Chopped T want tin roof
Discussion in 'The Hokey Ass Message Board' started by busch, Feb 28, 2010.
  1. busch
    busch
    Started 5" chop Friday nite the more I work on it the more I don't like the no roof look, have seen a few done with metal one had a suburban roof look good can't seem to find it now, any ideas on what might work or some pics of a few done. Here's what I started on
  2. 117harv
    117harv
    Does it have to be metal? How about some curved oak bows with some fabric across it?
  3. busch
    busch
    this is what I have not happy with it
  4. R Pope
    R Pope
    Suburban roof has ribs, look pretty cool. Or a minivan.
  5. fiftyv8
    fiftyv8
    from CO & WA
    Difficult issue with T Coupe and Tudor's to find a roof that works, they are so wide and the edge is not easy to make pretty.
    I have seen a piece of art done on a model A closed cab pickup but the guy had talent and spent hours and hours on it.
    I used an orginal wood kit and beefed it up with steel tube but still using the soft covering.
    I dont have the time to commit to such a project as I want it dont right.
    Finding a donor roof is one thing, but fitting it and making it work is another.
  6. busch
    busch
    your so right I'm having a hard time envisioning the edges what the roll would look like
  7. greasemonkey060
    greasemonkey060
    Does that thing run and drive?
    Summer is right around the corner you might want to leave it off!! :D
  8. 117harv
    117harv
    I have sen some with 80's ford van roofs , they have 1 3/4 wide ribs and have a small arc which seems to work well for the T sedans. They need a rolled edge though, they don't look right when they are just welded to the roof flat.
  9. 29nash
    29nash
    from colorado
    Not a T, but I like my tonneau cover.
  10. rexrogers
    rexrogers
    Using a van roof will work check in on some of the metal working sites pulls some tuck shrinks around the corners or even a small 1" radius edge formmed over a T dolly would work. go top less for the summer make finish the roof the next winter.
  11. busch
    busch
    Thanks for the tip Rex, thats one hell of a Buick Special wow
  12. Johnny Sparkle
    Johnny Sparkle
    I'd go with the stock wood roof. Pretty much everything else looks terrible on T sedans because the contours look wrong.
  13. busch
    busch
    any one that been for a ride gets white knuckled hanging on lots of fun
  14. busch
    busch
    do you have any better pics of your wood roof
  15. DirtyJohn
    DirtyJohn
    <------this what you talking about? lol!
  16. fiftyv8
    fiftyv8
    from CO & WA
    If you truely want to do the roof right then you will need to get a 1/4 curved section rolled in sheetmetal and start shaping it around the perimeter of your roof edge.
    Id suggest a little bigger than 1 inch radius so you have a little to play with when you hit the high and low spots around the door, rear corners and the windshield posts.
    Better still try to get something rolled similar to the wood in the roof kit as per my attached pic below.
    You will need to put some pie cuts or use a shrinker or maybe both to achieve the curved shape and follow the edge of the body.
    May also suggest that you get quite a long tail attached to your radius crved sheetmetal edge so it comes in about 3 to 4 inches.
    It can always be cut off later if no good to you, but it may save your life if you get a roof from a donor vehicle that is a tad narrow.
    It may so make welding easier as it will get you out of the edge where hammering and supporting etc could be difficult to access.
    You will also need to get some tube cross over pieces curved to shape which will support the main body of the roof and hold your body sides in shape.
    Do not weld your roof to these cross overs as you need the roof to be able to move seperate to the supports both whilst constructing it and later when finished.
    If the roof and cross overs do not quite match up or you has a couple of hollows you will need to use some home made packers to slip between to help form and maintain the shape and smooth curve of the roof sheet.
    TIG welding would be best but oxy or MIG should work, possibly get an expert welder to weld your donor roof in once you have fitted it and tacked it in.
    You will need to get the fit near perfect allowing a very small gap between the edge and the roof sheets.
    This will allow it to pull up when welded and reduce the chance of getting humps and warps from the welding heat.
    Small short welds move around to various locations and use wet rags sitting around your welding zones.
    No fun but worth a fortune once finished if it is a good job.
    That is why I did not attempt mine yet as I dont have the time and not ready for the challenge.
  17. Busy B
    Busy B
    from Kalama, WA
    Mine uses a s10 blazer roof. Check out my pics and see how it looks.
  18. The37Kid
    The37Kid
    fiftyv8 has some great advice. I've only seen one 26-27 Tudor with a steel roof and I know it cost the owner a bundle, but it looked great.
  19. busch
    busch
    fiftyv8 thanks for the advice an taking the time like you said alot goe's into this, and springs about here
    Busy B that look great can you get some closeup of the edges did you have to put any struts on the inside under the roof of any kind
  20. James D
    James D
    How about grafting on a Model A roof? That way you could lose the hard corners around the back and sides. Would get people scratching their heads too, which is always fun.
  21. texkbc
    texkbc
    Can someone tell me where you can buy the wood kits for T sedans?
    thanks
  22. fiftyv8
    fiftyv8
    from CO & WA
    I got my T coupe kit from Snyders, but I believe Howell's in TX do them.
    There is also a company some where in ID that makes them, but I dont recall the name.
  23. fc ute
    fc ute
    not exactley a T roof, but i did base this one on the T shape.
    i used a valiant station wagon roof skin and rolled the edges over so it wasnt a "sharp" edge
  24. John_Kelly
    John_Kelly
    I'm with Rex, you can tuck shrink at the corners and roll the straight runs. Tuck shrinking makes a really nice corner.
    You could also stretch the hard curves at the perimeter and blend the stretching into the panel. A lot of work, but it could be made to look perfect instead of almost right as sometimes happens with a donor.
    Or, you could both tuck shrink and stretch, a combination of both methods. If you know how to tuck shrink it would probably be faster unless you have a palm nailer and a portable planishing hammer to do the stretching and smoothing. My videos below show both of these methods.
    John www.ghiaspecialties.com
  25. busch
    busch
    John those are some very helpful videos
    tuck shrink got to learn more about this thanks
  26. Johnny Sparkle
    Johnny Sparkle
    I got my roof from Snyder's also. It went together pretty easy. Kinda pricey, but once you figure how long anything else will take to make look decent, it's not too bad.
  27. 26 coupe
    26 coupe
