Customs shaving a 49-54 chevy trunk lid
Discussion in 'The Hokey Ass Message Board' started by Ball and Chain, Jan 5, 2010.
  1. Ball and Chain
    Ball and Chain
    from Nor Cal
    Any good donors for a latch set up, any posts on it?
    Thanks Kevin
  2. 40StudeDude
    40StudeDude
    Its' relatively easy and cheap...
    Go to the pull-a-part yard, get the electric opening mechanism out of a Pontiac, Olds, Chev Impala, Buick, etc...take it all - the latch, the mechanism, the wiring and the ****on out of the dash...
    Usually it's one hot wire, a ground to the mechanism and the hot wire to the ****on on the dash...
    Bolt it in in place of your old key thingie and put the "catch" on the bottom......climb inside the trunk and close but keep it wired up so you can get out... check to see if it lines up and keeps the trunk closed (and it opens like it supposed to)...if it does, you're done.
    R-
  3. hotrod-Linkin
    hotrod-Linkin
    do not get into that trunk and close it shut!!!!! it's better to get your mother in law to do that!!!
  4. 40StudeDude
    40StudeDude
    Oh yeah, LOL...I forgot to mention that you should get someone you don't like to climb in the trunk and close it...
    R-
  5. I used my stock latch and just reversed it. I then ran a wire through the trunk floor to operate it. Look at my photbucket page for pics and by all means ask any questions that you may have. Todd
  6. Ball and Chain
    Ball and Chain
    from Nor Cal
    perfect thanks!
  7. slick39
    slick39
    from dallas ,ga
    this is good stuff thanks
  8. Your the man...:D...thanks for sharing !
    / primerkid
  9. outlaw1949
    outlaw1949
  10. merc-o-madness
    merc-o-madness
    used stock latch with cable through trunk
  11. pittsburgholdschooler
    What they said..lol:D
