350 engine build -compression question ?
Discussion in 'The Hokey Ass Message Board' started by 31nash, Feb 26, 2010.
  1. 31nash
    31nash
    from newminas
    hey there i have a std bore 4.000 350 with flat top pistons with 4 valve reliefs which i believe are -6cc and the heads im using are the 882's 194-150 , 76cc and are milled .030 , head gasket is 1003 fel-pro which is .041 thick what would be a estimated compression ratio ? the piston sheet said with 76cc heads and flatops would be 9:1 ?? the block has not been decked either !!
  2. Deuces
    Deuces
    - 1cc per every .006" milled... So, your probably looking at around 9.5:1 would be a rough guesstimate.
  3. 31nash
    31nash
    from newminas
    yeah man thats what i was thinking too , nice to hear another persons input
  4. Deuces
    Deuces
    Your welcome bud!! :)
  5. WNC
    WNC
    from Western NC
    If the pistons run to zero deck, you've 9.46:1. If they're 0.010" in, you've 9.26:1.
  6. 31nash
    31nash
    from newminas
    rightt on man thanks
  7. FWilliams
    FWilliams
    no decking of the block is going to put the piston down in the hole.020to .025
    pin height on the piston will add to this if rebuilder pistons were used
    fel pro 1003 adds 9.1 cc to the head ......... 4.166 bore and .041 compressed
    most 2 valve reliefs are at -5cc...i am not sure the 4 would be at- 6
    4.0 bore
    3.48 stroke
    factory piston is gonna put it down in the hole roughly .020 if a cast rebuilder piston was used add another.020
    fel pro 1003 9.1 cc
    really should cc the heads to see what they are at...... .030 shave on 882's is quite a bit
    doing the math quick you should be right aroound 8.5 -1 maybe 9-1 depending on the actual volume of the heads
    if the valve reliefs are more and a rebuilder style piston was used it will be less
    do you know the part number on the piston so we can get the pin height?
    Fred
  8. 31nash
    31nash
    from newminas
    hey fred the pistons are mahule partnumber #5999110080303
  9. man-a-fre
    man-a-fre
    If the blocks not decked i bet the pistons are at least .030 down in the jug ,you should check to get your quench right at .035 to.045..
  10. Hubbcat
    Hubbcat
    from Sweden
    Give me a hint Please? have a 16 comp whitout sparkplugs 350 400 crank 383.
    flat top piston,afr heads,
    16 a little to much ??????
  11. 31nash
    31nash
    from newminas
    nahh ur goin too need the angleplug conversion kit from summit to run that comp part number 3825633 lol......and u should run the .25 head gasket made from canadian hermaphrodite unicorn rare but not as rare as hens teeth
  12. Rich Rogers
    Rich Rogers
    If you want to bump the comp a little more, you could do a .028 head gasket.
  13. 31nash
    31nash
    from newminas
    the heads have been torqued down but is still on the stand will these head gaskets still be good where they were just put on a few days ago ? the motor has not been run
  14. Deuces
    Deuces
    A pair of 4V 305 cyl. heads with 57-58 cc chambers should bump the comp up to about 10.2:1 ..... Be prepared to run 93 octane fuel.
  15. Those 305 heads are ****. They're really restrictive, even on a 305, they ****. You'll lose power even though they raise the C/R. They just don't have the flow to make the go.
  16. 31nash
    31nash
    from newminas
    or i could go with a set of 64cc and run a 0.015 gasket haha hmmmm
