Hood Louvers on a 35 Ford Coupe
Discussion in 'The Hokey Ass Message Board' started by Blown35, Feb 17, 2010.
  1. Blown35
    Blown35
    I'm considering have louvers on the tops of my stock 35 Ford hood - question is how many louvers and what size. Do you start up front on the narrower end with to sets per side running for/aft and increase to three across toward the back? I'd appreciate suggestions and pictures of 35/36 hoods with louvered tops - Thanks:D
  2. 58Lincoln
    58Lincoln
    Here is a 36 Ford hood I had done.
    100 louvers in all. I believe they were 3".
    I chose to use all the area I could on the hood tops, function before form.
    You may wish to make the middle row of louvers shorter to make the 3 rows more symetrical.
    I looked at a lot of hoods, counted a lot of louvers and took a lot of photos before I made a decision.
    Good Luck
