Split 6 Exhaust - Why ?
Discussion in 'The Hokey Ass Message Board' started by TheMonkey, Jan 28, 2010.
  1. TheMonkey
    TheMonkey
    from MN
    I searched here and elsewhere... found loads of examples, but haven't really found the 'why'?
    Just for the sound? Or is there some sort of performance theory?
  2. James Curl
    James Curl
    I split the manifold on my flathead Plymouth I/6 and added dual exhaust. It seems to increase the power band and the little engines need all the help they can get. I also have dual carbs and a mild cam and milled the head .100 which also helps.
  3. 39 All Ford
    39 All Ford
    from Benton AR
    IMO the sound alone is enough of a reason.
  4. Porter Man
    Porter Man
    Alliance Vendor
    from Mound, MN
    Because they sound cool as hell!!!!!!!!!
    Nothing even sounds close to it, it's one of a kind.
  5. jcmarz
    jcmarz
    from Chino, Ca
    Mainly for that rapping sound but it also helps the engine breath better so you get a little more pep.
  6. belair
    belair
    You've obiously never heard one go by.
  7. Have you ever heard the sound of a split manifold on an old six? A sweeter noise you will never experience. :)
  8. thewishartkid
    thewishartkid
    If you have to ask!!!
  9. MERC 55
    MERC 55
    He's from MN they never get to open their windows
  10. TheMonkey
    TheMonkey
    from MN
    i've heard it... just wondering if it was the sound alone is why people do it.
  11. HealeyRick
    HealeyRick
    from Mass.
    To better control exhaust manifold pulses. My Dad's 1967 Pontiac LeMans Sprint with the OHC-6 4 bbl had splits, sure sounded good:
  12. 52HardTop
    52HardTop
    Well, why not? If it's good enough for the first Vettes it's should be good enough for Dads old sedan! Besides, like it's been said, they sound cool.
    Dom
  13. waldo53
    waldo53
    from ID
    That's the same question my dad asked me when I was in HS and I wanted to put duals on my '49 Fleetline. I told him it made the engine run cooler, last longer, and get better mileage. He then loaned me the $30 to get a split manifold from Sears and Roebuck (yes, they used to carry lots of hot rod stuff)
    Real reason = you can't beat the sound of an inliner with duals. That was 50 years ago, I still run Fentons and 22" Smittys on my 235. Still love that sound!!!
  14. TheMonkey
    TheMonkey
    from MN
    so - everyone has a traditional 3-3 split front to back? i understand the performance gain from that.
    BUT - i have always thought that the 'rappy' split exhaust was a 2-4 split, which i'm not ever sure what it is (other than 2 out one, 4 out the other) - which seems like it would have some sort of bizarre pulse stream.
    so what split is it that makes the sweet sound? if it's the 3-3 split, then what is a 2-4 split? oh - and why? :)
  15. Fingers
    Fingers
    Both, can't beat the sound AND pick up a bit of power as well = win-win
  16. 52HardTop
    52HardTop
    I think what your talking about is the way the cylinders are split into the exhaust manifold? The 2 4 split would be the fact that the first cylinder is exhausting out on it's own and the second and third cylinders are sharing the second pipe of the manifold. Three and four share a pipe with the last cylinder on it's own. Right? The six exhaust valves are split up a****st four outlets in the head.
    Dom
  17. Rickybop
    Rickybop
    There is no "2-4" split. A stock exhaust manifold has a common plenum. When it's "split", there's simply another opening for the exhaust to exit. The only time the exhaust is actually split, is when an after-market set of dual manifolds is installed. I honestly can't say that I've heard a six with a modified stock manifold, and knew it. I have heard dual manifolds, and I'll tell you, they rap. Maybe you can find a running car on youtube with the modified stock manifold, and compare it to a video of a car with dual manifolds.
  18. Jims35
    Jims35
    I allways used the 2-4 split, I never had to do anything to the heat source under the carb. by staying away from it . The why is , because I can . I liked the sound to.
  19. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Wrong. A stock straight six exhaust manifold has a common plenum IN STOCK FORM. A very important part of splitting it is to, once the second outlet has been added, internally divide the manifold into two separate chambers so that three cylinders dump into the stock outlet and the other three dump into the new outlet. Simply adding a second outlet doesn't make any additional sound at all. A friend added a second outlet to his '54 Chevy truck without dividing the manifold and, even with dual gl***packs, it was still whisper quiet. I cut open the back of the manifold and inserted a steel divider plate-----BIG difference in decibel level!
    The "2-4" split was usually done on manifolds that were difficult or impossible to split evenly; the Ford 223 comes to mind, since its center two exhaust ports both dumped into the stock outlet below the heat riser.
  20. Rickybop
    Rickybop
    I stand corrected, HEATHEN. I wasn't aware that a separator plate was traditionally involved. So without the plate, it is a common plenum, but with the plate, it's a 3-3 split...correct? So there is, in fact, no 4-2 split on the Chey. I like this place. 100,000 heads is better than one.
  21. lippy
    lippy
    from Ks
    Bingo. Just do it! :D
  22. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Right. Because of the 216/235/261's 1-2-2-1 exhaust port arrangement, it's ideal for an even 3-3 split.
  23. fullhouse296
    fullhouse296
    from Australia
    153624 usual firing order .on our old stockcar we made a header flange ,153 ran to a cone and back via 3 feet of 2inch pipi 624 did likewise . sure sounded cool but pulled a tad harder out of the bends when the two 2inch collectors were joined at about half their length and had half what was left welded on . didnt sound as evil but we left it as this .Blueflame six ,destroked to 221 ,600 4bbl dirt track in New Zealand .
  24. von Dyck
    von Dyck
    I ran cylinders 1-2-3 into one collector, and 4-5-6 into another collector. What you end up with is equally spaced exhaust pulses in each individual collector 240* apart that are easily tuneable by the length of the collector. The open headers at RPM have the sound of a radial airplane engine. The reason V-8 collectors sound rough have to do with the uneven firing pulses emitted from each collector.
  25. blueskies
    blueskies
    from Idaho
    I split my flathead six with tube headers and a crossover just ahead of a pair of smithys. No rapping or rackackack cackling, just smooth music to my ears...
  26. greasemonkey060
    greasemonkey060
    You gotta hear it, to "get it".
  27. LB+1
    LB+1
    from 71291
    piper cub down the run way right before take off
  28. Jims35
    Jims35
    When I had them split we cut the manifold in to two seperate parts . Capping each one off , then making a outlet for the short one that came off of two cylinders. We were not concerned about a good flow of exhaust , just lots of noise . This was back in the 1950s
  29. Dynaflash_8
    Dynaflash_8
    from Auburn WA
    <object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/smyHCN2DNC8&hl=en_US&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/smyHCN2DNC8&hl=en_US&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
    This is why
  30. TheMonkey
    TheMonkey
    from MN
    but, on a chevy 216 or 235, the exhaust ports are set up as 1 - 2 - 2 - 1... not sure that could be cut the way you are describing it.
    it must have been something set up like 1 - 1- 2 - 1 - 1? ford?
