Quest for a KY Title..Any Help, loop holes.
Discussion in 'The Hokey Ass Message Board' started by lrs30, Jul 22, 2007.
  1. lrs30
    lrs30
    from Kentucky
    Looking for a help on getting two titles..1. 1929 Model A sport coupe, no numbers any where to be found on the body, would settle for builders title/special construction, just wanna get the ball rolling, DMV not much help. Next is for my Alterd Chopped 48 Ford F-1 with vin-tag still attached and readable, whats the 1st step, maybe have the DMV do a title search, or is that a bad idea...PLease HElP
  2. Sam F.
    Sam F.
    on the vehicle with a VIN #,,,first check to make sure vehicle is not in system by the VIN#,,,if its not,,then you can apply for a title,,you must get and afidavit signed by you and your neighbors (as a witness) saying that you have owned the vehicle for atleast 5 years,,,,
  3. your next question should be since the 48' has #'s ask the question "where are the numbers on the frame of a 29' model A".
  4. lrs30
    lrs30
    from Kentucky
    On the F-1 All I have is the cab its going on a Frame I'm building, on the 29 no numbers anywhere body or the frame, they each came from seperate places.
  5. lrs30
    lrs30
    from Kentucky
    Thanks for the info on the truck Vin search, I bought from a recycling place in KY. So hard telling where it came from....
  6. wingedexpress
    wingedexpress
    I bought my 29 model a from a guy in lexington he stamped the numbers from the title on a brass tag and put it on the firewall they accepted it with no fuss.If you can get a title it's worth a try, on a vehicle that old it should not be hard to get a new title made . good luck
  7. the-rodster
    the-rodster
    This works, I've done it twice in the last two years. First with a model A and no VIN, second with a motorcyle.
    I just made up a VIN - starting with A and my daughters birthdates, checked with the clerk to make sure it wasn't in the system, had it engraved at the local trophy shop on a tag, and riveted it to the firewall.
  8. lrs30
    lrs30
    from Kentucky
    No kidding, interesting.
  9. lrs30
    lrs30
    from Kentucky
    Thats a good idea, but I have to find a title first for that to work, and that is where the trouble begins.
  10. georgep
    georgep
    I bought a title, hand stamped a metal tag, went to the sherif's office and no problems. They did not check a thing except for the tag on the firewall. The vehicle was a 39 ford truck cab on a 2x4 frame no hood or fenders and all that was said was "nice truck" Most questions at the c. clerk ended when I said I wanted h. plates
  11. Model A serial numbers were on the frame. But often they got registered using the engine number. Just get a title and put a tag on it with the same number -
  12. Rotobo
    Rotobo
    The A number is on the frame under the drivers side cowl. It's near impossible to read without taking the body off the frame. There may be a easier way to read it but I'm not aware of any. They had no number on the body. I was told this by a Model A addict and he knows his stuff. I have two frames and was looking up on the front in the area of a later Ford 37 etc. but both were back right where he said to look.
