I've seen some 6 split exhaust manifolds here with what looks to be cast outlets just wondering where I can get some.
Here's another tip for manifold splitting--if you ever run across an old step van that's Chevy six powered, look under the engine cover. I found a cast iron offset carb adapter on one that, when sawed in half, gives you two outlets that are the exact same size as the stock outlet on a 235.
On my Stude flathead 6, I found another exhaust manifold, took the two of them, cut them up and welded the 90's and flanges, and was all set. I got the idea from many others who have done it on Chevys and Ford 300's (truck motor).
You didn't say what engine. The late Ford 300-sixes with fuel injection came with "split" manifolds, which a lot of rebuilders like better than headers and a lot better than the older factory manifold. I also once saw some different, much earlier, "split" (by which I mean separate manifolds for 1-2-3 and 4-5-6) cast iron manifolds for the 240/300, which reportedly came on some late '60s Fairlanes.
back in the old days used 1 1/2 in pipe and 2 in flex tube and that must have been cheep if I could afford it, but it hit the threttle rod and kept sliding down , oh well was young and dumm then
In the fifties parts stores sold short cast iron pipe with a flange on it that could be used to split a manifold. If you have some old 50s car magazines you may see them in the ads. I think it was Almquist that had them.
