Projects So my wife made me go to a garage sale...
Discussion in 'The Hokey Ass Message Board' started by butterboy, Jan 26, 2010.
  1. butterboy
    butterboy
    We were looking at baby clothes in some womens garage, Just what I wanted to do on a Saturday morning right? Well then I spotted a chevy small block and crank..So I asked whats with the block? It's my husbands, he used to be into racing. Long story short I soon headed home to get my truck to load the block and crank up.. Turns out he was planing on building a motor for his chevelle but life got in the way so it sat. Thats where I come in. 80 bucks later I got a fresh block and reground crank. So my question to you guys is did I score a chevy 302 block? Thanks guy!!
  2. Little Wing
    Little Wing
    from Northeast
    ya need more info,,that block was several different sbcs more than likely a 327
  3. bje31
    bje31
    from Western PA
    maybe:
    <TABLE border=0 width="100%"><TBODY><TR><TD>1968-69</TD><TD>3955618</TD><TD>327</TD><TD>-</TD><TD>-</TD><TD>4</TD><TD>A,F,Vette</TD></TR><TR><TD>1969</TD><TD>3956618</TD><TD>302</TD><TD>290</TD><TD>290</TD><TD>4</TD><TD>Z28</TD></TR><TR><TD>1969</TD><TD>3956618</TD><TD>327</TD><TD>235</TD><TD>235</TD><TD>2</TD><TD>fullsize</TD></TR><TR><TD>1969</TD><TD>3956618</TD></TR></TBODY></TABLE>
  4. revkev6
    revkev6
    from ma
    what are the numbers stamped on the deck?? that block is 327,302,350 by the casting numbers
  5. Von Rigg Fink
    Von Rigg Fink
    from Garage
    agree..these are the numbers that count
    on the pad infront of the p***enger side cyl. head
  6. brett4christ
    brett4christ
    Or you can get the casting # off the crank.....I know they may not be a factory pair, but you never know!?!?!?!
  7. tigerShark
    tigerShark
    from Tampa Bay
    what about the crank?
    3279 302 68-69 Z28, CAMARO FORGED. LARGE JOURNAL, HI PERF
  8. butterboy
    butterboy
    I will look tonight. what numbers am I looking for on the front deck?
    So it could be a 302 327 or 350..Cool Im happy either way. So let me ask:
    Why is a 302 so desirable?
  9. brett4christ
    brett4christ
    Only if you are building a 67-69 Z-28. Otherwise, it's just a cool engine to claim ownership of.
  10. revkev6
    revkev6
    from ma
    well, if it's a 4bolt main block, it's going to be a 302 or 350. those casting numbers list 327 as a two bolt block.
    the "302" block is only special for the number stamped on it. otherwise it's the same as any other good 350 block. 4" bore, large journal, 4 bolt main.
  11. revkev6
    revkev6
    from ma
    that block would only have been used in the later 302 with the large journal, not the earlier small journal block. I forget what year they changed, if it was 68 or 69 only that had the large journal 302
  12. nutajunka
    nutajunka
    4 inch bore with a 3 inch stroke = a high winding smallblock...;)
  13. butterboy
    butterboy
    It is a four bolt main!! Sorry I forgot to say that.
  14. nutajunka
    nutajunka
    Calm down or you might melt yourself ****erboy...:D
  15. holeshot
    holeshot
    from Waxahachie
    ****ERBOY...you wife made you go! HERE KITTY, KITTY, KITTY! HA!...POP.
  16. Ebbsspeed
    Ebbsspeed
    And if it does turn out to be an OEM 302 stamped block, in your shoes I'd sell it to some **** Camaro restoration guy for beaucoup bucks, then you'd have plenty of cash to buy a lot more than just a block and crank. Unless the cool factor of the 302 is worth something to you.
  17. butterboy
    butterboy
    Whats the special number?
    The crank is a standard 350 crank from summit racing..the guy said something about making a 337? or 338? sorry can't remember. With a 302 block and 350 crank?? Does that make sence? So you would need to get the revs up to make power right..
  18. revkev6
    revkev6
    from ma
    agreed. they bring stupid money just for a number....
  19. el Scotto
    el Scotto
    from Tracy, CA
  20. revkev6
    revkev6
    from ma
    it's the "numbers matching" bs that the judges at shows look for.
    that block had a 4" bore stock. with a 3.48" stroke 350 crank you will get
    tada! a 350! a 327 is 4" bore with 3.25 stroke, and a 302 is a 4" bore with a 3" stroke. sure he didn't say a 383?? which is a 400 crank in a 350?
  21. nutajunka
    nutajunka
    Remember, if that block has been decked the numbers could be lost forever...:eek:
  22. MilesM
    MilesM
    DZ suffix for 69 I beleive.
  23. strawberry
    strawberry
    350 block + 400 crank = what? 383? or am I just getting old, heck like the other post said if its a 302 sell it and buy a complete crate big block he he he
  24. Check the casting date on the other side of the block; same location as the casting number.
  25. butterboy
    butterboy
    Not a 383. Thats what I was thinking to. I ran the numbers on the crank its a 350 crank...so what is stupid money? What is a 302 block selling for to the z28 crowd?
    If its a 350 still a good score for the ol' coupe.
    I will take a picture of the front pad when I get home ..Thanks
  26. That will depend on the casting date, IF it turns out to be a DZ/302. '69 versions bring something less than a '68 because they made so many of them, but a '67 casting is the most desirable ......... for the Z gurus.
    And BTW, ...... just because it isn't stamped DZ doesn't mean it's not a 302.
  27. revkev6
    revkev6
    from ma
    like miles said, if the front pad ends in "DZ" it's a 69 z28 engine.
    otherwise, yes it's a good core block. Did you ask if he had the rest of it lying around too??:D
  28. revkev6
    revkev6
    from ma
    from what i've read, 67's were small journal 2 bolt main, 68's were large journal 2 bolt main and 69's were large journal 4 bolt mains. If this IS a 302, from what he's said it could only be a 69. Chances are MUCH higher that it was the stock engine out of his chevelle. the front pad will have a partial vin that will tell you what it came in.
  29. 61TBird
    61TBird
    IF,and that's a big IF,it's a 302....
    On the Front pad(front of block on p*** side) it will be stamped MO for '67-'68 or DZ for '69 Z28 302.
  30. Little Wing
    Little Wing
    from Northeast
    Seems you should already know from your first post,,Z-28 Motor
