Projects The Tindall Coupe Build
Discussion in 'The Hokey Ass Message Board' started by Tindall, Apr 6, 2008.
  1. grits
    grits
    Looks really good, i like the black and chrome and that 409 rocks.
  2. VanHorton
    VanHorton
    uh oh! wont be long now.... awesome job
  3. lorodz
    lorodz
  4. Hot Rod Michelle
    Hot Rod Michelle
    Are these old Buick drums that have been cleaned up? Or, is somebody recasting these?
    Nice coupe by the way.
  5. Hot Rod Michelle
    Hot Rod Michelle
    This, I presume is the fuel pump? Please correct me if I'm wrong. I'm trying to learn something here that can help me with my build.
  6. NotNuRodz
    NotNuRodz
    Your coupe is looking great, what size are your tires front and back?
  7. Tindall
    Tindall
    750x16 in the rear and 600x16 up front
  8. Tindall
    Tindall
    nope just gl*** beaded old ones
  9. Tindall
    Tindall
    its the brake proportioning valve
  10. 34Chrysler
    34Chrysler
    very cool!!
    I am saving this thread to my favorites so I can refer to it again.
  11. SlowandLow63
    SlowandLow63
    from Central NJ
    Damn Matt that really looks awesome!!!!! Again, I sincerely apoligize that were not on youe body 100%, but mark my words, when you are ready for the body, it will be ready for you.
  12. claymore
    claymore
    Nice job on the trans mount. One safety suggestion though if it were mine and looking that good I would put the bolts holding the mount in from the top with the nuts on the bottom that way if things loosen up the bolts will still somewhat hold the mount in place and you may catch it before there is a problem your way the bolts will fall completely out and it could get hairy much faster.
  13. 31 Coupe
    31 Coupe
    Claymore, That is usually the prefered ***embly method, and I agree completely, BUT, the flat plate crossmember is mounted under the ch***is cleats so even if the nuts did fall off the crossmember is already gone anyway. Matt can you put the crossmember to the top of the cleats and reverse the bolts?
    You are an extremely talented kid, I'm 56 and I am loving your build. All the best , GB.
  14. claymore
    claymore
    Well if it needs to be installed with the nuts on the top for some reason then just drill the bolts after the nuts are torqued and install some cotter pins or better yet safety wire them as that will match that nice looking trans mount.
  15. Boozer
    Boozer
    Wow man..... Awesome car, awesome build thread. You've got more talent and ambition than most guys twice your age, myself included. (although I'm not quite twice your age...only 24) It seems as though in addition to your talent, you've also got some really cool parents/support system, I hope you understand how rare that is. Lots of us here have been doing the "car thing" in spite of our parents (or to spite them!) Best of Luck
  16. Hot Rod Michelle
    Hot Rod Michelle
    Ohhhhh..... Do I need one? What is its purpose.
    Thanks for any helpful information you can provide.
    Now, before any Model A-holes go jumping on me for not knowing this ****, this is the place to learn. The preceding message is my disclaimer.:)
    Michelle
  17. farmer12
    farmer12
    Great work Matt! An absolute inspiration to us all! Keep it up.
  18. Tindall
    Tindall
  19. Hot Rod Michelle
    Hot Rod Michelle
    I dig that "How Stuff Works" cite. Very cool, thanks for the info.
    Michelle
  20. Tindall
    Tindall
    i Got my carbs from UncleMax...and they look great. Brake lines are done...almost ready to start it up
  21. JohnJoyo
    JohnJoyo
    Alliance Vendor
    from Austin, TX
    That looks great! What a beautiful 409......dressed up just right.
  22. claymore
    claymore
    Dam fine looking 09 right there.
  23. HotRodMicky
    HotRodMicky
    Looks great.
    Your Front U-Bolt plate is mounted upside down.
    The rubber piece needs to go towards the axle
    Like a bumpstop.
    Michael
  24. Jeff Norwell
    Jeff Norwell
    MODERATOR
    I Like it!
    very nice work.
  25. I SMELL SMOKE
    I SMELL SMOKE
    looks really good matt!!!
  26. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    That's one of the nicest engine ever!!!
  27. grits
    grits
    That's beautiful man.
  28. uncle max
    uncle max
    I am uncle max & I approve of this thread!!!!!!!!!
  29. BudJ63
    BudJ63
    from Florida
    Excellent build! Hope there will be a video of that beauty firing up!
  30. freebird101
    freebird101
