Cadillac 429 Intake Modifification
Discussion in 'The Hokey Ass Message Board' started by Dr. Frankensickle, Feb 8, 2010.
  1. Dr. Frankensickle
    Dr. Frankensickle
    from Kansas
    Who has actually modified an intake to fit the 429 caddy,I would like to talk with you.Welding and machining buddies of mine can help me.Lets chat.
  2. ryno
    ryno
    what are you looking to modify?
  3. Dr. Frankensickle
    Dr. Frankensickle
    from Kansas
    a dual 4 setup is what I had in mind,Not really interested in the Log type manifolds
  4. ruggs
    ruggs
    Their is a company in New Mexico that has an adapter that alows you to use a Ford intake on the 472 and 500 caddy motors. I can't find the link on my home computer, got it at the shop. You can probably google it...........ruggs
  5. Dr. Frankensickle
    Dr. Frankensickle
    from Kansas
    Thanks,However the 429 Cadillac is a completely Different Animal from the 472-500-425 series motors
  6. panic
    panic
  7. Sonny Day Out
    Sonny Day Out
    Dr,
    I belive that 49-67 manifolds will work ! That is 331cu. in. to 427cu. in.
    Try http://hotrodcaddy.com/?p=17 for more information !
    I have 55 and 56 factory 2x4s , and a Detroit
    Engineering 2x4 !
    Good Luck,
    Sonny
  8. Abomination
    Abomination
  9. Dr. Frankensickle
    Dr. Frankensickle
    from Kansas
    I have a 1967 429 which after researching is a one year only head and intake set up.as I understand it the 67 heads are squeezed in compared to the 66 heads,This explains Why my 390 ,365 cast iron 2 4bbl manifold is too wide for my set up.It is off far enough to negate any port work and angle milling,not enough meat in the casting.Looks like its run log manifolds or build one from tubing.
