History Cool old find
Discussion in 'The Hokey Ass Message Board' started by busch, Feb 6, 2010.
  1. busch
    busch
    Came across this in my dads shop was taken back when I realized what it was, had been there for 30-35 years I remember seeing it a time or 2 never paid much attention to it. I was looking for a old rear view mirror that was in one of the cubby holes and to my surprise found this old tire inflater works off of compression from a spark plug. No idea on what year it is
  2. Master of None
    Master of None
    That's pretty cool.
  3. Deuce3wCpe
    Deuce3wCpe
    from New Jersey
    yeah those things are pretty neat... doesn't actually pump the cylinder charge (air/fuel mixture) into the tire, but uses the compression to operate a simple little "flutter" valve which pumps fresh air into the tire...pretty ingenious. I keep one of these and a tire plug kit on board since I don't have room for a spare.
  4. busch
    busch
    Deuce If you have used it how long does it take to fill a tire
  5. Onelow34
    Onelow34
    Cool! Great find
  6. Mudslinger
    Mudslinger
    from an age when we tried to make everything simple.
    That would work good in a pinch on the side of the road.
  7. oldebob
    oldebob
    from Spokane WA
    I have one in the trunk also along with a spare tube and a couple of tire irons. Same deal, no room for a spare either. Nice find,all in the orig box!
  8. r0yal
    r0yal
    from winnipeg
    that's pretty nifty.
  9. Deuce3wCpe
    Deuce3wCpe
    from New Jersey
    Never actually tried to fill a tire with it...I think I just keep it with me because it make me feel better - like maybe I'm not completely screwed if I get a flat!
    If it works the way I think, it uses the vacuum from the intake stroke to fill the hose with clean fresh air, then uses the compression stroke to force the fresh air into the tire so it should supply good pressure. A check valve keeps the air/fuel mix out (think Hindenburg).
    The old box mine is in shows a guy spray painting a car with it....ha, imagine running your old banger on 3 cylinders for 2hrs while you paint your car....
  10. 51 Leadsled
    51 Leadsled
    from NC
    Great idea! I imagine it would not take long to fill!
  11. busch
    busch
    I guess back in the day you used what you had but painting with this ****er
    dam that getting her done LOL, gas was maybe 3-5 cents a gal so it would have been cheap why to do it probably used some barn white wash
    Thanks Deuce
  12. outlaw1949
    outlaw1949
    I've never seen any thing like that.
  13. 29nash
    29nash
    from colorado
    They were a common item when I was a kid on the farm in the '40s. We didn't have electricity, no air compressor. An air compressor with a gas engine was pretty expensive relative to the need. Hand pumps were the standard, the SPARK PLUG PUMP was a step up. It took a while, up to a half hour to pump up a tire. The flutter valve opened when the piston was on intake stroke, pulling fresh air into the cylinder instead of fuel air mixture from the intake manifold.
  14. Hot Rods Ta Hell
    Hot Rods Ta Hell
    Neat! Definately the setup before slime, fix a flat cans and cIgarette lighter pumps, not to mention how easy it was to pull a plug on old cars. Some new cars are a MONSTER TO GET AT THE PLUGS.
  15. busch
    busch
    I have no idea on what theys are wood boxs 3 wires coming out each one
    any Idea's
  16. Dzus
    Dzus
    I had one of those "flutter valve" kits I kept in my first '56. It actually worked. This was long ago and I'm trying to remember how long it took the 235 at idle to pump up a tire.....Seems like it was about as long as one of those modern 12v pumps. I do remember that it made a racket when it was pumping. Or at least the one I had did. Wonder where it went??
  17. Ebbsspeed
    Ebbsspeed
    I believe you have a pair of buzz boxes there. Used to generate the spark for plugs, before points/coil ignition was common. Here's one in action...
    http://www.youtube.com/watch?v=2OXTw06l_u8
  18. selohssa
    selohssa
    that inflator is cool. I will have to keep my eyes peeled for one now.
  19. Okie Pete
    Okie Pete
    Yes these are buzz coils . A battery was used for power and the coils made the spark . Used in Model T's . Hit and miss ,throttle governed one lunged engines. Will throw a spark like a welder and make you wet yourself.
  20. BELLM
    BELLM
    I became friends with an 85 yr old farmer about 15 years ago, bought a couple of early 40s John Deere B tractors from him, he had a '66 Chevy with a 6 cylinder engine up on blocks, had one of these permantly installed, was his air compressor. He started the car, aired up one of the tractor tires, didn't take long. He had lots of cool junk including an early '50s Chevy car with the interior completely filled with Maytag gas washing machine engines.
  21. busch
    busch
    heres another something any ideas
    this is a spout for steel oil quart can push it in 1/4 turn
  22. busch
    busch
    Fender Flaps they would look awesome on a old seld
    sorry they are dusty been in that box who know how many years
    still complete set
    [​IMG][​IMG][​IMG]
  23. T Fritz
    T Fritz
    The above is used to pound chain links apart that were used on agriculture equipment like corn binders, elec vators and combines
