Model A sedan behind the seat gas tank/out side gas cap ideas??
Discussion in 'The Hokey Ass Message Board' started by KCCOS, Nov 30, 2009.
  1. KCCOS
    KCCOS
    from KC
    I am putting my gas tank behind my rear seat in my tudor sedan and I am looking for some ideas for the fill neck and and gas cap on the out side of the car. I have a few ideas myself but would like to hear our see what you guys got. Pics would be great.
  2. 40Standard
    40Standard
    from Indy
    I don't think there is a good looking place unless you run saddle tanks under the running boards on a Model A sedan
  3. Von Rigg Fink
    Von Rigg Fink
    from Garage
    Im looking at Monza filler caps..Norton MC caps, and the like..
    the pop top style caps..but not the huge ones like on the Mustrags.or i ment rustangs
    like this
      47.2 KB
  4. Von Rigg Fink
    Von Rigg Fink
    from Garage
    those things are an abortion
    and the cap placement is also a major eye sore
  5. bigbal
    bigbal
    I don't like the idea of the tank hanging back there like a Pinto either but I am building a 29 2 door highboy on bobbed 32 rails and this is what I am going to do. By buliding a tank that goes almost all the way across between the subrails, under the base of the back seat and making it about 1 inch taller than the seat riser I think I can get about a 15 gallon tank. The bottom of the tank will be exposed to the road underneath and I will seal the p***enger compartment with plywood. For the filler, it will run upward to just under the beltline to a sheet metal box with one of the gas caps with the flip open hloe to stick in the gas nozzle. That box will be small enough to be covered by a flip down license plate holder. Sorry no photos as this is all still in my little brain. Just remember when building a tank 1 cubic foot equals 7.5 gallons liquid.
  6. KCCOS
    KCCOS
    from KC
    For the night crew
  7. fine29
    fine29
    from Des Moines
    We ran the filler neck out the side of the one I done and it just didnt look right so I filled it back in and just fill from inside the car now with a plastic gas jug.
  8. What about behind a taillight or license plate.
    Filling it with a jug has got to be a PITA
  9. josh77
    josh77
    Nice and simple, that was my plan, thanks for the pics.
  10. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    I'm planning to do an undercar tank, over the rear axle. Thought I'd mount one taillight on a gas door, hinge at 12:00. magnetic catch. Modify the door slightly smaller than the light, no one would know.
    May have to mount the lights a little on the high side, but not too bad. At least, thats the plan.
  11. landseaandair
    landseaandair
    from phoenix
    I plan on using a filler and grommet from a pickup truck through the body on my Vicky, high on one side. Cheap, simple and it should fit the early 60s look I'm going for.
  12. Probesport
    Probesport
    I am just going to make a cap that will act as an extension tube and you can just put it on to fill through the back window, take it of then replace it with the regular cap.
  13. Chevguy37
    Chevguy37
    I used a tank out of a Honda Civic and the gas door too. Neat installation and the gas door blends.
  14. dirtcop
    dirtcop
    I used a boat filler cap. It is close to the body, has a chain for the cap, and screws on very easily. The only down side is I should have looped the vent line higher so gas wouldn't pour out if I fill into filler pipe too high. Cap could be painted to blend in better.
  15. caseys_customs
    caseys_customs
    that looks silly on the green model a
  16. HATED1
    HATED1
    the car isn't my favorite but i do like the gas cap for some reason.
  17. edljames
    edljames
    from OK
    Here is mine with a magnetic door and push thru gas cap.
  18. chevy3755
    chevy3755
    sorry I dont have a pic.... but mine is on the drivers side......I used a older VW door flap.....molded it into the body.........turned it up side down....flap opens towards the back of the car.......used a tank out of a late 40's chevy truck .....turned filler tube towards the drivers side.....hope this helps ya......Larry
  19. KCCOS
    KCCOS
    from KC
    any more ideas?
  20. stillkruzn
    stillkruzn
    from Conway, AR
    Here is an old build pic of mine... I am running the '32 tank out back... beats having the gas inside the car...
  21. KCCOS
    KCCOS
    from KC
    any more ideas?
  22. Von Rigg Fink
    Von Rigg Fink
    from Garage
    I decided since i was going Full fender..I got a 32 tank out back..fits nice, looks right imo
  23. 29 sedanman
    29 sedanman
    from Indy
    Here is mine. Tank behind the seat with a kris kraft boat filler neck. Make sure you have plenty of fall from the filler to the tank or it will be a pain in the *** to fill.
  24. lowelife
    lowelife
    I bought the 15 gallon universal from "gas tanks" that says it fits behind the seat. Welded brakets to each side and mounted it to the frame angled to match the sweep of the back of the car. Then made a rear fire wall with a removable center section to access tank, lights and battery. Only had to give up about 5" of room overall.
  25. i,ve put the gas tanks in two model A tudors in between the frame rails and used a chevy van filler located just under the rear window to fill both tanks . didn,t like the idea of gas tanks hanging off the rear or just behind back seat in case of a rear ender. works well . can send photo,s if interested. craig
  26. motoandy
    motoandy
    from MB, SC
    I went the same route but mine is in the other side, but same height. I used a 67 Chevy truck filler neck and running a 17 gallon aluminum tank from Summit.
  27. blt2go
    blt2go
    i've been toying with the saddle tank mounted on one frame rail. (maybe both) also been thinking about the problem of filling. has anyone successfully tied in to the original cowl filler after removing the tank bottom? i was thinking i could run a filler tube down the p***enger side kickpanel and out the floor to the tank. i've been thinking it would work good but now seeing it in print it sounds like a pain.
  28. 41 C28
    41 C28
    I have always though if I ever built an A sedan that I would build a tank and use it as a seat riser for the back seat bottom cushion. That way the tank would have a little protection.
  29. 57tailgater
    57tailgater
    from Georgia
    Flip tops are very cool, but I'm not too interested in the generic boat ones that have "GAS" cast into them although the can be had brand new for around $25. The Monza ones are neat too. I scored a smaller flip top on ebay, similar to the Moon ones that's going on my truck. Older Triumphs and 60's Chargers had flip tops one as well. The clean older truck round ones look clean. You could even take one of these rounds ones and put an older Ford tractor radiator cap (below) on it too. :cool:
  30. 29 sedanman
    29 sedanman
    from Indy
    Thats a neeat cap Tailgater, I agree the generic boat ones are funny looking with "GAS" cast into them. The Kris Kraft ones are a lot cleaner looking. The cap is large enough that the edge of the cap covers the flange so you see nothing buth the cap, and there is nothing cast into it. Not sure if still available but I think Repops can still be found on Ebay in two different diamaeters.
