I am working on a 33 Ford Roadster and am in the process of putting a 427 FE motor in. I have search page after page on the HAMB and elsewhere to see if any one knows what header might fit. I have a pretty good feeling that no off the shelf headers will fit and I will have to make them. I am running inside the frame rails to an exhaust system. Just curious if anyone has tried to make something off the shelf fit or modified a off the shelf header to fit. Thanks Mike
I have a model a sedan with a 390 and have built several pairs of headers...........my opinion is that if you have to do any modifying to an m*** produced set you might as well build them yourself so they fit your application perfectly. Hope this helps................Love to see FE's in rods!
Yep, I figured that I would have to build them. Just thought if anyone would know the HAMB would. Thanks Mike
I mostly agree with that (if you have to start chopping, it might be easier to make your own). But if could get some block-huggers cheap (swap meet) and maybe you only have to move one pipe, that is probably the way to go to start. I got a stock header to fit one side and had to modify the drivers side due to steering / brake clearance. Still it was less work than build-from-scratch.
Try a pair of mid 70'S 2wheel drive pickup headers they are suprisingly tight to the engine block. Rob
Check with Sanderson. I got some block hugger headers from them when I put a 429 in my '56 F-100. Fit good, but right side collector was so close to the starter it fried half way across the country. Actually found a starter in Wakeenie, Kansas and pulled off the right side header to change the starter. Ah, the memories....
I think carls ford sells shorty factory style headers, from galaxies and fairlanes..I'll have to take a look and see if I can find them again..
