what can be done with harbor freight mill/lathe
Discussion in 'The Hokey Ass Message Board' started by Slag Kustom, Feb 1, 2010.
  1. Slag Kustom
    Slag Kustom
    after so many bashing threads about harbor freight **** i wanted to post some stuff i have made with my 9x20 lathe and bench top mill. both cheap china **** but are good castings. with some help from my friend joe we set the machines up tight and went to town making some parts.
    f100 steering box
    slave cylinder for camaro t5 bell
    trans crossmember
    throttle linkage
    37 degree AN fittings.
    throttle pedal
    ac bracket
  2. greasemonkey060
    greasemonkey060
    Wow! You my friend, are just a good craftsmen using okay-quality tools!
  3. willymakeit
    willymakeit
    Good work. Quailty of tools will never exceed ability and desire.
  4. Ken Carvalho
    Ken Carvalho
    In that top right picture of the steering box,... how were you able to get the round (where the shaft goes thru) protrusion "off-set" on the square block?? It comes with a 3 jaw chuck right? I am under the impression if you used a 4 jaw you would be able to "offset" the block in the chuck jaws so the shaft area would be centered, just confused?!?!? I'm no machinist, and I can't figure it out. BUT VERY IMPRESSED!!! Also very ingeneous on using the fuel pump bolt holes for that mount. Ken
  5. Slag Kustom
    Slag Kustom
    due to the size of the block for the steering box first step was to bore the holes for the steering shaft and pitman arm shaft. then box was held off those hole in the 3 jaw chuck and turned from there. many hours spend thinking on just how to set up the tools to work with what i had to do.
    Darryl Deir likes this.
  6. Ken Carvalho
    Ken Carvalho
    Ahh haa, I get it!! Makes perfect sense (now that you explained it)!! DAMN GOOD JOB!!! Very impressive...Ken
  7. My Dad used to say "a poor carpenter blames his tools". You just made his point. GREAT WORK Boss!!!!!!!!!
  8. Slag Kustom
    Slag Kustom
    as a friend said
    We have done so much
    with so little
    we can do anything
    with nothing
  9. 440shawn
    440shawn
  10. OFT
    OFT
    Very nice work!!!!!!!!!!!!!!!!!!!!!!!
    Earl
  11. oldskool30
    oldskool30
    Machinist's can turn out good work on aything... GREAT JOB
  12. TomWar
    TomWar
    I am a Machinist, although I haven't worked in the trade for many years, A few years ago I bought a HF hand milling machine, it is not the best piece of equipment I have run, but for the price, it serves well. I have used it for many projects on my roadster build. and it has paid for itself many times over. Of course I would still rather have a Bridgeport or Gorton mill, but this will suffice.
  13. Captain Freedom
    Captain Freedom
    from Upstate SC
    I bought one of their 12" x 37" geared lathes about ten years ago and have been using it almost daily ever since with no problems. I recently purchased one of the largest table-top type of mills they sell, but it has been the reason for many foul words floating around in my shop. Lets just say If I hadn't have had the lathe, the mill wouln't be working right now..
  14. scottybaccus
    scottybaccus
    You say you set it up tight? What was involved in making it work at it's best?
  15. bingo!
  16. MedicCustoms
    MedicCustoms
    Man thats some cool work ,you are a very good craftsman nice work
  17. Impressive work, with all the effort put into that stuff, I'm sure everybody would like to see where it's going :D
  18. Slag Kustom
    Slag Kustom
    most of the work was just making shims to take out the lash and getting it all square
  19. Ruiner
    Ruiner
    Yeah, I upgraded the chuck on my HF lathe with a kit from some online website that deals with small hobbyist machining tools...and got a quick change tool post (which is a piece of **** compared to the real deal regular sized tool posts)...I really do need to adjust the slack out of my bed though, the damned thing chatters like there's no tomorrow on anything harder than 6061 aluminum...but I gotta say, that little ****** has made some fantastic parts for me over the years...I'd like to get a mill too, but not if it's a taper spindle. Is your mill a taper spindle or a drawbar spindle?...
  20. Slag Kustom
    Slag Kustom
    mill is a taper but i got a cuick change collet set for it. makes tool changes real easy
  21. mrpowderkeg
    mrpowderkeg
    I have a little jet lathe, and that thing has paid for itself. I don't know how I'd live without it.
    I do need to order about $200 in stuff for it, but so far I have made a ton of stuff on it with just basic tooling. It saves me time to make the stuff rather than order it. I do want to learn how to make AN fittings, then I'd be set.
  22. Ruiner
    Ruiner
    I could deal with a taper if it's got a collet system, as long as that damned taper doesn't keep dropping out or chattering at the start or end of a cut...there's nothing fun about a 1/2" carbide endmill dropping onto your table or floor at 1,000 rpm's...hahaha...I'd still prefer a used Sharp or Bridgeport full size mill though, but the prices are always way out of my league...
  23. Ruiner
    Ruiner
    By the way, www.littlemachineshop.com is where I got my upgraded chuck for my lathe from...it makes a HUGE difference over that dinky chuck that came with the lathe...
  24. blojectedj
    blojectedj
    from oklahoma
    I have a HF benchtop gearhead mill and 12x36 gearhead lathe, they are not the best equipment but will do as good a job as the man running it. I have built and milled main caps, milled intake manifolds, built so many damn one off brackets and stuff for my buddies I can't count them all. I just wish I had been smart enough to take pictures of the stuff so I could show off a little!:D
  25. Slag Kustom
    Slag Kustom
    if it was not for my ****py cell phone pictures i would not have any either
  26. johnboy13
    johnboy13
    Do you have, or could you get some better pics of that steering gear box?
  27. Excellent to see the nay sayers look in awe! I am envious and glad to see sucess stories like this!
  28. Slag Kustom
    Slag Kustom
    i will try to remember the good camera but who knows when
  29. boldventure
    boldventure
    Here is a link to a website that deals with the HF type machines. Some of the info is a little old but probably still relevant.
    http://www.mini-lathe.com/Home/index.htm
    By the way really nice work!
