Newbie from Wisconsin - 38 chevy
Discussion in 'New to the H.A.M.B.? Introduce yourself here!' started by wideglide, Feb 7, 2010.
  1. wideglide
    wideglide
    I'm 33 years old starting my first street rod build. I have a 38' chevy 2dr sedan. Started in December with chopping it 4". Have it mostly fitted and welded up. Now shaving the drip rails. Next I'm gonna start on the frontend. Going with MII set-up, I'm just not sure if I'm going with stock height spindles or 2" drop. Does anyone have any info or recommendations on what height spindle to go with?
    Thanks for taking the time to read this and I look forward to any help with this.
    -Paul
  2. Eb4Prez
    Eb4Prez
    Welcome from an Arkie from WI !
  3. 38hemi
    38hemi
    I'd go with the 2" dropped spindles. I've got a '39 Chevy coupe that I built 20 years ago (still not done). It's got a Nova front suspension and a Morrison Ladder bar/coil spring rear set-up. It sits low (almost too low). I'm currenly building a '38 Chevy coupe and I'm using a Mustang II IFS with 2" dropped spindles and a Morrison 4-bar rear with air bags all around. I really like the way it sits.
    With a 4" chop your sedan will scream "LOWER ME!!" It'll look awsome.
  4. Stefan T
    Stefan T
    from Sweden
    welcome to hamb from sweden
    any pics??
  5. Welcome from Iowa! Will you be going to Symco in August?
  6. wideglide
    wideglide
    Here are a few pics.
  7. rayford
    rayford
    from calhoun ga
    welcome from Ga
  8. VonWegener
    VonWegener
    Welcome from Apple Valley, Calif.
    VonWegener
  9. Welcome fellow Wisconsiner
  10. Draggin wagon
    Draggin wagon
    Welcome friend! Keep the pics comein with the progress on the ride...
  11. Cliffy
    Cliffy
    Welcome welcome welcome
  12. dashman
    dashman
    from Viroqua WI
    Welcome from Viroqua!
    Dashman's Hot Rod & Speed Parts
  13. Max Gearhead
    Max Gearhead
    from Wisconsin
    Welcome from southwestern Wisconsin
  14. yellow wagon
    yellow wagon
    from WI
    Welcome Wisconsinite!!
  15. OshkoshRob
    OshkoshRob
    from Oshkosh
    Welcome to the HAMB from Oshkosh!!!
  16. theczking
    theczking
    Welcome from West Virginia I did a 38 sedan awhile back and channeled the body 4 inches so the stock Ms 2 spindles worked fine otherwise I'd use 2 inch drops I'll bet that chop was a hellof an undertaking
  17. wideglide
    wideglide
    It was a hellof an undertaking. All in all it went good. I thought I had it pretty well palnned out, but I sure learned alot along the way...the next one should go alot better (and faster).
  18. Carguy365-24-7
    Carguy365-24-7
    Welcome from Appleton! Stick with us you'll learn alot !!
  19. chubbie
    chubbie
    hello from cold NW Iowa... looks like a good start
  20. 343w
    343w
    Welcome Wideglide, (maybe weldguy would be more fitting). That's quite the undertaking for the first chop, good job man! Enjoy the Hamb and keep on cuttin!
  21. rustyhood
    rustyhood
    Welcome from Louisville Kentucky.
  22. Welcome from Melbourne
  23. ARTSWRK
    ARTSWRK
    Welcome from Kansas. Speedway Motors has a 2"drop crossmember that works well, saving money on spindles.
  24. farmer12
    farmer12
    Welcome from the Netherlands!
  25. wideglide
    wideglide
    Thanks for the advice on the 2" drop crossmember...But I just ordered a complete MII front end with crossmember and 2" drop spindles. Says 2-4 weeks delivery, we will see what happens.
  26. rockguy92
    rockguy92
    Welcome from O-HI-O
    The Rock
