Beer Can Welding!!
Discussion in 'The Hokey Ass Message Board' started by fordrat31, Feb 23, 2010.
  1. fordrat31
    fordrat31
    from Palmer, MA
    I was looking through some welding forums the other day and noticed some people talking about welding two beer/soda cans together. They said it was fairly hard to do. I had to give it a try! Went out to the shop and this is what I came up with. I really didnt find it that hard to do. To me the hardest part was getting the cans tacked together. After that you can concentrate the heat on the bead you have started. Has anyone else tried this?
    Mike
  2. Shaggy
    Shaggy
    from Sultan, WA
    Now try doing it with the Oxy Acetolene!!
  3. Used Up Junk
    Used Up Junk
    from Merced, CA
    Nice welds but when I talk about welding up a beer can I meen through the sides where the can is thinest. Imagine cutting two cans in half to make a top and bottom then welding them back together to make a normal looking can again. I'm sure this is way off topic but it's a fun challange!
  4. DenverDave
    DenverDave
    from Denver, CO
    I heard a story about welding two foil chewing gum wrappers together. It that possible?
  5. fordrat31
    fordrat31
    from Palmer, MA
    That would be very impressive. I tried to lay a bead on the side of a can and it instantly blew through as soon as I struck the arc. I would love to see a picture if anyone has sucessfuly done it.
  6. Fenders
    Fenders
    Lemon lime soda ????
    Hey we're talking BEER cans !!!
  7. Flathead26T
    Flathead26T
    now try welding some aluminum foil together!
  8. fordrat31
    fordrat31
    from Palmer, MA
    HAHAHA sorry I was fresh out!
  9. carcrazyjohn
    carcrazyjohn
    from trevose pa
    Ever had any luck with alumna weld .It works great on beer cans ,Have not had any luck with it on any other aluminum.
  10. GasserDave
    GasserDave
    from Sin City
    Here is my welding Instructor. Won-hung WayTulo ..He was a master welder of cans. Problem was he kept lighting his face on fire..
  11. hotroddon
    hotroddon
  12. fordrat31
    fordrat31
    from Palmer, MA
    Wow! Thats very impressive!
  13. Punk_from_palmy
    Punk_from_palmy
    Well ****** me sideways with a Sally!
    With skill like that, bet you could build your own cylinder heads starting with just a neat little bead!
  14. 64Cyclone
    64Cyclone
    Dang I thought you were talking about using a beer can as a welder on the cheap. Or maybe even welding while drunk. I've seen some welds that looked like they were done by a drunk! :(
  15. lippy
    lippy
    from Ks
    A buddy of my Dads, RIP, welded aircraft aluminum tail section parts during WW2 with a torch for Dougl***. He said the test was tough. You didn't just weld it, it was stress tested, and checked seven ways from sundown. He claimed a guy he worked with could weld two Schlitz steel cans together down the middle. He said most was 1/16 or less alum. Lippy
  16. revkev6
    revkev6
    from ma
    wonder if you could slip a copper backer in through the tab hole to make striking the arc easier without blowing through??
    not that anyone would cheat ;)
  17. JOBCORP
    JOBCORP
    if you want to see it done RIGHT pm deviator he is the master at this
  18. Wesley
    Wesley
    some people have WAY too much time on their hands
  19. Pete1
    Pete1
    from Wa.
    Those are impressive welds.
    I tried welding aluminum cans end to end both with tig and
    oxy/hydrogen..Worked fine for both.
    Back in the 50's I gas welded 60 feet of steel beer cans together
    to make a vertical antenna..It worked great. The hardest part was
    putting it up without kinking any of them.
    The best part of the project was emptying the cans.
  20. GREASEMONKEY72
    GREASEMONKEY72
    thats pretty cool
  21. R Frederick
    R Frederick
    from illinois
    Yea, but are they water tight?
  22. greasemonkey060
    greasemonkey060
    I've Tig'd razor blades, but I'll have to try beer cans.
  23. ironfly28
    ironfly28
    from Orange, CA
    sure, but can you do it when the cans are FULL?
  24. chevy3755
    chevy3755
    very impressive...........im lucky if i can just strike the tourch.............
  25. Turbo26T
    Turbo26T
    My uncle's sister's step-brother's neighbor says he can weld a fart to a dryer sheet...wonder what heat setting he uses..
  26. 53sled
    53sled
    from KCMO
    Got a friend who is into vw's, they weld cooling tubes onto the fins to make water cooled conversions. Anyway, he practiced for a long time to get the cans to weld together, but by age 16 he got it. it is good to have friends. :)
  27. MeanYellowZ
    MeanYellowZ
    Now THAT is talent!:eek:
  28. willburton7
    willburton7
    i went to visit a welding cl*** at a tech school and some guy cut a copenhagen lid in half and welded it back together, not sure what he used to weld it
  29. the-rodster
    the-rodster
    Can you describe the method?
    TIG?
    What filler? What size?
    What tungsten? What size?
    What gas?
    What welder settings?
