what have some people used. my car has a set of low back buckets.. not really feeling that. i have an s10 bench but...i dunno. its kinda small. any better sources for a seat?
mid 70's nova split bench in mine made seat bracket for height. I had a stupid truck seat in it before but when people got in both front seat p***angers would have to get out .. lol...
Can't go wrong with what came with the car. Stock bench seats are comfortable and fit the car well. A good upholsterer can contour the seat with foam before covering it if you want. I am going to run my stock bench in my '50. Since I chopped it 4 inches, the seat was too high. so, I sectioned the risers about 2 3/4 inches. I had to modify the floor in a few places - flatten out the tunnel, and make pockets for the runners at the rear. I also had to tweak the adjuster linkage that runs from side to side, I think I actually reversed it for clearance. Lastly, I had to trim the side valence to each seat. If you take your time and think it through, it isn't a bad project. Sorry, no pics right now. PM me if you want me to take pictures of what I did to my seat. I would need some time to take the seat out. I may do it anyways and post here when I have time, but it may be a while. Andy
Just went from S-10 buckets that came with the car when i bought it to the original seat. I hated the buckets and a friend found the stock seat with good springs for 50 bills. The seat does need to be recovered, but nothing fits like the original.
if i had a stock seat, i would use it. the upholstery is all recovered so redoing a stock seat wouldnt be a big deal to me...if i had one.. just looking for other options until i come across one.
Mine has an early 80's split bench from a cadi in it. Nice part is they are a bit thinner so I fit with the chop.
I believe a 65 el camino bench would work. I had measured it and its only about an in narrower and an inch lower than a stock seat
We have a pulled out Mini van seat, can't remember if it was a second or third row. Works GREAT! It is in a Sedan Delivery,48 Chevy. Did some mods on the mounting and like it way better than the 2 different sets of buckets we tried. Just measured the width and depth of the area and bought one from a custom shop that was tearing them out , found it on Craigslist!
My 51 has a stock bench seat which will not work with the cage. So I've s****ped the plan to use stock and will be going to a pair of buckets. I just have to find the right ones that won't look too out of place. Indiana is a long ways to come for seats. But, other than needing recovered, they are in good shape.
