School me on headers, specifically Zoomies!
Discussion in 'The Hokey Ass Message Board' started by Don Moyer, Feb 11, 2010.
  1. Don Moyer
    Don Moyer
    I did a search for headers here on the hamb and really didn't find anything. So I am looking for input on design and build tips. I am building a set for my current project and want sound and performance. Performance as in the car will only see the track. Sound as I know that headers with collectors perform better, but because the car is for nostalgia racing, I will sacrifice some performance for the sound of Zoomies. I found a couple calculators on the internet:
    http://www.wallaceracing.com/header_length.php
    http://www.thedirtforum.com/headercalc.htm
    What is the theory of bigger vs. smaller primary tubes. What about the length of the tubes. How about the gains or benifits for "stepping" the pipes at the end. What about pointing up, out, or down? Any difference. How about tricks for cuting and figuring out angles for the pipes. Set up, etc....share your expertise for all the hamb....or just point me to a similar thread that I missed while searching!
  2. Algon
    Algon
    Don, Have you flowed the heads? Head/intake flow port size length, cam rpm it all counts on a real set of tuned Zoomies. Generally a longer/ smaller tube is more torque-midrange while shorter larger tubes are for higher rpm with no back pressure. To make a real difference you need a base line to go off of. It's one of those things that sometimes the engine likes something other than you think it would too... You can also step them both ways and testing of a similar engine helps. Maybe someone with a similar combo would be helpful?
  3. pasadenahotrod
    pasadenahotrod
    from Texas
    easy enough, Zoomies do not belong on the street.
  4. beatnik
    beatnik
    He said "the car will only see the track", try reading the posts before spouting off.
  5. Phil1934
    Phil1934
  6. oj
    oj
    What engine? naturally aspirated? What body, enclosed or open engine bay? Not quite enough info.
    Here's my door car w/sbc, fuel injected, 4 steps (1 7/8 to 2 1/4)
  7. 117harv
    117harv
    Zoomies give you that cackel sound as each piston has it's own tube, you don't get the crossover/feedback of headers with a collector.
    You might make some adjustable baffels to tune the engine to what it likes as Algon mentioned in his post. I say make some and run them, after all you said you were going for the nostalgia look.
  8. Algon
    Algon
    I'll say this, with the set I'm building right now based off of other combinations, dyno pulls and everything listed above the first calculator is almost identical to the set I am currently building,the second is two inches longer on the primary...
    Why can you not run Zoomies on the street? Outside of preference that is, you can tune baffles to them for sound and correct pressure?
  9. mercury Bill
    mercury Bill
    Unless you have one hell of an engine zoomies sound like ****. Thats a fact
  10. my bud made a set of zoomies and has 8 small baffles slid into them. Looks wicked mean and tolerable.
  11. Algon
    Algon
    Come on Don... What are you working on? Besides why does "Mr p***ing guy's while still standing on the back bumper" need help any way? :D
  12. Don Moyer
    Don Moyer
    I am working on Mikey Harts old 33 Willys. (Pure Determination) I am running a BBC with Crower injection right now. I plan to later to go blown with it...
    nice car! how do the steps work?
  13. Don Moyer
    Don Moyer
    Thanks for the laugh! Not working on the Rebel Reaper...new territory for me with a Chevy...
  14. Don Moyer
    Don Moyer
    I picked up a couple sets of swap meet headers to cut up to start with...
  15. storm king
    storm king
    Weedburners would be more nostalgic than zoomies for that Willys, and like Murcury Bill said, if it's not one heck of an engine, they do sound like ****. I'd go furhter and say if it's not a blown mill they'll sound like carp.
    But it's your car, so have fun!
  16. lippy
    lippy
    from Ks
    Don, blown alky? Gas? If it's blown, probably all you need to be concerned with is keeping the flames off your pantlegs. :D Oh, BTW, is that stool on the other side for visitors? Lippy
  17. hog mtn dave
    hog mtn dave
    I've been going the opposite direction. Zoomies just don't sound right to me unless the engine has a blower on it or injected nitro. After running zoomies for the past 14 years we just built a set of conventional collector headers. I'm either lazy or a slow learner. The motor sounds much happier now.
    Zoomies do have the "look" if built right though. Good luck. Have you tried headerdesign.com?
  18. 150J/F
    150J/F
    They will sound good unblown if you have plenty of compression.
  19. Ruiner
    Ruiner
    To me, zoomies are for blown or nitro engines that simply need exhaust out quickly...but I'm uneducated on them, so that doesn't mean much...I'm used to building collector style tuned headers, and I'm happy with staying in that realm for my personal projects...but I love learning new things, and hadn't ever thought of zoomies as being tuneable...good luck with the car Don, even if it is Chevy powered :D
  20. Don Moyer
    Don Moyer
    It is funny how you guys think that zoomies will sound like ****? My other car sounds really good, and that amc motor is not that crazy...and Littlemans truck and coupe also sound pretty damn good....but I think weed burners might be the look I am going for...I will look and a couple of the sites suggested tonight. The car had zoomies on it back in the day, but I want to be able to fit the car in the front of my trailer and the zoomies would cause a problem with that...
  21. Don Moyer
    Don Moyer
    I am curious on what your performance gain will be?
  22. hog mtn dave
    hog mtn dave
    Yeah, we're curious too. Making some fuel system changes and if it picks up I expect that will have a lot to do with it. I'll miss the look of the zoomies
    and blowing the hats off of peoples heads on the burnout. You'll have fun with yours. Should be quieter inside the car than collector headers too.
    It does sound better.
  23. Ruiner
    Ruiner
    I will say that higher compression and blower motors sound better through zoomies than your buddy's stock 305 SBC does...
    lower compression motors with smaller diameter tubing can sound half-***ed decent through zoomies...but it'll never beat the real ground shaking sound of a built motor pushing big HP...
  24. captmullette
    captmullette
    Run em if you want, ilike em also, gonna put em on my 31, of course i thought i was wrong once but i was mistaken................
  25. Don Moyer
    Don Moyer
    Sure, your welcome any time Lippy...if it looks uncomfortable, that is because there is a Honda 10 inch wheel sitting on it...
  26. Algon
    Algon
    As a historic car it would be a shame to alter it... what if the lower step section was removable if nothing else? I can't see you going wrong with the same design with a 2-1/4" tube... You probably want to keep the engine under wraps but what are we talking about 800-1,000hp give or take? Being blown the header is usually considered less critical unless you are building a serious mountian motor or running Nitro. It's your stack injector that would really come alive by splitting hairs but here as long as it's not choked up you won't see a major loss or gain the way you do naturally aspirated.
  27. panic
    panic
    You're giving up quite a bit of power. A collector system is also far easier to tune on the car.
    BTW: fastest tuned length system for a single pipe is a megaphone - the original Ramcharger Plymouth used them.
    some adjustable baffels to tune the engine:
    Baffles in to shut the motor off.
    Baffles out whenever the motor is running.
    Correct amount of pressure for a race engine: none, not one, never, ever.
  28. Don Moyer
    Don Moyer
    Still cutting and placing pipes around to find something I like...
  29. darrin1999
    darrin1999
  30. ...doc...
    ...doc...
    from Houston
    zoomies are good,...if you want them run them
      233.1 KB
