Incredible welds
Discussion in 'The Hokey Ass Message Board' started by rusty f100, Oct 6, 2008.
  1. D-fens
    D-fens
    from Huntsville
    Not sure how to ask this question and make it understandable but here goes.
    My welds seem to come out a little nicer using the 2% thoriated tungsten we have at my work (using an old Syncro 250) than when I'm welding at school using 2% ceriated tungsten on a new Dynasty 350 machine at school.
    Is it the different tungsten, or the machine? WTF. :confused:
  2. Johnny99
    Johnny99
    This may sound a little funny, I like to have some music going while walking the cup, its a rhythm thing.
    John
  3. onlychevrolets
    onlychevrolets
    you see that GOLD weld. Thats a near perfect weld, I mean the temperature is just right, to hot turns it dark gray. thats as pretty as it gets.
    simpsonrl likes this.
  4. jdustu
    jdustu
    from Detroit
    It could be the machine settings, it could be the tungsten brand, but my guess is that it's the gas. Occasionally you'll get a bad bottle, or one that's not as "pure" as another, or perhaps there is an air leak.
  5. aaggie
    aaggie
    Welding is an artform but there are some simple rules that you have to follow.
    Buy the best machine you can afford.
    All parts must be squeaky clean.
    Fit the joints tight, you can't weld big air gaps.
    Practice, practice, practice.
  6. scootermcrad
    scootermcrad
    This is one of the most inspirational threads of all time! I love welding and I strive to learn more and this thread seriously shows some beautiful stuff to strive for!
    Thanks to all that have shared!
  7. themachine
    themachine
  8. Wow, some (most) incredible welds here, i can weld alright, but as someone said before, i´m better at grinding.
    Does someone have any good pics of hammerwelds? i have seen a guy here in Sweden that does it so good that you didn't see the weld at all!
    Some pics here belong in the Friday art posts!
  9. 067chevy
    067chevy
    We used to do that back in the 80's. Not easy to do. Don't have a tig so haven't tried it in a few years.
  10. exStreamliner
    exStreamliner
  11. Kevinsrodshop
    Kevinsrodshop
    My guess is that because one is transformer (sychrowave 250) whereas the other is inverter (Dynasty 350). High frequency I think makes the difference but I'm no expert.
  12. jdustu
    jdustu
    from Detroit
    His welds should come out similar whether it's on an inverter or a transformer, especially if he's welding steel. The inverter can make it easier to lay some nice beads on aluminum, but you aren't gonna find anyone that can tell the difference between an inverter weld and a transformer weld.
    FYI the welds in post 356 were done with a Synchrowave 350, the welds in post 341 were done with a Dynasty 200.
  13. Can i see some Oxy Acetylene Welds i know there's some guys that can put down a bead like it's tig. If theres another thread i apologize and if you could point me in that direction. I searched and came up with nothing. Thanks Frank
  14. LPRS
    LPRS
    this thread has been gone way too long. how about some tig on a kustom aluminum intercooler?
  15. Man- that's sweet. If you gotta paint it, work a silver stripe into the design to keep it visible.
  16. paco
    paco
    from Atlanta
    Nothing like working with clean aluminum - nice job.
    PACO
  17. tee joint
    tee joint
    i teach at a welding school here in western ohio...welds look really good. taught tig now for 21years. the welds to me look like ther were done with a pulser box built into machine ,what it does is goes to a high amperage then the puddle cools and you step ahead a half puddle.this is what gives it a row of dimes look.a lot of guys do this with there foot reastat or foot pedal. makes a real destinctive ripple some guys even go back over there welds to give a nice washed out look. still loooks pretty *****in!!!!!
  18. jdustu
    jdustu
    from Detroit
    The only time I use pulse now is on stainless or sheetmetal and I crank it up to around 110pps, it helps with the warping and on stainless it gives you a cleaner bead without really effecting the ripple.
    I don't pulse on aluminum, just dipping the rod gives you those nice freeze lines:D
  19. speedmetal
    speedmetal
    from houston
  20. Zornig
    Zornig
    from NJ
    Some of my work. I have tons of pics
  21. Blue One
    Blue One
    from Alberta
    Don't know if anyone else pointed this out, but this is most definitely NOT Aluminum MIG.
    It is Aluminum TIG.
  22. Blue One
    Blue One
    from Alberta
    Most definitely the different tungsten. 2% Thoriated is the tungsten of choice for DC welding of carbon steel and stainless.
    Ceriated will work well, but will lose its sharpness and ability to focus an arc much quicker than the 2% Thoriated.
    This is because the Ceriated has lower current carrying capability than the Thoriated.
    With 2% Thoriated tungsten and when the machine is properly set up ,the Dynasty 350 will outperform the old syncrowave easily.
  23. Rex Schimmer
    Rex Schimmer
    from Fulton, CA
    Off road truck. Exceptional fabrication and welding.
    Rex
      86.5 KB
      86.9 KB
      89.5 KB
      58.1 KB
      46.5 KB
  24. DonnyB
    DonnyB
    from Indiana
    Man there is some really nice welds on here
  25. DonnyB
    DonnyB
    from Indiana
    How much time do you have in one of those frames?
  26. Rex Schimmer
    Rex Schimmer
    from Fulton, CA
    Donny B,
    I only wish I could fabricate that good. These frames are for the Hurbst Brothers off road trucks. Built in Huntington Beach at their shop. Don't remember the guys name, his nick name is "Dump". As for the time fabricatioin one of these ch***is I would guess 500 to 1000 man hours.
    Rex
  27. DonnyB
    DonnyB
    from Indiana
  28. bracket
    bracket
    from ATX
    I dunno if mine would be considered "incredible" but here are a few pics of my work.
  29. onlychevrolets
    onlychevrolets
    yeah that was not a M.I.G. weld.
  30. paco
    paco
    from Atlanta
    I would .... & your "purge system" is a great idea. I've used bicycle tubes but will try the tin-foil trick next time on headers.
    Thanks.
    Paco
