    I'm not sure if you're against switching to 12 volt, but i that's how i understand your post...what is your reasoning for staying with 6 volt?
    to the guy that made this post...If I were you I would get the stock generator converted to 12V. I believe there is a small oil fill thing on your generator...did you maintain your previous generator?
