Not another falcon "GASSER"
Discussion in 'The Hokey Ass Message Board' started by BrickTopp, Jan 4, 2010.
  1. stretch 1320
    stretch 1320
    Wow dude, it looks really good from here!
  2. stickers
    stickers
    An Original Falcon from the 60's "I can let you know that the green Falcon was driven by Donnie Jackson who was from Clarkston, Washington and he was also running a 300 cubic inch 6 cylinder with a 4 spd in H/M" Donnie was I believe world record holder and cl*** champ 60's and early 70's. He was a "Tuner" could make anything run. He could drive em and his wife Judy did some kwik driving times also in the car.
      45.1 KB
  3. BrickTopp
    BrickTopp
    Body work never gets any glory so heres some pics. Dans handled most .. actually all of the bodywork so far filling holes and fixing rust and straightening the panels. shaved off all the door trim below the belt molding, and still up in the air on the hood.
  4. BrickTopp
    BrickTopp
    well this is what the header will pretty much look like, one side down other to duplicate. the whole goal was to have it dump and follow the fenders wheel radius. there will be a full exhaust, you dont think its just meant for the track do you :D. the right side door bodywork is also done.
  5. dirttoo
    dirttoo
    Is that stock pitman arm going to work are are you using somthing else?
  6. BrickTopp
    BrickTopp
    to be honest dont know yet about the steering. keep pushing it aside to get other things done but i know its gonna test us a little bit just by looking at it. youll find out soon enough cause the check list is gettin smaller
  7. Falcon Gasser
    Falcon Gasser
    I used the stock pitman arm on mine, it worked out good.
    Jon
  8. fredb
    fredb
    Cool post
    1969-70 Project Falcon
    first car I ever built was a '60 Falcon stuffing in a hilborn injected 421 Poncho motor (got for free). Used front axle from econoline van, removed inner fenders and moved firewall back about 5" to make room, stripped out interior and replaced with aluminum and two fibergl*** bucket seats (no padding). Ford 9" w/locker 4:40. Aluminum dash panel with SW gauges...ran good, but never had the $$$ to completly sort out.
  9. dirttoo
    dirttoo
    Got any pics? Looks like mine will hit the oil pan big time.
  10. Ray C's son
    Ray C's son
    Man, your work is just top effing shelf. Any updates?
  11. fab32
    fab32
    Keep the updates coming. Your doing a great job so far.
    Frank
  12. BrickTopp
    BrickTopp
    thanx for all the comments. yeah I have been distracted with work, detroit and world of wheels but there is more coming, just have to get all the pics gathered. im not trying to jump the gun but the goal is to have it at a certain drag event at DA Grove in the beginning of may so fingers crossed that all goes well in the next 2 months cause i never make goals with my own cars.
  13. El Coral
    El Coral
    from Argentina
    please more pictures
  14. BrickTopp
    BrickTopp
    well its been long past due since i update my post and i thought id share the rear suspension. We used a maverick rear end and shortened it an inch and a half on both ends to **** the wheels in a little for launching clearances. theres nice new moser axles on there way with long studs. the whole system is a leaf spring ladder bar. im kinda thinking coilovers i could have had done in a day. but it was cheaper. the 8 inch sits on full floaters that ride on the springs. i did move the locating pin for the leafs forward an inch to keep my rear wheels centered in the wheel well. the pin also acts as a stop now if for whatever reason something is to break. lets hope not with 3/4" rod ends and a small block i think were on overkill. i will have a plate bolted a 1/2 inch behind the floaters to act as the rear stop. i did put on a panhard bar now that the rearend can move side to side with a left and right hand threaded ends for ease of adjustment. as for the ladder bars they have 3/4 inch rod ends and urethane bushings on the ch***is end for street driving. it all gets tied in to all crossmember that slams into the roll bar and subframe connectors. i also made new shckles for a little bit of an adjustment even with the adjustment in the floaters. pinion angle is set just under 3 degrees.
  15. 60 ford
    60 ford
    Cool build, Love Falcons. Need time to work one mine,would like to have mine done this summer.
  16. BrickTopp
    BrickTopp
    for the steering we used camaro tie rods to connect the stock box to the steering arm because they were the right size for the tubing we were using and gave us the room needed to use the pitman arm on the box. not super cheap at 50 bucks a pop but for durability no compromise. and for connecting the two steering arms we used left and right hand threaded rod ends. the right steering arm we extended a bit for turning radius and reamed both the extension and pitman arm for the tie rod ends.
  17. Shizzelbamsnapper
    Shizzelbamsnapper
    from Ohio
    Not to be negative but the drag link has too much angle, when you hit a bump its gonna flatten out and make the wheels turn causing it to be all over the road. I just did this setup on mine. The drag link needs to be as parallel to the tie rod as possible.
    Looks great other than that. Thanks for the header build thats next on my list and the pictures helped out a ton.
  18. BrickTopp
    BrickTopp
    no your not negative at all. if i didnt want opinions i wouldnt post. thanx for the input.
  19. BrickTopp
    BrickTopp
    all right this is my fix to bump steer. make a new steering arm. caliper works, its still in the rear and everything is level and i scored a little more turning radius with no rubing anywhere. the lower steering arms will need a little tweaking for the caliper but nothing major. pictures explain and its 3/4 plate.
  20. Shizzelbamsnapper
    Shizzelbamsnapper
    from Ohio
    That looks great, it should be good to go now.
  21. lorodz
    lorodz
    looks great
  22. Gotgas
    Gotgas
    from DFW USA
    Holy ****, that steering arm is awesome! :D So is the rest of the car. :cool: Not sure if there is any other way to build a Falcon!
  23. I SMELL SMOKE
    I SMELL SMOKE
    great work!!! keep it up!!!
  24. Haven't seen this build for awhile. Any new updates?
  25. 60 ford
    60 ford
    Id like to see some pitcures
  26. Kerrynzl
    Kerrynzl
    Cool at***ude! Cool Car!
    Looks like your bump steer is sorted out , nice work.
    If the bump steer is still a problem, I have a recommendation.[ and to others open to suggestions ]
    Use a panhard bar, identical length as the cross steering arm, same angle [ and parallel to the steering arm ] and mounted on the ch***is on the same side as the steering Box.
    The idea is to have the RH side of the axle beam move in an arc identical to the cross-steering arm arc [ it cancels out bump steer ]
    I've seen this on a vintage dirt car when my dad raced in the 60's
    Again Cool Car !!!
  27. HotRod60F100
    HotRod60F100
    Wicked buildup so far! good luck with the rest of your project!
  28. low budget
    low budget
    from Central Ky
  29. newfalconowner
    newfalconowner
    from NS Canada
    nice work on the arm..
