1965 caddy parts?
Discussion in 'The Hokey Ass Message Board' started by 40oz., Jan 30, 2010.
  1. does anyone have any sources for 65 cad. deville parts. looking for window motors and am havin no luck.
  2. Caddy-O
    Caddy-O
    I know O'reillys stocks a lot of Mid 60's Cadillac motors, you might give them a try.
  3. I could have had a ton of that **** last fall and let it go. Ended up with a couple clocks. Should be cheap and the motors themselves probably fit three dozen other GM cars - checked Rockauto.com?
  4. flatheadpete
    flatheadpete
    from Burton, MI
    I run the stock motors in mine.....S--L--O--W!! My tracks need new bushings in 'em as they don't go up straight.
    BTW...You can buy my motors with the car attatched very reasonably priced!!
  5. i will check those tomorrow, thanks. anyone else?
  6. Rande
    Rande
    We are kinda far away but a friend of mine has a complete car he would likely sell.
  7. teddyp
    teddyp
    there a place in pa. that i got alot of parts for my 65 fleetwood
    bobby,s
    cadillac parts
    hamburg pa.
    610-562-8631
  8. plym49
    plym49
    from Earth
    You are gonna hate me but two months ago I threw a bunch of them into the dumpster. I had been hanging on to them forever and did not see a need. Sorry.
    If it helps, I believe that 80s Jags (XJ6, etc.) used essentially the same window motors. Perhaps someone can confirm this.
  9. ShortBus
    ShortBus
    I think all of the GM window motors are the same. I pulled one out of the p***enger door of an 80s Cadillac for the rear quarter window in my 60 Olds and the only difference was a round electrical plug vs square. I had snipped the pigtail from the Cad so I just spliced it in.
  10. this is all good stuff, i will check it all out tomorrow. thanks.
  11. GaryM
    GaryM
  12. stuart in mn
    stuart in mn
    Auto City Cl***ic sells a lot of power window parts for GM cars. They don't list Cadillac on their website, but as mentioned above chances are the motors were used on many GM cars. You could give them a call. http://www.autocitycl***ic.com/
  13. thanks guys, this list has come in handy more than once.
  14. jfrolka
    jfrolka
    carquest out here in ca has them, 100 each
