Hot Rods Gasser Gasser Gasser!! 1962 Falcon Futura with a Nailhead??
Discussion in 'The Hokey Ass Message Board' started by Chuckles Garage, Dec 16, 2009.
  1. Chuckles Garage
    Chuckles Garage
    Alliance Vendor
    hahahahahaha! I definitely laughed out loud on that. The best explanation of the rules I have found so far is on the Byrons G***er Madness site. If it's wrong, I would love to know exactly what the rules were.
    From BGM site:
    "Just by way of providing information for those who aren’t quite sure what “engine setback” means, a 10% setback would allow the engine to be moved back enough so that the forward most sparkplug in the engine could be no further than 10% of the wheelbase behind the front axle centerline. In other words, if the car had a 100" wheelbase, the front sparkplug must be within 10" of the front axle centerline.
    The reason that the setback rule was introduced is reasonably simple. There was nothing in the rules that required the original engine in the car to be used. When someone performed an engine swap in a Model A, for instance, chances were that they would have to cut the firewall anyway. The question then becomes “what is the “stock location” for a flathead V-8 in a Model A?”. Introducing an engine setback limitation merely provided a level playing field for all compe***ors."
  2. 69fury
    69fury
    from Topeka
    yeah i read the same thing and had to edit my post- i thought it was 10% of the original engine location but that would only work for stock mills not swapped ones.
    i just checked some pics of mine, and have the front exhaust port on the p*** head even with the axle, Which means the plug is about an inch behind the axle. Now this p***enger head is the rearward head on a mopar, so the number one cylinder (on the driver side)is actually a touch ahead of the axle.
    If you put your front plug 10" behind that axle, you're right- that's WAYYY back!:D How streetable will she be once the headers are built? lol (mid engine zoomies?)
  3. Chuckles Garage
    Chuckles Garage
    Alliance Vendor
    Not very streetable at all. 3.5 gallon tank, no front brakes, no lights, zoomies etc....make a pretty horrible street car. I've also been toying with going A/FX with it and putting a 6-71 Mooneyham blower on it. That wont help streetability either hahaha.
  4. 69fury
    69fury
    from Topeka
    Cant wait to see it! Gonna be a beast!
  5. robt500
    robt500
    from Lex, KY
    yes!
  6. Chuckles Garage
    Chuckles Garage
    Alliance Vendor
    Update #4
    Made a plastic sheet template for the fenderwells. I used some gray primer to mark the cut. You dont have to worry about tape moving etc... when it's done this way. The tires are 30" tall, so I made the fender opening 32.5"
    Taped it on to the fender after some careful measurement....
    Got out my trusty angle grinder with a small wheel on it. I like the control this affords me. Cut Cut Cut.....
    This is where the tire will sit when its on the ground.
  7. low budget
    low budget
    from Central Ky
    Super Wicked, keep at it man you are lookin good!
  8. BrickTopp
    BrickTopp
    I swear your car is mine lookin in a mirrior. awesome job!
  9. newfalconowner
    newfalconowner
    from NS Canada
    man be cool to get our falcons together once were all done them
  10. Falcon Gasser
    Falcon Gasser
    Looking good, its coming together fast.
    Jon
  11. 69fury
    69fury
    from Topeka
    We need to get them all together when done, for a Falcon G***ers of the HAMB meet or calender!
    sorry for the huge pic.
  12. lorodz
    lorodz
    looks good man keep it up the front wheels are sweet ...
  13. Chuckles Garage
    Chuckles Garage
    Alliance Vendor
    So.....as I mentioned earlier, I bought the car for $200. Since then, I have sold parts off it for a total of $300. I love it when a car pays ME. haha. I still have all the side trim to sell now too.
    I'll have some more updates tonite. Gonna have an axle in front!
  14. JCShiels
    JCShiels
    If it's the one I am thinking of, the article is ***led "Big Indian With Falcon Feathers". Ranchero w/Ford pickup beam axle (narrowed), Pontiac engine, can't remember what transmission.
  15. Chuckles Garage
    Chuckles Garage
    Alliance Vendor
    Update #5
    Finally got all the spot welds drilled out for the suspension mounts. Man thats ugly!
    Cleaned up the rails for the addition of a curved piece of 2.5x1.5 3/16ths box tubing. This will give the wimpy rails some much needed strength.
    Cutting the square tube to conform to the factory rail. this will be welded and ground smooth before it is then clamped to the factory rails.
    Welding the square tube on. I also filled the spot weld marks
    Cleaning up the filled spot welds...
    Rail support all welded in place...
    This will be tied in with a full subframe later.
    Front and rear spring hangers welded in place....
    Finally! On the wheels!
    The front wheels will NOT stay red, I will most likely just paint them black or white. They are only temporary till some spindle mounts magically show up on my doorstep. The gross tires will go away in the next couple days as well, and be replaced with a set of Hurst Super Cushions.
    The front of the car will drop an inch or two when the powerplant gets dropped in. Oh ya!
  16. Chuckles Garage
    Chuckles Garage
    Alliance Vendor
    Heres The seats that are going in eventually. I bet ya can't guess what they are from.
    and....yes....I will be pretty much sitting in the back seat.
  17. hemi
    hemi
    nailed31 likes this.
  18. hemi
    hemi
    Oh yeah.... Lookin' good! :D
  19. "Whitey Ford" 62 Uni
    from Tampa, FL
    I want to take this car behind a middle school and **** it. Cant wait to see it done....
    I seen this one at the Atlanta World of Wheels and then a g***er dream came about from this car alone. Im not keen on the chevy engine part but i would still drive thie **** out of this. Put a ford in it and its my dream g***er....they remind me of each other.
  20. Undercover Customs
    Undercover Customs
    This thing is very cool. Keep up the awesome work man..
  21. lorodz
    lorodz
    those welds are great ...jesus...i need a better welder
  22. low budget
    low budget
    from Central Ky
    They have a early 70s American muscle look but by the way you are daring a guess I will guess 70s/80s BMW? I give up.:eek: what?
  23. low budget
    low budget
    from Central Ky
    [QUOTE="Whitey Ford" 62 Uni;4875250]I want to take this car behind a middle school and **** it. [/QUOTE]
    :confused:
  24. Chuckles Garage
    Chuckles Garage
    Alliance Vendor
    1968 Honda N360 Microcar! haha.
  25. dragrcr50
    dragrcr50
    wow I know that car on your avatar??:cool:
  26. Chuckles Garage
    Chuckles Garage
    Alliance Vendor
    Ivo's quad nailhead powered FED........If I could have ONE car in the world......
  27. low budget
    low budget
    from Central Ky
    Thats what I was gonna guess next:D
  28. Chuckles Garage
    Chuckles Garage
    Alliance Vendor
    Hahahaha....riiiiiiight.
  29. cabby34
    cabby34
    from England
    This looks so similar to mine :), waiting to see what you do steering wise?
    Great work by the way
