Belly Tank Projects- Can I see yours?
Discussion in 'The Hokey Ass Message Board' started by Anchorboy46, Jan 4, 2010.
  1. I have a good chance at an 11 foot Belly tank that would make a damn good body for a Bonny Salt flat racer.
    Thing is I dont want to get this and just have it hangin around my shop. I think with a Blown 4-71 283 Chev and an older 2 speed aluminum powerglide for a transmission, this could possibly be doable. My T roadstrs have a 10 foot wheelbase, so an 11 foot Belly tank isnt too small I would think...
    How many of you have built a Belly tank lakester?
    Do you gots any pix? Thanks in advance..Mikey
  2. Tim G
    Tim G
  3. fordrat31
    fordrat31
    from Palmer, MA
    Even though the tank is 11' that doesnt mean you will get a 11' wheel base out of it. You have to take in account how much the tank narrows in both the front and rear. The tank I am building is 13'6" and my wheel base will be 105" - 108". I can garauntee you will have a real challange on your hands to fit everything you will need in the tank, but this is true with any lakester. How wide is the tank? Whats it made of, Alumnium - steel? Here are a few pics of the one I am building.
  4. Bearing Burner
    Bearing Burner
    from W. MA
    GET A RULE BOOK. 283Cube engine is in the middle of a cl***.260-304 is D cl***. Also a
    11' tank will give a short wheelbase. You didn't say the Diameter you want the engine to fit in the body. you mighht want to think about a transmission with more gears.
  5. Ol Deuce
    Ol Deuce
    from Mt. U.S.A.
    this is my tank project:p
  6. Ol Deuce
    Ol Deuce
    from Mt. U.S.A.
  7. BigJim394
    BigJim394
    From an early 1960s issue of Mechanix Illustrated. Never saw anyone use a belly tank like this before. By the way he apparently had an outboard in the tank that would tilt up when it was not in use.
  8. HeyyCharger
    HeyyCharger
    Btt. Keep this thread going.....
    HC.
  9. nefareous
    nefareous
    from maryland
    There is someone selling 2 identical tanks on Craiglist right now. $1500 for both!
  10. ChassisResearchKid
    ChassisResearchKid
    from Michigan
    This is just Bad ***!!!
  11. God I love this thread!
  12. Dr. Frankensickle
    Dr. Frankensickle
    from Kansas
  13. torchmann
    torchmann
    from Omaha, Ne
  14. JeremyJames
    JeremyJames
    from concord NC
    i love belly tanks!
  15. lippy
    lippy
    from Ks
  16. flynbrian48
    flynbrian48
    That is just wrong...
  17. Lucky Burton
    Lucky Burton
    I've seen a belly tank called " Old Crow" before
  18. Which Craigs list ? City? State? original misfit Thanks
  19. Patrick46
    Patrick46
    Waaaaaaahhhhh.....you don't like Zippy???
  20. Chuckles Garage
    Chuckles Garage
    Alliance Vendor
    That is a beautiful thing right there.
    volvobrynk likes this.
  21. Chuckles Garage
    Chuckles Garage
    Alliance Vendor
  22. Dr. Frankensickle
    Dr. Frankensickle
    from Kansas
    its been reinforced and gusseted since that pic
  23. jpm49c
    jpm49c
    I have one for sale here in Phoenix. Its a FJ-4 Aluminum, 12"long 25" dia. $700. I was planning to build a Bellytank but can't do it right now! John
  24. LarzBahrs
    LarzBahrs
    from Sacramento
    Wonder if an old water heater tank would be a doable belly tank
  25. HeyyCharger
    HeyyCharger
    Nice Project there Dr!
    Fill us in a bit more.......
    HC.
  26. Chaz
    Chaz
  27. Dr. Frankensickle
    Dr. Frankensickle
    from Kansas
    429 Cadillac Lakester headers are on ,moons are on rear suspension changes,Working on a dual 4 set up as we speak.57 Olds Rearend 3.08 on a factory Posi.If the Caddy cant cut it ,Iwill toss in a 427 Chev
  28. Hay Doc...your photo bucket seems to be empty!
    Extending and tank is pretty simple. Find the fat spot, slice it in half, and add additional length as required to fit everything in. The additioal body panels do not have to be compound curves. Straight panels work just fine.
  29. cornfieldcustoms
    cornfieldcustoms
    here is mine, it is a f84-e tank. it sounds like yours it is 11.5 ft long and about 3 ft in diameter. it was a challenge to get everything to fit in mine. there are some things missing in the pics but they are from almost two months ago
