Ford 1926 / 1927 Roadster differences?
Discussion in 'The Hokey Ass Message Board' started by 13, Jan 13, 2010.
  1. 13
    13
    from Sultan, WA
    Can anyone tell me the specific differences between the 26 & 27 Ford Roadster?
  2. Shaggy
    Shaggy
    from Sultan, WA
    Door sills and the only deffinitive i know, i've heard a little bit of the stamping on the doors before, but cant get a good answer
  3. waldo39
    waldo39
    from Illinois
    '26 has a square raised plug in the rear end; '27 has square recessed. There is a small difference in the A pillar at the top hinge. New deck lids are available several places.
  4. flamed34
    flamed34
    Any good suppliers of sheet metal for 26/27 roadsters? I have a nice complete roadster body that I bought a few years ago ($207.50 at auction with a full truck load of Model A parts!) but it's in need of a couple of patches (like around around the top of the seating area, sub-frame rails). I haven't started the build yet...just collecting parts...
    Wish I had had a bunch of cash at that auction...'35 Ford 5 window sold for $800 (solid overall, but needed lower body patched), '36 Ford 3 window ($1200 - very straight solid car), restored '30 roadster for $5500, PILES of model A thru '36 fenders (talking @ 10 fenders in a pile) for $5....list goes on and on!
  5. oldebob
    oldebob
    from Spokane WA
    Main difference in the bodys is that the lower piece of the rear quarter is long on a '26 and extends way back. On a '27 it only extends back about 4 inches to a separate filler piece.
  6. The37Kid
    The37Kid
    Lots of differances! Early and late cowls, windsheild posts, doors, two different turtle decks, full floor and no floor, side curtain rod holes in doors are the ones that come to mind. Rear crossmember on the ch***is differ, and the running board Ford script is large and small. Yes, I like 26-27 Fords.
  7. rust
    rust
    ford didnt really like the whole model year thing back the , constant running changes, bottom o windshield post, doors , cowl, etc.
  8. Halfdone
    Halfdone
    Learn something new everytime I drop in here. Anyone got any photos of that?
  9. Heo
    Heo
    The headligt bar on 27 .26 have no bar
    think 3 ore 4 diferent bars on 27 dont remember
    all things that differ my father has a 27 roadster
    thats made the last month they made model t
    differ a lot from earlier 27
    but most things you most realy know whats
    you are locking fore
    On a hotrod the dont make any differens
  10. El Hueso
    El Hueso
    I'd like to echo what flamed34 asked; What suppliers are there out there for 26/27 roadsters with patch panels, door skins, etc?
  11. Shaggy
    Shaggy
    from Sultan, WA
    I just got done replacing the panel below my decklid, it was an 1/8 wider than the factory panel above the lid, which was something like a bit over 1/16 wider than it shoulda been compared to my decklid structure. So it all adds up to the panel below the decklid is close to 1/4" wider than is should be compaired to my decklid, but as i said even my factory stuff was off
    So i guess for me i'm gunna streach my decklid to match when i reskin it
  12. bloodsweat&gears
    bloodsweat&gears
  13. OFT
    OFT
  14. hotrodA
    hotrodA
    BAAAAAD experience with this joker.:mad: Would ONLY buy from him if I saw the parts in my hand first. Deceiving EVEN with pictures. Not sure that I even got what he promised. Rough cut out with a torch, and as bad as what I was replacing. Plus, forever to ship. Caveat emptor:mad:
  15. twofosho
    twofosho
    I'll bite, where?
    While we're at it, is there really a decent patch panel supplier out there you can trust? One with parts that fit close enough you can tweak them to make them work instead of remanufacturing them, or tossing them and making your own up from scratch? One who will deliver when THEY say they will?
  16. hmuchler
    hmuchler
    My car is some kind of a model T. I was told 27. The bondo came off the door with the help of power tools and I have these holes above the door latch and handle. Right where a modern push lock ****on would be. What is it for?
  17. JohnEvans
    JohnEvans
    from Phoenix AZ
    Hmuchler : Those holes are for sidecurtain mounts.
  18. Tall Tom
    Tall Tom
    from Austin MN
    For patch panels check out www.mowercountycustoms.com
    John is a member here, I believe his handle is mcc7
    He can build anything you want.
  19. -Brent-
    -Brent-
    Hmmm.... that guy has RULED for me.
  20. Dean Lowe
    Dean Lowe
    Probably not important here, but '27 spindles are different. They lower the front axle 1" and are sought after for speedsters.
  21. The37Kid
    The37Kid
    The 1926-27 T's had a large rear brake drum, and are good to use on T speedsters too. Very early Midget Race cars used these drums with 12' rimsc welded to them to make wheels. That 6 bolt hub pattern that ford used on the wood wheels became the standars in Midget racing for many years.
  22. RussTee
    RussTee
    early 26 even had kero side lights
  23. BELLM
    BELLM
    Door latches are different
  24. I'm trusting memory here, but didn't Ford add front brakes in '27? Knowing Ford, it probably didn't coincide with a model year change, probably a running change somewhere in late '26 or early '27.
  25. youngster
    youngster
    from Minnesota
    You are going to find most all of the replacement and patch panels come from Howell's.
    Trying to sort out the variations in the two years has driven more that on person to drinking. Henry was known to make changes at the drop of a hat. That continued till Edsel took command of the company.
    Ron
  26. Angry Frenchman
    Angry Frenchman
    A couple of guys said door jams, you can't loose. When I'm looking at A rusty pos hulk, I go by the door jam. 26 are screwed in, 27 are rivited.
    whtbaron likes this.
  27. hmuchler
    hmuchler
    Side curtains, have you a link to a photo or a picture of a side curtian. Rains 6 months a year here. Ok more like 7.5. I want some kind of splash / rain windows. Can anyone help with a photo or a link.
  28. opu27
    opu27
    from ONYX,CALIF
    you can use outer 26/27 door skins to make inside door panels. they have the same compound shape. you can put 4 2" holes in the center. you at least have something to work with. think about it. ****
