Daughter was helping... found a mystery part. Help!
Discussion in 'The Hokey Ass Message Board' started by kelseydum, Feb 17, 2010.
  1. kelseydum
    kelseydum
    I was cleaning up after getting everything back together and found this part laying in a towel that I had my old transmission filter and pan sitting in. My 5 year old daughter was "helping" me and was messing with stuff from time to time. I thought I kept a good eye on her but found this part. The only thing I removed from my ****** was the governor, filter and pan. I inspected the governor right before I put it in so I don't think it came from that.
    Any ideas? It's a TH400 transmission. I was working on some other front suspension parts too but I don't recognize this piece.
  2. FoMoCoPower
    FoMoCoPower
    Looks like a sleeve for a rubber bushing.
  3. THE_DUDE
    THE_DUDE
    So does it shift??????
  4. Skeezix
    Skeezix
    from NorCal
    Alignment dowell from bell housing
  5. SchlottyD
    SchlottyD
    Does look like a bushing sleeve for a shock or something. She's just trying to collect some parts for her future build.:D
  6. Larry T
    Larry T
    If your running a deep pan, there is a spacer that goes over the bolt that holds the filter off the bottom of the pan. Kinda looks like that could be one.
    Larry T
  7. skullhat
    skullhat
    looks like an alignment dowel to me as well, but i couldnt tell ya where it goes
    skull
  8. SchlottyD
    SchlottyD
    :rolleyes: I believe we have the WINNER
  9. Natedrag
    Natedrag
    The center bolt that holds the filter, some have a sleeve like that between the filter and valve body. I think the deeper pans do, I can't remember.
  10. kelseydum
    kelseydum
    Cool, that makes sense (goes with the filter bolt).
    The filter seemed to go on snug... Do I need to put this sleeve back in? Will it mess anything up without it?
  11. onlychevrolets
    onlychevrolets
    that would be solid and not that long
  12. Always wondered what a k'nipling pin looked like!
    Bill.
  13. sloppy_J
    sloppy_J
    and tapered on the ends
  14. kelseydum
    kelseydum
    Well, I'm guessing the logical thing would be the sleeve for the filter bolt. I hadn't put fluid in it yet so I'm gonna drop the pan back down and put it in for peace of mind.
    Thanks for the help!
  15. highboy_04
    highboy_04
    from Kansas
    actually you're wrong. they can be hollow
  16. fergusonic
    fergusonic
    from Kokomo, In
    a ring for a long fingered 5 year old?
  17. 51 Leadsled
    51 Leadsled
    from NC
    It looks like away to spend more time in the garage with dad!
  18. uc4me
    uc4me
    that'd be my guess
  19. squirrel
    It's for the filter. Deep pan (truck) transmissions use it. Goes between filter and valve body.
    If he was working on some late model little engine, it might be a bellhousing alignment dowel, but the dowels on all the TH400 equipped engines were solid. Because the bolts are above and below the dowels, not in them.
  20. Deuces
    Deuces
    Ditto on that last post. ^^^
  21. kelseydum
    kelseydum
    Thanks guys, I got the spacer back on. It went to the filter bolt. I'm glad I noticed it when I was cleaning up though. My first thought was... Oh God did she crawl under there and pull something out!
    I got it fixed now... Thanks all for the info. Now I know what an alignment dowel looks like too.
  22. onlychevrolets
    onlychevrolets
    Actually your wrong..... a transmission lineup dowl is not hollow , unless your a tuner guy.
  23. 46stude
    46stude
    :D
    That was a good 'un.
  24. kelseydum
    kelseydum
    edit. Wrong thread
  25. duste01
    duste01
    looks like a guitar slide
  26. jc555247
    jc555247
    It's not a piece from inside a king pin set is it? Are there groves inside it and is it copper color inside?
  27. If it was, then we have a hell of a coincidence. According to post #22, he successfully reinstalled it in the transmission.
  28. I've seen hollow alignment pins, but not on anything that takes a TH400. I haven't seen everything though. It's been a few years since I had a 400, but I remeber that part on the filter.
  29. DonMan
    DonMan
    Glad you found where it goes.
    I was really thinking that part looked like the inlet tube for a Kanooter Valve. I had one on a Huppmobile. Of course my car had the Quadraphonic system on it, so I`m not sure that the Kanooter Valve inlet tube would be the same . . . :confused:
