Front leaf spring source?
Discussion in 'The Hokey Ass Message Board' started by Antny, Feb 15, 2010.
  1. Antny
    Antny
    from Noo Yawk
    I have a dropped I-beam front axle (unknown manufacturer), kingpin-to-kingpin measures 47.25-inches center-to-center (at the top of the axle), 48-inches (at the underside of the axle), it's spring perch bosses measure 38.5-inches center-to-center. I'm using split bones, in case that's important. According to most websites, I'm supposed to deduct 4.5-inches for the perches/shackles, for an overall spring length of 34-inches, eye-to-eye. Anyone know of a source for a leaf spring with this dimension? I've searched all the usual suspects and come up empty. Any help would be appreciated. Thanks in advance! :)
  2. cruzincougar
    cruzincougar
    got a Speedway catalog?
  3. Antny
    Antny
    from Noo Yawk
    No, I searched their website though.
  4. Fogger
    Fogger
    Contact Posies for one of their rolled and tapered leaf springs. Check their web site for info.
  5. VAPHEAD
    VAPHEAD
    sounds like a 1937 and up axle.
    (lost a touch of width when dropped)
    Posies 1009 spring.When running spring on top.
  6. zjb69
    zjb69
    do you have an outfit around that makes replacemant spring for comercial trucks, most of the time these out fits also make springs for p***enger vehicles, you just call them up with the info and they can have them bent up...here in oregon(on the other side of the continent) we have oregon spring..
  7. Antny
    Antny
    from Noo Yawk
    Yep, sure do. I'll give them a try. Thanks!
  8. Antny
    Antny
    from Noo Yawk
    Thanks, Vaphead!!
  9. Anderhart Speed
    Anderhart Speed
    Yeah, check out posies, we have guys calling in all the time with special spring requests, and todd is very good at filling those requests. Tell him what you are doing, and he'll be able to set you up with exactly what you're looking for. website is www.posiesrodsandcustoms.com. Good luck!
  10. Antny
    Antny
    from Noo Yawk
    Will do! First thing in the am. Thanks folks!! You guys/gals are da bestest! :)
