I have hit a snag in rebuilding a track T. One of the front rotors needs to be replaced, but I have been unsuccessful in identifying what it is. So for I have contacted Wilwood and the local brake supply shop with no luck. The rotor and hat are one piece with the hub attached with countersunk hex head bolts. At first the brake guy thought it was a volvo unit but the Chevy 4 3/4 inch bolt pattern threw him. The brake ***embly fit early Ford spindles and probably dates from the late 1970's. Can anyone identify what I've got? Thanks in advance. 29guy
You might want to look into circle track parts books. There are several different companies that make hat style rotors that are designed to bolt onto a hub. I do not have my books/catalogs anymore or I'd try to get you some numbers/names.
Thanks 333 Half Evil and pasadenahotrod, I had some volvo rotors pulled and they did not match up. The hats were very different. I will hit the search engine and see if I can come up with some track suppliers. 29guy
