Bones vs Hairpins, need help
Discussion in 'The Hokey Ass Message Board' started by no6, Jan 25, 2010.
  1. I figured if I asked the question on here I would get straight answers one way or the other and since I am building a traditional rod here is the place to ask. I started with A bones and was going to drill them and use cowl steering. The placement of the sprint unit and the fact that this car is for the ole lady I decided against the sprint unit mainly because of the quick steer. I then purchased hairpins and still wanted to go side steer so on here I found info on a chrysler box and installed that more centrally on the cowl. Now I can get the bones to work out with the pitman arm. Here is my dilema, I can cut 4" off the ends of the hair pins and rethread them or build another bone and have them plated, expensive and time consuming. I'm not rich but I will save up to build the car right and labor is free. I don't know what to do what do you guys think? If I go the A bones I will be selling the hairpins and batwings.
  2. krylon32
    krylon32
    from Nebraska
    I would probably shorten the hairpins so the rear pivot point is in line with the pitman arm. I would keep the draglink in a horizontal line with the hairpins. The hairpins would work as is but maybe a little better in line plus look better.
  3. buker60
    buker60
    from NYC
    i'm a big fan of hairpins usually. But I have to tell you, those bones look sick! I think you should go with the bones. my 2 cents
  4. Is this site slow or is it my putor?
  5. HBCbackwoodsbrawler
    HBCbackwoodsbrawler
  6. Nobodys Hero
    Nobodys Hero
    from New Jersey
    Im not a huge fan of hairpins, and I dig the way the A bones look...Id make them work. Reminds me a bit of my coupe
  7. wallygator
    wallygator
    Bones all the way.
  8. grits
    grits
    It's the site, it took damn near 1 minute to enlarge the thumbnail pic.
    I know the boss is probably pulling his hair out trying to fix it.
  9. krylon32
    krylon32
    from Nebraska
    There's hairpins and then there are hairpins!
  10. LSGUN
    LSGUN
    from TX
    Bones forsure, they have a much more cleaner look being so subtle.
  11. 325w
    325w
    Built my car in the early 90's. 4 bars were the way. If I was not so beat up i might try to uninstall the 4 bar. I like the split bone. But the bracket seems low to my eye. $00.02
  12. 3wLarry
    3wLarry
    from Owasso, Ok
    I'm sorry, but those hairpins don't work on your car...bones are cleaner...much better....my opinion.
    kidcampbell71 likes this.
  13. plymouth1952
    plymouth1952
    bone all the way
  14. Actually to get the 7 degrees they will be mounted on the frame. Keep them comming, bones are winning.
  15. Beano
    Beano
    from Pa.
    I would go with the bones . I think you're just showing off how much room you have to work .:)
  16. BISHOP
    BISHOP
    I think the bones look better.
  17. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Hairpins....and btw....thats a sick ride coming together!
  18. Another vote for the bones.
  19. krylon32
    krylon32
    from Nebraska
    In my comment he simply asked what to do. I gave him my thoughts. Not to cause hurt feelings but I to would pitch those hairpins and get a set with a little finesse, or go to bones.
  20. kirby1374
    kirby1374
  21. bobscogin
    bobscogin
    Hairpins -- but saw off the part of the rear threaded boss that projects forward in front of the bends.
    Bob
  22. A Chopped Coupe
    A Chopped Coupe
    I have always like hairpins, but the split bones you have really make the car look a heck of a lot better than the hairpins. Besides, the hairpins are too long by almost 8/10", they should be right at the cowl line as it meats the frame. If you wold only take a couple of inches off the hairpins you would need to put a brace on the hairpins. Are those hairpins over 36" long, they just look way to long on your car.........................another vote for bones!
  23. 2deuces64
    2deuces64
    Those hair pins look out of place on your car. I vote for the bones!!!
  24. 117harv
    117harv
    Bones all the way, especially drilled!
  25. fast30coupe
    fast30coupe
    from Illinois
    if i could build my car over again i would go with the hairpins, but its your car so you know what is best
  26. NOTCH
    NOTCH
    My vote is for the bones!
  27. jj mack
    jj mack
    Bones all the way, but have you thought about the drop from the pitman arm to the steering arm?
    Not sure its problem...but the bone and drag link wont be parallel.
    Any geometry experts out there?
    jj
  28. Countn'Carbs
    Countn'Carbs
    from CO
    bones...great looking car.
  29. goonz55
    goonz55
    from Yuba City
    Bones! Hair pins are like altenators, they work good, but who wants to see an alterator on an nastalgic engine. Just my opinion, great job the car looks *****in
