Molasses bath made me a believer !!
Discussion in 'The Hokey Ass Message Board' started by drfreeze, Oct 14, 2009.
  1. That is an interesting point....I had not thought of that.
  2. bloodyjack
    bloodyjack
    Works on body parts too
  3. big creep
    big creep
    wow thats rad! i never knew? thanks guys!
  4. Okay, here's my dilema, I have 2 Borg Warner T-10s, one is a cast iron case and the other is an aluminum, both early '63 and '62 I belive, regardless, my question is will this work as both were stored in a damp enviroment and are seized up tight! Thoughts on this??
  5. Chucky
    Chucky
    I didn't read all the posts but, how did the cookies taste?
    I vinageregegededd mine last summer, after flushing it out twice - ****s to buy anti-freeze over and over and over.......GOOD POST!
  6. stealthcruiser
    stealthcruiser
    Don't use it on the aluminum.
  7. 343w
    343w
    You could spray paint the surfaces you don't want to pit, then after the soak remove the paint with stripper. I don't see why that wouldn't work. The mol***es is real cheap out in the small country town grain stores, less than $2 per gallon, I took 5 gallon bucket and they fill it for less than $10.. What a deal and it's green.
  8. One of the previous posts stated that it will eat aluminum and zinc. So don't put your ****** in there if it's go any aluminum.
  9. Got this tip from 97 on the Feb Banger thread:
    "You can mask the bearings with wax or other electroplating methods... the latest method is to
    Use Dymac Speedmask....
    http://www.dymax.com/products/masking/index.php
    it is a resin for protecting machined surfaces temporarily during electroplating and acid cleaning processes, remember to plug any oil feed holes from the other side too.... "
  10. oldpl8s
    oldpl8s
    Does everything come off with a rinse is do you need to s****e and brush off the "slag". I brush on a product (I think its called Rust-Mort) that I got at an auto paint store. The next day the rust is turned into a black sludge that I need to wire brush off. That's ok for the outside of the part, but wouldn't work for oil galleys etc.
  11. 13
    13
    from Sultan, WA
    Yeah I saw that one, dump it on the lawn/garden. But that does not necessarily mean it's right, kind of like dumping anti-freeze into a storm drain?
    I'm no scientist, but there is obviously some chemical conversion/reaction going on there. It would be nice to know [for certain] there is no harm done putting on the lawn, especially where animals are present.
  12. mart3406
    mart3406
    from Canada
    Whatever you do, DON'T seal it! The drum NEEDS to be vented to the atmosphere! Fermentation produces carbon dioxide gas - lots of it - and if it's not able to vent , you could possibly build up enough pressure to cause the drum to burst , or at the very least, severely injure you by blowing the lid into you're face when you go to remove it!
    Mart3406
  13. If you have a lid on a drum of this stuff wouldn't it cause the drum to expand if sealed?Could you vent it through a water filled vent like they use in wine making?
    Nothing like creating a time bomb!! Any info? Rob.
  14. mart3406
    mart3406
    from Canada
    [QUOTE=Mart3406
    "Whatever you do, DON'T seal it! The drum
    remove it
    Rob - woody 29 dodge;4917736 wrote:
    "If you have a lid on a drum of this stuff
    info?
    [/QUOTE]
    No, all that would be needed is to vent
    the drum to the atmosphere, via a hole
    in the the lid. The purpose of the
    water-filled vent used when making wine
    or beer is to allow the CO2 created by
    the fermentation to safely vent, while
    preventing airborne bacteria that could
    contaminate the fermentate from entering.
    You'd only need the water-filled vent thingy
    if you planned to drink the resulting goop left
    over after you finished de-rusting your
    block....and I woudn't recommend anyone
    try that!!! :eek::eek::eek:
    Mart3406
  15. martin
    martin
    Im in, This is to simple to be true, and I only found it two days after iv`e taken a pile of rusty parts to the sand blaster :( Good thread, Thanks.
  16. barney rubble
    barney rubble
    I bet the kids love what you did to there sand box. lol.
  17. rustyford40
    rustyford40
    from Mass Bay
    In 1919 a 2,300,000 tank of mol***es ruptured in Boston, killing 21. It was a wooden tank with steel bands.
  18. oldpl8s
    oldpl8s
    They must have been de-rusting some BIG parts...
  19. 55 dude
    55 dude
    note of caution don't dump the old mol***es into the storm drain all at one time! the drain nazi's will find you because even though its biodegradable large amounts of anything will throw off the ph in the treatment plant and pisses them off! my brother in law works at a local grocery store and the freezer took a **** one day and all of their ice cream was quickly melting so his boss tells him to just start opening up the packages and wash them down the drain in the back of the store. all of the sudden the drain nazi's showed up and fined the hell out of them. they were going to fight it in court.
  20. THE SPEED ADDICT
    THE SPEED ADDICT
  21. Well I have my first results from my mol***es bath. I got soem differential parts that were a bit crusty from years of sitting so I bought some mol***es and made up a pail of 5:1 mix and dumped the parts in.
    Before...
    And after...
    The side bearings were seized solid and after a month of sitting I can turn them freely!! This has made a believer out of me!!
  22. It was the raw material for explosives. After hostilities ceased it was left full, a level it had never been before during production.
  23. Kan Kustom
    Kan Kustom
    Been seeing these threads.Gonna try it this summer.
  24. BillyBobsSpeedShop
    BillyBobsSpeedShop
    I just finished some parts and they turned out good. My question is can I reuse the mol***is? I mean can i put another part or parts in the tank and leave it 4 weeks and it clean them also?
  25. Hot Rod Michelle
    Hot Rod Michelle
    Well, I for one am glad he posted this. Thanks Drfreez for posting. And, I'll tell you why, Tman. How is one to search for something that is not known or not common knowledge. What key words would one use to produce an effective search, when this is the first time, a novice like me, has ever heard of such a process.
    This is great tech info for those of us whom are not in the know.
    Its funny, how old this thread is, and yet its the first time I'm seeing it.
  26. I reused the mol***es for a couple months, and a bunch of different parts. After a while though I started getting these little nodules on the clean metal surface, almost looked like salamander eggs. Kind of gross, and I had to take a screw driver and flat s****per to get them off.
    So I would recommend cycling it out every couple months or so.
  27. Tim G
    Tim G
    Now i just got to find where i can get mol***es in bulk in the UK :)
  28. X38
    X38
    Anywhere that sells horse/farm stuff.
  29. dadseh
    dadseh
    check your local horse feed store, or, animal feed stores have it.
    Damn X38 !!! Im too slow typing.
  30. mart3406
    mart3406
    from Canada
    [ "A Mol***es bath made me a believer!!"]
    A mol***es bath made you a believer??? Hell,
    just the threat of one would probably be enough
    for me!!!!:eek::eek::D
    Mart3406
