Lets see your scratch built floor pans
Discussion in 'The Hokey Ass Message Board' started by johnboy13, Feb 3, 2010.
  1. johnboy13
    johnboy13
    After reading Da Tinman's post about floor pans, I decided to have a go at it myself. I will be replacing the whole floor rather than just patches. I have the back half of my cab to use as a pattern for the beads, but the front half is a patchwork of Shi**y s****s welded over the original floors that I did years ago. It is now time to rip it all out and start from scratch. So that brings me to this post. Let's see some pics of floor pans, patch or complete, that you did yourself. I have a bead roller, a 4' by 8' piece of 20 ga, and enough bits to fill any voids I may have. While we're on the subject, what's the best way to attach the new floor to the cab? Should I leave a one inch lip of the old floor all the way around and spot/full weld to that, or bend a 90 degree lip on the edge of the pan and weld to the inside walls of the cab? Thanks, John
  2. johnboy13
    johnboy13
  3. chaddilac
    chaddilac
    make your beads on come up into the cab, not out. That way if you have some water or fluids that spill, they won't settle in the beads and rust them out!
  4. BobPer
    BobPer
    For my 36 Dodge I had to replace the entire bottom 6" of the body, so I made all my floor out of 14 gauge. The sills are also 14, the rockers and quarter panel patches I made from 18, and the wheel wells I made from 16. I initially made the pieces for the floors with beads, but they warped on me so I made them a second time (sound familiar?). Bob
  5. alteredimage
    alteredimage
    Rolled them in the english wheel first in the opposite direction of the bead so when the bead was put in it would straiten the pannel. When the reat of the work is finished we will spray the floor with bedliner to preserve and keep the sound down.
  6. Tinbasher
    Tinbasher
    Here's the Floor for the 31 Ford Cabriolet.
  7. uncle johnny
    uncle johnny
    doing this in a 36 chey pu.
    johnny
  8. flamedabone
    flamedabone
    Here is my 39..she was missing most of the good stuff.
    The new floor is a mix of 14 and 16ga, depending on the panel and 18 for the driveshaft tunnel.
    Good luck, -Abone.
  9. 46 rat
    46 rat
    from clever mo
    Not the best but better than nothin.
  10. titus
    titus
    heres some ive built
  11. I SMELL SMOKE
    I SMELL SMOKE
  12. exStreamliner
    exStreamliner
  13. MGGeerJr
    MGGeerJr
    I smell soke is that rivetted together?? It's a great look
  14. BCR
    BCR
    I did this for a Model a tudor.
    Lance helped too.
  15. BCR
    BCR
    Here is a pic going in the car. I screwed it down with oval head stainless screws. Flaired the washer heads into the sheetmetal with the pullmax, but you can do it with a rivit gun or a air hammer and a backup.
  16. charleyw
    charleyw
    50 F-1, in (slow) progress. 12 ga, no beads, 1/2" sq. tube reinforcement
  17. TudorJeff
    TudorJeff
    Speaking of DaTinman... he did these for me.
  18. Heres mine, 1/8th inch diamond plate.
  19. metalshapes
    metalshapes
    These pics are from 2 different Model A's I did.
  20. Kirk Hanning
    Kirk Hanning
    Here are a couple from my sedan I'm currently doing.
  21. metalshapes
    metalshapes
  22. heliotropephotos
    heliotropephotos
    from Austin, Tx
    Here is a full Merc floor and firewall I did for Mercury Charlie. My first floor, a bit intimidating, but turned out nice. now all the new floors are based off this design.
  23. Toast
    Toast
    from Jenks, OK
    Some I did on my truck
  24. metalshapes
    metalshapes
  25. Excellent thread guys.
    Very timely.
    Just pondering about how to do mine.
  26. gmgrunt
    gmgrunt
    heres a section I made with my pullmax for my 34 ford 3 window project. It has some beading facing down and some beading coming off the original floor facing up.
  27. Beebeebobby
    Beebeebobby
    from Webb City
    Thanks for this thread...I need to do the floor of the falcon...sheesh...:rolleyes:
  28. drptop70ss
    drptop70ss
    from NY
    low buck cut from a mid 80s chevy pickup hood..not pretty but beats dragging your feet on the ground. I need to buy a bead roller!
    before
    after
  29. bent metal
    bent metal
    Step down Hudson (48-54).
  30. bent metal
    bent metal
    '40-'47 Hudson, but custom design.
