48 f1 door lock
Discussion in 'The Hokey Ass Message Board' started by zeke51, Feb 12, 2010.
  1. zeke51
    zeke51
    from arizona
    Okay, finally got eh hinge pins out. doors are almost stripped ready to chop. But now I cant get the frikken door lock out! Geeez, does anyone know how to take these out without a plasma cutter? Thanks
  2. No horseshoe clip?
  3. Deuce Roadster
    Deuce Roadster
    I believe the lock is held in by a small set screw.
    I had a 48 F-1 years ago. I have had a bunch of older Fords since then ...
    so I may be remembering the wrong Ford. :confused:
    But look where the door jam is ( in the area of the lock )
    Look for a small set screw.
    :D
  4. green53ford
    green53ford
    from Wisconsin
    Set screw in door jamb. PROBABLY UNDER THE WEATHERSTRIP.
  5. TERPU
    TERPU
    Small hole behind the weatherstrip, it should be a hex key.
    Tim
  6. zeke51
    zeke51
    from arizona
    Thanks deuce, green and terpu! That was it. Must have still been emotionally drained from the hinge pin removal ordeal! lol
  7. HOT40ROD
    HOT40ROD
    from Easton, Pa
    What the last three said. If it does not come on then shoot some penetrating oil in the hole and let it set for a couple of days.
  8. zeke51
    zeke51
    from arizona
    Thanks hot too!
