i neeeeeed help
Discussion in 'The Hokey Ass Message Board' started by customrod, Feb 21, 2010.
  1. customrod
    customrod
    hi guys i have a 58 ford that runs abit on the hot side about 190deg to 195deg it has a 400m clevo in it with 302 heads about 10.5:1 comp runnin on lpg gas (propane).it has a huge 4 core xflow radiator twin thermo fans,timing has been done on the dyno has the coolest thermostat i could get and ive drilled 4 holes in it.on cool days it runs around 180deg wich is fine but as soon as the weather warms up so does it ....
    any help would be greatly apreiciated as i am gettin to the end of my fuse with it ready to pull it out and throw it to the ****house
    cheers...
  2. harrydude
    harrydude
    from ab
    biggerst thing I read is the fans???
    can you post a picture???
    do you have a shroud?? do the fans cover the whole rad???
    is the rad clean???
    is the fans push or pull???
    need a little more info
    thanks
    also what is the mix in the rad?
    you can also ad a race product called water wetter,,, it highers the boiling point
    look in to the race car area for heat isuues
  3. The Hank
    The Hank
    from CO
    does it havve a shroud?
  4. Unkl Ian
    Unkl Ian
    195 is NO problem at all.
  5. customrod
    customrod
    its got two large thermo fans that cover the whole radiator its a pull set up.no i dont have a shroud
  6. customrod
    customrod
    what temp would u start bein woried at ???
  7. SchlottyD
    SchlottyD
    Anything over about 230 is when u need to start thinking about shutting her down. As mentioned before water wetter is a damn good product that works, I've run it in circle track and drag cars and in both situations dropped temps by about 20 degrees. By the way, is the engine bored?
  8. customrod
    customrod
    yeh its bored out 020" so that should be fine
  9. duste01
    duste01
    drilling holes defeats the purpose of separating coolant that needs to be cooled as opposed to coolant that has been cooled. And thats not really "too hot" but get a shroud.
  10. 40streetrod
    40streetrod
    from nj
    400 M (modified - cleveland) with 302 heads ?
    may I ask what 302 heads are you running on a 400 M block?
    BOSS 302 heads or 302 Windsor? something just doesn't sound right here,
    please explain.
    thanks
  11. customrod
    customrod
    302 clevo heads mate
  12. american opel
    american opel
    from ohio
    there is no such thing as 302 cleveland heads.i95 isnt that hot,i do like mine in the 165-185 range.what deg.thermastat are you running?it should be running a 195deg in it.also lp should be running really cool,but it also has to be hot enough to heat the lp so it doesnt freeze.i guess i have herd of people putting cleveland heads on a 302{boss}is this what your running?pics.and yes put a fan shroud in it
  13. skidsteer
    skidsteer
    Boiling point of water goes up when under pressure, so can get hotter before it boils.
  14. R. Seghi
    R. Seghi
    I would have the radiator flushed out and buy a new cap.
  15. tdoty
    tdoty
    Seems some folks think Ford only made engines in the US. I'm pretty sure there was an Aussie made "Clevor" 302..........................I don't think I'm imagining it.
    Tim D.
  16. George
    George
    Ford Australia made 302 Clevelands, they're not Clevors. 302C is same as a 351C we have here, just with a 3" stroke crank & 6" rods. I often run 190 thermostats, cylendar wear is a lot less than if a 160-170 is used.
  17. Crease
    Crease
    I agree that 195 is no problem.
    ***uming you just gotta hit 180. Does it run at 180 on the highway? If not, probably not a fan in the world that will get it there.
  18. nutajunka
    nutajunka
    Heat doesn't sound to bad, but I like 180 to just for a little margin also. Where is the tem. sensor located and is it correct? Do my old shop rag trick if those fans have a built on shroud arond them. Put a shop rag on the front of the raditor at idle with the fans on and see if it can **** it flat to the radiator. Does it cool down driving down the road?
  19. Just a thought, how good is the water pump? some are better than others, how old is the pump?, the impellas could be rusting away.
    Has it been like it since you bought it or built it?
    Cheers, Waz.
  20. Fiddytree
    Fiddytree
    from Durango
    Hope you are running a Cleveland t'stat, not a Windsor t'stat!
  21. Not sure why we are worried about running at 195*F
    You can run it up to 230*F if you really want to (It runs more efficiently) and still be almost 20*F from the boiling point with a 15# cap.
  22. Gasser57
    Gasser57
    302 Cleveland is an Aussie engine, just like a 351 Cleveland. Your combo sound as if it should work fine, so check to see if the fans are moving the air in the right direction, and the water pump is spinning the right direction. I'm not positive, but on small block Fords, they changed rotation in the early 80's when they switched to serpentine belts. The Aussie motors may have a similar issue where the pump bolts on, but doesn't rotate the right way. Other than checking those, it sounds as if it should be fine. I wouldn't worry about the temp until you're at 220 on a real hot day. Good Luck!
  23. customrod
    customrod
    yeh there is buddy im in australia the 302 heads have a smaller combustion chamber about 56 cc from memory that along with oversize valves and a port clean up makes 4 a nice package so no it isnt a boss.
  24. customrod
    customrod
    yeh water pump is brand new mate :)
  25. american opel
    american opel
    from ohio
    sorry about saying there wasnt a 302 cleveland.i have been into ford all my life and i never herd of one.do you have any pics?so are they small bore bigblocks?some of my friends use to put the clevelands in there mustangs but they didnt like to rev up like my windser pluse they were way heavy and big!!!
  26. George
    George
    As I posted earlier, they are the same as the US 351C except for having a 3" stroke & 6" rods. Put in a 351 crank & rods & you have a 351C. Thier heads have some revisions that make them a bit better than ours.
  27. George
    George
    Aussie Cs If you comment was the 400s are big & heavy, they are! Have been a few threads on how to wake them up.
  28. pinstriper ny
    pinstriper ny
    are the fans in the right direction are they large enough if all fails use a fluid that will lower the temp.
  29. Thorkle Rod
    Thorkle Rod
    Does it get hotter on the higway at speed or does it get hotter when idling. If it's getting hotter at idle you would most likley have a fan or shroud air movement problem. If it's at highway speed then I would check out the things that make the water flow. You say when the weather is warmer it gets hot, how warm is the outside temperature when it's running hotter?
    Being that you are down under maybe the water is going the opposite direction :)
  30. 29nash
    29nash
    from colorado
    Yep, if it ain't puking the coolant, chill out and drive it.
    I don't understand the logic of drilling holes in the thermostat.
