Hot Rods 1960's Vintage Dragster Find
Discussion in 'The Hokey Ass Message Board' started by 29hammeredcoupe, Sep 28, 2009.
  1. trksmth
    trksmth
    Found out today that it was ran with the wheels it has .
    Henry said it DID NOT have a chute! And just a push bar, no starter.
    I'm checking with Guffey today.
    Thanks
    Mike
  2. trksmth
    trksmth
    Ya, I asked him if they ran camel backs heads and he said NO!
    He said they had double points??? Camel backs may not of been out yet?
  3. trksmth
    trksmth
    Just got off the phone with a guy that thinks he has a (J * 2) 327, Oct, 1962 327 four barrel motor with twin towers on them? He going to check on them for us today. If anybody knows of these let me know.
    Thanks
    Mike
  4. trksmth
    trksmth
    So, Has anyone seen or have pics of an old ROLLER STARTER set up?
    I'm looking for one or need to build one for this car.
    I just heard about them today and think we need one!
    Pm me if you have info on one.
    Thanks
    Mike
  5. Little Wing
    Little Wing
    from Northeast
    I believe they were built into the ground at the track
  6. trksmth
    trksmth
    I'm talking about the one that uses your tow rig tire to power it in the pits.
    Cool pic! Thanks Mike
  7. Brad54
    Brad54
    from Atl Ga
    For cooling, I wonder if you could run one of those finned tube auxilliary coolers they sell now... run one on the outside of each frame rail, between the frame and the body. One end plumb into a block freeze plug, the other plumbed into the water port on the intake, done on each side of the engine.
    It'd shed some of the heat in the water, without a pump and radiator.
    -Brad
  8. RopeSeals???
    RopeSeals???
    Looks like BT-13 (maybe)
  9. 66cayne
    66cayne
    It wasn't running 9s with that smallblock. What are your plans for it?
  10. PITRE ART
    PITRE ART
    Very cool,nice score!
  11. trksmth
    trksmth
    It's hard for me to believe too, I've ran 10.02s and thats fast! But they are looking for the time slips and I'll post them as soon as I got them.
    The car is very light! And had a 292 (283 .060) that was built good for, back in the day.
    My kids car weighs 1900 lbs w/377 runs 10s, so it's possible.
    We're looking for a 292 ci to run, we are keeping it the way it was!
  12. trksmth
    trksmth
    You are right! the Chevy orange, dual quads is a completely stock 1958 Corvette engine!
  13. trksmth
    trksmth
    I tried to search to see if it is. I looked but can't find anything or pics? I like to know what seat it is! So if anybody can tell us, that would help.
    Thanks
    Mike
  14. 33 ply 440
    33 ply 440
    from mn
    your plans seem to show it a alot , build a trialer with a roller built in , low slug , easy on an off .
  15. The only pit roller/starters I've ever see were for bikes. In almost 40 years of going to the drags from coast to coast I've never see a unit large enough to start a rail or comp coupe like your's.
    Sticking with race gas is a good idea. With alky the tracks will want a huge ($1,000) fire bottle system.
  16. trksmth
    trksmth
    I have a vintage trailer and thats the plan, for a roller start on it.
  17. Little Wing
    Little Wing
    from Northeast
    just put a starter in it and use a hot box to fire it up,,roller is no god if you stall or something else and your starter is back on the trailer
    Also on teh trailer your starting it up in the pits,,does you know good when you have to go sit in line,,as you can't just sit on idle
  18. trksmth
    trksmth
    Don't want to add a fire bottle, we will try gas first.
    Mike
  19. trksmth
    trksmth
    True! But still like the keep it old school feel, we'll see. I'm sure we'll get sick of pushing it.
    Mike
  20. Pushing it is a pain, and for that reason I am going to add a battery without harming the car. It will be a bolt on. Totally removable. Here is my crew. We are in the staging lanes at Da'Grove. AJ is my pusher. It push starts pretty easy. After a run, he drives the four wheeler down the return road and pushes me back. As far as I know, they won't let a push car run the track, but you could have a fellow racer tow you from the big end.
  21. trksmth
    trksmth
    I must say. I love your car, it's got that nostalgia look I hope ours will, when we get her done.
    I'd pay admission just to watch your car run all day! Nice to have a crew to share it with.
    Mike
  22. trksmth
    trksmth
    Friday I picked the car. Here is what the car looked when we picked it up. The body was just sitting on it. So now to get it back together!
  23. trksmth
    trksmth
    The tank and valve covers showed up on Friday. I put the tank on it Fri. night. I picked up the other engine on Thursday and misc. parts. The other engine is a 283 that's rebuilt. I'm just using a a dumby, until we find a 292ci.
  24. trksmth
    trksmth
    Here's what the engine looked like when we picked it up. We are dressing it up to like the way it was raced. Take a look at the distributor gear, the way it was installed? The DL. high school rebuilt it, so I'm told.
  25. I think that distributer gear would make me question the entire rebuild. I think for the cost of a gasket set, I would tear it down and make sure the rods are in the right way along with the pistons at least.
    Oh and are you going to repaint the bad spots on the frame and body? I think you should leave it as it is. You can always restore it if you must.
    Keep the pictures coming!
  26. racinman
    racinman
    You can't change History... You can only screw up the future!
    racinman
  27. vintagehotrods
    vintagehotrods
    Great story!! I'd love to see it run again. I was watching it on Ebay and I wondered where it was going to end up. Congratulations!
  28. trksmth
    trksmth
    I felt the same if I can trust the rebuild or go though it, It's just a dummby for now and will look good for the show.
    NO PAINTING on this car, just it's natural paint cracks and rust on this car!
    Here are some pic of engine so far.
  29. trksmth
    trksmth
    Can I steal that for my signature? What a great way to put it!
  30. Rehpotsirhcj
    Rehpotsirhcj
    super cool Mike
    keep with the updates, can't wait to see more!
