air ride with hard lines
Discussion in 'The Hokey Ass Message Board' started by mick_b, Feb 12, 2010.
  1. mick_b
    mick_b
    from scotland
    whats the best way to go about this. also does any one have pictures of installs which there air management has been done this way. is there any pros to hard lines than nylon lines.
    cheers
    mick
  2. dirty petcock
    dirty petcock
    I think the hard lines will look better. nylon is quick and ez. My lines were nylon and worked fine, never leaked anything. But my valves would freeze up in the winter and I would be stuck on the ground. ahaha
  3. 6berry
    6berry
  4. mick_b
    mick_b
    from scotland
    that happened to me on thursday morning. not best thing to happen when your trying to get to work. so i left it. haha.
  5. mick_b
    mick_b
    from scotland
    cheers for the link 6berry. looks very helpful. just what i was after, any got any install pictures.
    currently run 8mm lines, want to upgrade. but limited due to my front stut units on my car.
  6. Synthetic lines can easily be repaired most anywhere. With hard lines it will be much harder work let alone trying to find a torch to solder joints together. I don't think it's worth doing!
  7. mick_b
    mick_b
    from scotland
    you reckon. looks tidy with hardlines. and again less worry if caught to an extent.
  8. krylon32
    krylon32
    from Nebraska
    I've done several ch***is with shockwaves or bags plumbed with SS Hardlines/AN fittings and braided SS lines at the ends to the bags. Used thru the frame fittings in front that matched the thru frame fittings for the brakes. Since speed wasn't an issue I used 1/4 inch hardline and #4 flex lines. Worked out good.
  9. Glen
    Glen
    I ran stainless braided lines in the engine compartment and under the rear suspension, it worked very good. I used my local parker store to make the lines.
    If you need help with the hard lines you might look up some of the lowrider guys....they run a lot of it.
  10. dirty petcock
    dirty petcock
  11. That car also has no engine, trans, interior, bracing or floorboards. It also runs WAY higher pressure that any normal bag system should run. It is really kool to watch, though.
  12. Streetwerkz
    Streetwerkz
  13. blue collar guy
    blue collar guy
    we did james truck with all stainless hard lines here is a few pics
  14. mick_b
    mick_b
    from scotland
    thanks. how hard was it too do? quiet straight forward
  15. Tin Can
    Tin Can
    I was thinking about this for my 53 too when the time comes to start plumbing the airbags
  16. chickenridgerods
    chickenridgerods
    from DSM, IA
    It wouldn't be any harder or more involved than routing brake lines.
  17. mick_b
    mick_b
    from scotland
    never thought of it like that to be fair. fail on my behalf haha
  18. K13
    K13
    Do guys just use AN fittings to plumb them?
  19. you guys need to be putting "air brake antifreeze" into your system, about 3-4 cups full is what you should do every winter..works great and you'll never have it freeze up again can get it at any semi truck stop or napa
  20. outlaw1949
    outlaw1949
  21. so did you use both hardlines and nylon lines on your set up then?
    I'm thinking about this for a future project
    anyone who has done this whats the cost of doing an entire car with 3/8 hardline?
  22. GrantH
    GrantH
    can anyone specify the type of stainless tubing? Also, for anyone skimming through, that street trucks article says to use TYPE L copper tubing for airlines. Just looking for the stainless type!
  23. carlos
    carlos
    from ohio
    Go to tractor supply buy Hydrolic tube by the length an -fittings 37 degree steel braided lines
  24. I like that video.. the car goes boingy boingy
  25. GrantH
    GrantH
    is this in response to my post? If so, i'm not really looking for braided. I've seen people using stainless hard line, like on that first page. Also, if anyone knows by looking, are those AN style fittings, PTC, or swage-lok style? Sorry for the questions, but I can't find the answers to save my life.
  26. I believe most people use the swage-lok fittings
